[AOKP-ROM][JellyBean]*02.08.13*[4.2.2] JellyBamV9.2.0 [MiX-PARANOID-AOKP-CARBON-10.1]
  • 2.104 Antworten
Video aufnahme ohne Ton?!
Ist das bei jemanden auch der Fall?
JellyBamV7.0.0
Neueste Dori(dings) Kernel
kann ich nicht bestätigen! bei mir geht der ton einwandfrei bei kamera!
V 7.2 ist raus
BAM Android
Changelog
JELLYBAM Project name: android_build
.igio90 – BamSizer -> BamCleaner Signed-off-by: igio90 <giovanni.rocca.90@gmail.com>
.igio90 – Building BamSizer from sources
.igio90 – Port forward: [1/3] Install persistence support
JELLYBAM Project name: android_frameworks_base
.igio90 – HoloBam Tile: Toggle label on status change
.igio90 – FW: Holobam Tile 1/2
.Domenico – Add Holobam Tiles
.igio90 – Cleanup
.Quarx2k – Add UsbDebuggingManager and UsbDebuggingActivity to LegacyUsbManager
.Zaphod – SysUI : Fix opacity of LastApp Icon
.Zaphod – SysUI: Prevent Kill-Task from killing SystemUI.
.Guobin Zhang – Two REMOVE_PROVIDER messages caused by race condition.
.Wei Zou – Remove opaque check in GLRenderer when preparing dirty region.
.Jeff Sharkey – Tighten enforcement of file modes.
.igio90 – Fix up and missing res for Sleep tile Signed-off-by: igio90 <giovanni.rocca.90@gmail.com>
JELLYBAM Project name: android_vendor_htc
.igio90 – pyramid: copy camera.default.so as vendor-camera.default.so as per camerawrapper.
JELLYBAM Project name: jellybam_vendor
.igio90 – New supported device hercules – Samsung Galaxy S2 T-Mobile
.igio90 – New supported device mesmerizemtd – Samsung Mesmerize
.igio90 – New supported device p760 – LG Optimus L9
.igio90 – New supported device Skyrocket – Samsung Galaxy S2 ATT LTE
.igio90 – New supported device t0lte – Samsung Galaxy Note 2 LTE
.igio90 – New supported device Vibrantmtd – Samsung Vibrant
.igio90 – New supported device LG VS920 – LG Spectrum
.igio90 – BAMModder v2
.igio90 – Persist: Added paranoid preferences
.igio90 – Port forward: [2/3] Install persistence support
.igio90 – Bum to 7.2
.igio90 – Updating ville manifests
.igio90 – Removed touchwiz launcher, passed as option into bammodder
.igio90 – Added tf300t, tf700t
JELLYBAM Project name: platform_manifest
.igio90 – Tracking BamSizer
CyanogenMod Project name: android_hardware_qcom_display-caf
.Ricardo Cerqueira – gralloc: Let gralloc_priv.h be overloaded by device trees
.Giulio Cervera – display: fix “Use cache invalidate and clean correctly” merge
.Steve Kondik – Tiny changes to support media codecs with vanilla driver.
.Naseer Ahmed – display: Use cache invalidate and clean correctly
.Saurabh Shah – hwc: Configure pipe for FB even if we exceed max layers
.Arun Kumar K.R – libcopybit: Use blending parameters passed by HWC
.Sravan Kumar D.V.N – hwc: Configure FbUpdate only when needed
.Arun Kumar K.R – libexternal: disable HPD during initialization.
.Arun Kumar K.R – hwc: fix dst calculations for right mixer
.Ping Li – libqservice: Change the permission for SCREEN_REFRESH
.Jeykumar Sankaran – display: Remove framebuffer HAL usage
.Naseer Ahmed – gralloc: Stride information fix
.Saurabh Shah – hwc/ov: Fix MDP orientation flags and values.
.Saurabh Shah – hwc: qclient: Subscribe to mediaplayer death later.
.Prabhanjan Kandula – libhwcomposer: add dynamic thresold support for copybit.
.Sravan Kumar D.V.N – hwc: Use correct z-order in video overlay
.Saurabh Shah – hwc/overlay: Video on 4k2k external, 4k2k rotation.
