S2_Galaxy
Stamm-User
- 106
- Themenstarter
- #801
Wenn man die Tapatalk APP nutzt wird die Signatur nicht angezeigt.
Originally Posted by iGio90
We have recently started the various tests of the new jellybam v5.0.1 based on Android 4.2.1.
The changelog is huge and rich, many new features and applications. We have also included the new Xposed framework, which will replace the Paranoid Settings. A video tutorial will come before the official 5.0.1 release.
Regarding the compatible devices, I doesnt know all the details, I just started to make various porting. In addition, several changes were made to different device tree including the Samsung Galaxy S3, I can not tell for sure if the problem of the lockscreen has been fixed since I do not have such a device to be able to do the tests.
Here is the changelog of the new v5.0.1, let me know what you think via our fan page on Facebook or by a comment below.
project vendor_jellybam:
* Removed prebuilted PerformanceControl, Build from AOKP Sources
* Added XPosed DPI Changer
* Fixed DisableMediaStorage
project android_frameworks_base:
* SystemUI: update nav bar keyguard logic
* SystemUI: cleaner recents key implementation
* Alternate Signal Layout (1/2)
* New toggle: sound state (ring/vib/silent)
* Lockscreen: option to use carousel animation when switching widgets (1/2)
* Lockscreen: enable longpress on expand challenge handle (1/2)
* SystemUI: unlock keyguard to open nav ring apps
project packages_apps_Settings:
* DeviceInfo: Add chipset to supplement cpu display in device info
* Added DPI Changer
project packages_apps_ROMControl:
* Clean up some leftover performance files and strings (Merged)
* RomControl: NavBarColor (2/2) (Merged)
* New toggle: sound state (Merged)
* Lockscreen: option to use carousel animation when switching widgets (2/2) (Merged)
* Lockscreen: enable longpress on expand challenge handle (2/2) (Merged)
* ROMControl: Cleanup czech translation (Merged)
* Alternate Signal Layout (2/2) (Merged)
project packages_apps_PerformanceControl:
* PC: Remove app from app drawer (Merged)
project packages_apps_Camera:
* Camera : Powerkey shutter (2/2) (Merged)
* Camera: port additional settings from jellybean 4.1 (Merged)
* Camera: extend supported exposure compensation range (Merged)
project packages_apps_LockClock:
* LockClock: Added pt-PT language. (Merged)
* LockClock: Czech translation (Merged)
* LockClock: Added Danish translation (Merged)
project packages_apps_CMFileManager:
* Added missing hungarian translation (Merged)
* PT-BR: Added missing translations (Merged)
* CMFM: Dutch translations (Merged)
* CMFileManager : add French translation (Merged)
* Update Russian Translation-CMFileManager-CM10.1 (Merged)
* Added hungarian translation for .nomedia settings (Merged)
project packages_apps_Torch:
* Torch: Hebrew translation (Merged)
project packages_apps_DeskClock:
* DeskClock: Hebrew translation update (Merged)
project ackages_apps_Browser:
* Browser: Hebrew translation (Merged)
project kernel_samsung_smdk4412 (S3, N7000)
* t0lte: disable samsung mtp (Merged)
* use VZW defconfig as common T0LTE cdma defconfig (Merged)
* t0lte: support for galaxy note 2 lte (Merged)
project kernel_samsung_smdk4210 (S2):
* Revert mach-px: Remove odd ION contigheap #ifndef (Merged)
* Config: remove PMEM, reduce FIMC1 alloc (Merged)
* Tabs: disable Sec_Fifo DAI (Merged)
project device_samsung_smdk4412-common:
* Add I605 and L900 (Merged)
* smdk4412: set cityid parameter for t0lte camera hal (Merged)
* smdk4412: add support for note 2 lte (Merged)
project device_samsung_i9300:
* Fix Quick Toggles FC
project android_hardware_samsung:
* gralloc: Remove hacks (Merged)
project frameworks_opt_telephony:
* Make ringing audio focus handling work with Speed up audio on MT call flag
(Merged)
* SMSDispatcher: Add option for sending pseudo-multipart SMSes (Merged)
* telephony: set additional audio parameters for incall audio (2/2) (Merged)
project frameworks_av:
* audioflinger: Fix to release wakelock after closeoutput (Merged)
