[AOKP-ROM] *17.06.12* (4.0.4 - B39) Dragon ICS V3.3.2 [1080p-MP4-SENSE-AROMA]
  • 396 Antworten
Deadboy
Deadboy
Aroma Installer 2.0
(Custom Installation, Choose Which Apps, Modems, Kernels And Other Stuff you want to install)
Based on AOKP (Build 39)
Default AOKP Theme And DragonICS AOKP Theme with extra options (choose in installer)
Build.prop Tweaks
Init.d Tweaks
Tweaks for better scrolling experience
Tweaks for more speed
Tweaks to reduce battery usage
Tweaks for faster 3g and wifi
OTA Updater
1080p MP4 Video Recording
gps.conf edited (world GPS support, Thanks to NeoPhyTe.x360)
Latest Gapps Integrated (29-04-2012)
**Included Kernels**
Extweaks or xxtweaker is found in settings as label depending on installed kernel but only in DragonICS themed version(Extra features!!).
In Stock AOKP themed version you need to download it from the Google Play Store!
Abyss 1.2 Ultimate
Dorimanx 3.4C
Fluxi xx.02-Beta5
N.E.A.K 2.06
Siyah 3.3.2
Thoravukk 3.02
**Included Modems**
XXLPX
XXLPW
XXLPS
XXKI4
**Included Launchers**
Apex Launcher (System Default)
Trebuchet
TouchWiz 5
LG Home 3
**Included Apps**
Adobe Flash Player
GoogleTTS
Google Plus",
Google Maps
Google Drive
Google Currents
Google Car Home
Google Talk
Google Translate
Google Shopper
Google Reader
Google Chrome
Swype Keyboard
Polaris Office
OI FileManager
Solid Explorer
ES Explorer
Fonts Installer
YouTube
Hier sind noch 3 Videos:
Video Stock Themed Version:
[ROM](AOKP) Dragon ICS V3.3.1 - YouTube
Video DragonICS Themed Version:
[ROM](AOKP) Dragon ICS V3.3.2 - YouTube
thanks to Samidu15 for the Youtube video
An Other Vid Of DragonICS Themed Version by PolarWorks
Galaxy S II con Rom DragonICS 3.3.2 ICS 4.0.4 (Review Sub. Español) - YouTube
**ChangeLog Version 3.3.2:**
*LCD Density RomControl Fixed
*Added Themed Gmail To Rom DragonICS Themed Version
*Added Stock Themed Maps to Rom Stock AOKP Themed Version
*Few Other Fixes
*Tested Stock AOKP Theme and everything is good (Proof see youtube vid)(if you have any problems do an full wipe! and try again
**ChangeLog Version 3.3.1:**
AOKP build 39
*Now Full Features AOKP B39
*Siyah 3.3.2
*Fluxi XX0.2b5
*NEAK 2.0.6
*Dorimanx 3.4C
*Added Apollo Music App To Stock AOKP Theme
*Updated Super Video
*Updated FlipBoard
*Updated Solid Explorer
*Updated Dsp Manager
*Changed Play Store 3.5.19 For DragonICS Themed And Stock AOKP Themed
*Some Fixes
*Modded Framework Some Fixes And For More Performance
*And More...
*Now DragonICS & Stock AOKP In One Rom, So it will be just one rom from now on!!
Enjoy
XDA File Server - For all your ANDROID ROMS! /Files/Samsung/Galaxy S II/DragonICS/
Mirror:
Dev-Host - DragonICS_V3.3.2_AOKP.zip - The Ultimate Free File Hosting / File Sharing Service
Full Wipe Recommended If Come From Other Rom!!!
If You Dont Perform Full Wipe It Can Cause Instability And Other Problems.
__________________________________________________ __________________________________________________ _______________________
Questions and Answers::
My microSD card doesn't show up!
The location for the microSD card is /emmc.
Still don't understand.. Follow these instructions:
1. Download Solid File Explorer (Also included in rom, choose when installing rom in aroma installer).
2. There are two ways with Solid Explorer, when open Solid Explorer hit back once (now you are in /mnt). You should see folders such as asec, SD Card, Internal Memory, and secure. When ask give root permission and click on SD Card. now you have access to the files on your SD card.