.Ramkumar Radhakrishnan – gralloc: Override gralloc calculated size only if bufferSize is greater.
.Amara Venkata Mastan Manoj Kumar – hwc: Handle WFD Pause/Resume usecase
.Arun Kumar K.R – libcopybit: Remove usage of C2D_NO_BILINEAR_BIT
.Naseer Ahmed – hwc: Add support for clearing with c2d
CyanogenMod Project name: android_hardware_qcom_media
.Steve Kondik – Tiny fixes for building on vanilla display driver.
CyanogenMod Project name: android_hardware_qcom_audio-caf
.Daniel Hillenbrand – alsa: make pcm debug flag optional
CyanogenMod Project name: android_kernel_samsung_d2
.Dan Pasanen – video: msm: re-enable framebuffer splash screen
.Steve Kondik – Revert “Revert “msm_fb: display: remove background invert alpha option for alpha drop pipe”"
CyanogenMod Project name: android_kernel_samsung_smdk4412
.Daniel Hillenbrand – smdk4412: enable sio iosched
.Daniel Hillenbrand – block: add sio iosched
.Daniel Hillenbrand – smdk4412: enable row iosched
.Daniel Hillenbrand – block: add row iosched
CyanogenMod Project name: android_kernel_samsung_smdk4210
.Daniel Hillenbrand – i777, i9100, n7000: enable row io scheduler
.Andrew Dodd – mali: 3-step gpu DVFS control
CyanogenMod Project name: jellybam
.igio90 – Updating release script with the new devices
.igio90 – Added the new devices to the release scripts
CyanogenMod Project name: android_packages_apps_Apollo
.Jorge Ruesga – Apollo: Fix afrikaans aapt warning
JELLYBAM Project name: android_packages_apps_BamCleaner
.igio90 – Tracking default settings icons
.igio90 – derp
.igio90 – Update README
.igio90 – BamSizer -> Bam Cleaner Signed-off-by: igio90 <giovanni.rocca.90@gmail.com>
.igio90 – Initial
CyanogenMod Project name: android_packages_apps_LockClock
.DelPETER – LockClock : reorganize and add french translation
JELLYBAM Project name: android_packages_apps_Settings
.igio90 – Fixed typo
.igio90 – Tracking the new BAMCleaner icons
.igio90 – BAMControl: HoloBam tile 2/3
.Mark van Osch – Settings: Added BAMcleaner icons beta
.igio90 – BAM Persistence: Persist PA prefs
.igio90 – Tracking new persistence icons and some strings re-order!
.Mark van Osch – Settings: Added persistence icons
.igio90 – BAM Persistence: Summary and headers!
.igio90 – Missing re-order ids
.igio90 – Settings re-order Signed-off-by: igio90 <giovanni.rocca.90@gmail.com>
.igio90 – Overhaul CMDProcessor to fix deadlock and allow redirection
.igio90 – Port forward: [3/3] Install persistence support
.igio90 – BAMModder: Fixed typo
.igio90 – BAMModder apps: Samsung S-Note
.igio90 – BAMModder Apps: Samsung Task Manager
.igio90 – BAMModder fonts: Added asap and avenir
.igio90 – RC New unlock logic for lockscreen
.igio90 – Amend singleChoiceItems where it is not a permanent/visible choice
.igio90 – SECURITY FIX: Fix package uids being reused between uninstall and reinstall of different packages
.igio90 – Fixup donate app intent
.igio90 – Tracking bammodder donor app
CyanogenMod Project name: android_packages_apps_SamsungServiceMode
.Pawit Pornkitprasan – SamsungServiceMode: dynamic line count
JELLYBAM Project name: android_packages_apps_Mms
.Muhammed Nazim – Small visibility fix
.Jiri Tyr – Option to strip all unicode characters from SMS
CyanogenMod Project name: android_packages_apps_Camera
.Tamás Tóth – Added hungarian translation
.Ricardo Cerqueira – Fix picture size tables
CyanogenMod Project name: android_packages_apps_CMFileManager
.Marco Brohet – CMFM: NL translation reorganization
.Francesco – CMFileManager: Update italian translation
.djMesias – es_ES: Add spanish translations
.DelPETER – CMFileManager : reorganize and new french translation
.jackmu95 – CMFileManager: Update German translation
.Jorge Ruesga – CMFM: Fix reflection call in ColorPickerView
.Jorge Ruesga – CMFM: Fix hex viewer dark theme
CyanogenMod Project name: android_packages_apps_Browser
.Chirayu Desai – labs: websockets: fix typo in preference key
CyanogenMod Project name: android_device_samsung_i9103
.Adam77Root – Various fixes
Meine Güte, man kommt ja kaum noch hinterher. Statt immer mehr und mehr in die Rom zu integrieren was eh kaum jemand braucht sollte er lieber anfangen mit optimieren.
