Masta_Gee81
Enthusiast
- 5.419
Post 1 - ANDROID 4.1 - PFittech ROM GT -JB
Post 2 - ANDROID 4.0.4 - PFittech ROM GTX -ICS
What is Neutrino system? Neutrino is connection between AOKP & CM10 & HTC & Samsung & SE sources in one functional system. In this way, I managed to create a system which is very fast, smooth and stable. Another advantage is that the system can be easily improved without re-compiling. Neutrino - faster than light.
PFittech Home
Advanced user support - my new forum PFittech Forum • Index page. If someone want me moderator or want help me then contact me pfittech@gmail.com
Im finding new user who will help me with forum - moderator, uplaoders etc. IF you want help me then pfittech@gmail.com
Every new user is welcome .)
http://code.google.com/p/pfittech-de...nt/issues/list
If you report bug and bug is now deleted - came to the following:
1. I dont accept your report (not my bug, bad report, impossible fix)
2. Bug was fixed - NEXT version ROM without this bug
3. All bug reports are deleted if I bring new version of ROM
P.S. Danke drücken kostet nix