3. Or with Solid Explorer just press Jump > Device > SdCard
My external SD card doesn't show up when I connect my phone to the computer!
Goto Settings > Storage > Menu > USB computer connection > Choose between Mass Storage And MTP mode.
Or when using Siyah Kernel
Goto Extweaks > Misc > USB Mass Storage Mode > Force MTP Mode
My /sdcard and /emmc are reversed!
If you want to change the storage settings go into: Settings > Storage > Menu > Storage configuration > Select Use Internal Storage > Reboot.
My scrolling is not smooth!
Go to Settings > ROM Control > Performance > Scrolling cache > Force disable > Reboot
The weather shows up as a black box!
Tap on it to trigger a weather refresh, It should show up fine after that.
__________________________________________________ __________________________________________________ _______________________​
IF YOU LIKE MY WORK THEN PLEASE DONATE
------------Thanks for Donation:------------
*Manfred Köning
*Malavan
*Tim Win
*Ho Cheung Li
*Twilight-Zone14
*Yosef Shawahneh
*Folgui
*Tonko H
*Lanyco
*Twilight.Zone14
Quelle: Klick
Die Links sollten alle funktionieren :)
Happy Flashing :thumbsup:
Reaktionen: BlauesIicht, Kuqe_zi, V2Monster und 12 andere
Hab mich schon gewundert dass dieses Rom noch keiner gesehen hat. Habe es seit 3 Tagen im Einsatz und muss sagen wow.
Das schönste AOKP Rom bis jetzt.
Kein FC keine Reboots und keine Freezes. Akku hält wie bei allen anderen, bei Vielbenutzung einen Tag sonst auch länger.
Sent from my GT-I9100 using Tapatalk 2
Reaktionen: sventehf, Bandit und Deadboy
Reaktionen: DarkwingV8 und Bandit
Hey,
die Rom sieht verdammt gut aus meine Frage gibt es hier eine T9-Tastatur???
Weil mag kein QWERTZ oder SWYPE.
Würde mich über eine Antwort freuen.
Viele Grüße
Gerade mal installiert.
Hier in der Rom gibt es nur die Android Tastatur (keine Ahnung ob man die umstellen kann auf die T9 Tastatur) und Swype.
Wäre hier die Samsung Tastatur dabei gewesen (aber aufgrund von Aokp eher unwahrscheinlich), hätte man die Tastatur umstellen können.
Swype ist auch dabei.
Habe ich ja geschrieben und das mag chris264 aber nicht ;)
Selbst habe ich die Version wieder entfernt. Der Medienscanner hat bei mir verrückt gespielt. In der Galerie waren die 3fache Menge von Bilder und Videos drin.
Der Miui FileExlorer hat einen kleinen Farbfehler (zumindest bei mir). Dort wo man die Root Option aktivieren kann, ist die Schrift nicht lesbar. Schwarze Schrift auf schwarzen Hintergrund kommt nicht so gut an.
Vom Style her aber mal was neues. ;)
Sehr geile rom gefällt mir tichtig gut!
Send from Hell
UPDATE ICS V1.7
Features Dragon ICS V1.7:
Based on AOKP (build 31)
Kernel: Siyah V3.0 (Other Kernels are included - SdCard/DragonICS-Addons)CWM
Modem: XXLPS (Other Modems are included - SdCard/DragonICS-Addons)CWM
Build.prop Tweaks
Init.d Tweaks
Apex and Trebuchet Launchers
Miui FileExlorer Modified For AOKP(FTP, GoTo sdcard then options to enable root explorer to gain access to emmc)
MiuiCompass
Google Play Store 3.5.16
Google Gmail 4.05
Google Maps 6.5.0
Google Play Books
Google+ (Updated on 13-04-2012 to latest version)
Google Streetview
Google Car Home
Google Music
Polaris Office
Voltage Control
ExTweaks (Siyah Kernel Only)
CpuSpy
Youtube
DSP Manager
Facebook
Swype Integrated
SGS2 Settings
And more..