Reaktionen: Steveria
Stimmt, wiedermal sind die bugs nicht gefixt worden. Die rom ist mittlerweile genau so undurchsichtig wie seine webpage und sein changelog. :D
Gesendet von meinem GT-N7100 mit Tapatalk 2
Moin Zusammen,
Seid der 7.1.0 hab ich 2 Uhren in der Leiste und wenn ich die Uhr deaktiviere
Sind beide weg ...dann aktivierte ich wieder de Uhr und ich hab eine...
Aber sobald ich die Leiste rausziehe und wieder einklappe sind 2 Uhren wieder da.
Weis einer von euch was?
Gesendet von meinem GT-P5100 mit Tapatalk 2
Hast du die Uhr zentriert? Wenn ja, dann auf rechts stellen, dann ist nur mehr eine da. Hat aber redbull1 auch schon öfter gepostet gepostet!
Gesendet von meinem Nexus 7 mit Tapatalk 2
Hab ich und zwar alles genau so und die 2. Ist immernoch da :(
Gesendet von meinem C6603 mit Tapatalk 2
Das mit der Uhr hat mir ja keine Ruhe gelassen aber ich kann mich auf den Kopf stellen ich krieg keine 2 Uhren, keine Ahnung was da bei mir falsch läuft.
Anbei noch nen paar Screenshots nicht das ihr denkt ich würde euch übern Nuckel ziehen ;), sind halt ein paar mehr weil ich mit der Uhr noch hin und her und dann noch der Tag mit rein usw. und das beste ist ja noch normal hab ich die garnicht an :blink:
Was hat das Kamel da zu bedeuten?
Errare humanum est!
OT AN
Vielleicht solltet ihr einfach mal nicht gleich jedes Update flashen. Wartet doch erst mal ab. Wozu muss ich das noch haben und jenes noch und auch noch dieses Feature? Je mehr in eine ROM kommt, desto mehr Fehler macht sie. Ist doch klar. Also nicht beschweren. Entweder Finger weg vom Flashen oder mit den Fehlern leben. Wir sind alle Menschen u machen alle Fehler. OT ENDE
Das ist das Symbol von Llama, das steuert verschiedene Sachen wie Töne und Lautstärke je nachdem an welchem Ort ich grad bin.
LG Tommi
Habt ihr auch mit cm diese unschärfe in der schrift?
Gesendet von meinem GT-i9100
Das muss ja so unscharf sein das du dich sogar im Thread verlaufen hast :laugh: du bist grad im Jelly Bam Thread. Aber um auf deine Frage zurückzukommen, hier ist nix unscharf, siehe Screenshots etwas weiter oben.
Tommi
Diese unschärfe ist bei jeder 4.2.2 rom bis jetzt mit cm kernel vorhanden!
Kann ich nicht bestätigen.
Errare humanum est!
Reaktionen: derpennerwinter
Aha, da liegt der Hase im Pfeffer, Kernel nehm ich nur Dori.
Tommi
Ja dorimanx hat denn sharpness tweak,habe grad mal eine andere schrift gewechselt und an der Farbe gespielt jetzt ist besser ,nicht 100% aber ok
ups, ganz vergessen, das abo abzuschalten, denn
goa 6.4 plus turkbay theme= jellybam 25.9.9 ;)
RedDr4g0n
RedDr4g0n
RedDr4g0n
antsa
beicuxhaven
RobertAntonio