Full wipe Recommend!!
format data/Factory reset
wipe cache
wipe dalvik
format system
External_SD Fix
(For mounting external_sd: After installation rom goto settings/rom settings/start-up tweaks,
allow root permission then select wanted start-up tweaks and reboot phone thats it)
When Connecting phone to computer use UMS1.0(SdCard/DragonICS Addons)
Internal & External Sd Mounted
Tweaks for better performance and stability
fixed some bugs
Siyah Kernel 3.1rc2
Gps Fix
Integrated SGS2 Setting into Settings Menu
Blue Phase Theme done for 99% (Very Nice)
Themed Apps (Thanks to el_liberator for some drawables)
Updated & Themed Google+
And more...
Downloadlink:
Dragon_ICS_AOKP_V1.7.zip | PutLocker
Reaktionen: HSV-Freak, Deadboy, Aleks9007 und eine weitere Person
Hab grade mal den Startpost aktualisiert :)
Eine geniale Rom muß ich sagen.Allerdings frage ich mich wo der Zeichenzähler für die sms geblieben ist.Gibts den generell nicht mehr unter ICS?Ich hatte vorher 2.3.5 und da gab es diesen Zähler noch.Ich hab jedenfalls nichts dazu gefunden und werde sonst wieder auf HAndcent umsteigen.
Die werde ich mir diese Nacht mal flashen, bin mal gespannt.
Meine erste AOKP:drool:
Das ROM ist wirklich genial... auch die Optik ist mal was erfrischend anderes. Nur die Toggles sind ein paar zu wenig... gerade das man die Datenverbindung nicht de-/aktivieren kann ist etwas nervig aber sonst sehr gelungen
Ist das der original Thread oder ist das ROM von woanders?
Das ist eine Kopie, der original thread steht bei der quelle unter dem Zitat :)
würde mir das rom auch gern mal testweise flashen. bevor ich das jedoch tue, würde mich mal der unterschied zwischen einem aosp rom und nem aokp rom interessieren? irgendwie steig ich da nicht so durch. ich stelle die frage absichtlich hier, weil mir mir in diesem thread erstmals aokp-rom auffiel. sonst ist ja fast immer von aosp roms die rede.
gruss farid
edit: hab unter http://www.droidwiki.de/AOSP dann doch eine erklärung gefunden, jetzt weiss ich mehr.
Also ich habe jetzt von einigen gehört die das update bekommen haben das es wie vorher auch einen sms zeichenzähler gibt und in einem Video hier hab ich auch gesehen das der Zähler vorhanden ist.Wäre also echt super wenn man das in diese Rom auch einbauen könnte.Ansonsten hab ich mit dieser Rom nach wie vor keine probleme festgestellt.Alles läuft rund soweit und der Akku hält auch sich auch ganz wacker.
Die 1.8 ist bald online.
Dragon ICS AOKP V1.8 Within a few hours
Features Dragon ICS V1.8:
Based on AOKP (build 32)
Kernel: Siyah V3.1rc5 (Other Kernels are included - SdCard/DragonICS-Addons)CWM
Build.prop Tweaks
Init.d Tweaks
MiuiCompass
Google Gmail 4.05
Google Maps 6.5.0
Google Play Books
Google Streetview
Google Car Home
Google Music
Polaris Office
Voltage Control
CpuSpy
Youtube
DSP Manager
Facebook
Swype Integrated
SGS2 Settings
And more..
wipe cache
wipe dalvik
format system
Changelog..
AOKP Build 32 (Changelog here: http://forum.aokp.co/page/news
Siyah Kernel V3.1rc5
New Camera ( We can now save to external SD - 1080p video recording)
External Sd Fixed (albums are no longer listed twice in the gallery)
Turning on external_sd after installing rom: goto RomControl/Start-up tweaks and grant permission when superuser ask's for it..
and enable start-up tweaks then Restart Phone. done
added aVast mobile security (removable)
some bug fixes & tweaks
added latest siyah v3.1rc5 , Neak 2.0.2, Thoravuxx 2.25, Stock Kernel CM9 3.0.28 to sdcard/DragonICS Addons/Kernels
added FM Radio To sdcard/DragonICS Addons/FmRadio
and more
Rom is tested from yesterday afternoon till now and i got good reports from my testers..
this is what they say about Dragon ICS V1.8:
Very fast and stable rom.
camera works very good
battery friendy..
and more
