[ROM][OMNI][4.4.2] Dirty Unicorns - Galaxysmtd v5.0 [Team D.I.R.T]
  • 22 Antworten
Blade Runner
Enthusiast
11.627
Rom Features:
  • Facebook Sync Hack
  • PDroid patches included
  • Immersive mode
  • Hot Reboot Option
  • Appbar (ribbons)
  • Customizable Quick Settings
  • Customizable power menu
  • Customizable lockscreen shortcuts
  • App Ops access in Settings
  • TRDS (built in theme in settings)
  • Statusbar Clock options
  • NavBar Options
  • Halo from Paranoidandroid
  • Halo size changer
  • Hardware key remap mod
  • Battery Bar / Circle batteries
  • Network speed indicators in statusbar
  • Koush Superuser
  • Build.prop mods
  • Init.d Tweaks
  • Active Display (Moto X notifications)
  • ListView Animations
  • Custom System Animations
  • Custom BusyDialog
  • Advanced Low Battery Indicator options
  • ScreenShot QuickTrash
  • Color Changing PhaseBeam
  • Gesture Anywhere
  • Button Light Notification
  • Much More, just look in Settings/Dirty Tweaks and ENJOY!!!
Bekannte Fehler:
  • Same Omni's bugs
  • Can't move app to SD with a specific app (Titanium Backup i.e.)
  • Recovery can't flash from emmc
Change Log:
Initial Kit Kat release (24/01/2014)
  • it may have some bugs
du_galaxysmtd_20140125-1626.zip
  • ScreenRecorder fixed
du_galaxysmtd_20140129-2341.zip
  • DU's code updated
  • DSP/Apollo fc's fixed
  • aries: using busybox from sbin (twrp built)
  • aries: fix error during init recovery
  • Put the secondary keyboard in
du_galaxysmtd_20140215-1213.zip
  • Fixed Buttons remapping (now you'll have "Kill app button" too and more)
  • Custom bar header
  • Check DU's github for more informations.
P.S.: NavBar will be included in next build, I did a test with this build, but it doesn't work due to its dimension for our HDPI device (forgot to revert it)
du_galaxysmtd_20140218-1354.zip
  • NavBar in DirtyTweaks
  • Fix keyguard forma SIM card pin
  • Toggle to enable/disabile HighEndGfx
  • For more info read DU's Github
du_galaxysmtd_20140228-1750.zip
  • Changed contextual notification panel headers …
  • Lockscreen custom wallpaper
  • Custom Progress Bar
  • NavBar ring customizations
  • New DU easter egg
  • Suspend Actions
  • Recents: Google Recents
  • Disable Camera shutter sound
  • Double tap to sleep
  • DarkUI recents background
  • For a more technical and complete changelog visit Gerrit Code Review
du_galaxysmtd_20140308-0109.zip
du_galaxysmtd_20140314-0828.zip
du_galaxysmtd_20140324-0835
  • Improvements to custom status bar
  • Fix statusbar/center clock icon showing up without any notifications
  • Hide Signal Bars
  • Change notification background from holo to kitkat grey
  • SystemUI: Cleanup and enhance notification drawer header
  • App sidebar: some adjustments
  • Camera button support
  • Fix bug with non-secure gesture lockscreen
  • Smart Phone Call
  • On The Go Mode
  • Enable/Disable Profiles in power menu
and many more... please visit https://github.com/DirtyUnicorns-KitKat for more
Rom Link und Gapps Link
Download
GApps
Version Information
Status: Beta
Reaktionen: tobiasth, ted27 und wolder
Danke!
Dann Berichte mal.
Wie läuft sie?
gesendet von meiner Rüttelplatte
Ich habe jetzt noch nicht viel probiert. Dazu bietet die Rom einfach zu viele Spielerein :)
Installation war recht einfach. Ich habe sie versehentlich einfach über die Mackay-Omni Rom drüber gebügetl.
So bieleb also alles Setting meiner Programm erhalten.
Was zuerst auffällt. Die Rom läuft auf meinem Galaxy noch eine Ecke flotter als die Mackay-Omni.
Die Menus reagieren ohne merklich Verzögerungen. Apps starten auch schneller als wie bei der Mackay-Omni.
Bluetooth und GPS habe ich noch nicht getestet. Zu Akkulaufzeit kann ich noch nichts sagen.
Was mir aufgefallen ist bis jetzt.
  • In den Sicherheitseinstellungen fehlt ebenfalls die Blacklist.
  • Im Recovery ist die externe SD ebenfalls nicht ansprechbar.
  • Auf dem Sperrbildschirm fehlen diese Ribbons/Kacheln die es bei der Mackay hatte wenn z.b. eine Mail oder SMS kam oder ein verpasster Anruf war.
  • Bei eingehendem Anruf dauert es sehr lange bis angezeigt wird wer anruft.
UPDATE:
  • Wenm man unter Systemeinstellungen -> Einstellungen -> Standort auf "Ja" stellt erscheint im Tray das Bluetooth Icon.
  • Bluetoothverbindung mit meinem Pioneer AVH-2400BT klappt.
  • Navigation mit Google Maps funktioniert wie schon vorher bei mir nicht. Standort ist ein, Ziele sind gewählt und Navigation gestartet und ich fahr los.
  • Und es tut sich nichts am Bildschirm. Bildschirm bleibt am Startpunkt hängen. Der Strecke wird nicht gefolgt. Ich weis nicht ob das Problem meines Handy, von Maps oder KK an sich ist.
  • Grade nach einem Anruf hat sich das Galaxy beim beenden des Gesprächs neu gestartet.
Ich werde wohl mal in den sauren Apfel beisen und heute abend wenn die Zeit reicht das Handy sauber neu flashen.
Reaktionen: Xavier84 und wolder
Heute nacht habe ich die ROM noch mal neu geflasht um sicher zu sein das nicht Reste der alten Rom stören.
Und so siehts nun aus:
  • In den Sicherheitseinstellungen fehlt die Blacklist -> Rom spezifisch
  • Auf dem Sperrbildschirm fehlen diese Ribbons/Kacheln die es bei der Mackay hatte wenn z.b. eine Mail oder SMS kam oder ein verpasster Anruf war -> ROM spezifisch
  • Navigation mit Maps funktioniert jetzt. Aber etwas hakelig.
  • Rom regaiert in den Menues und meisten Anwendungen nach wie vor sehr flüssig. Maps aber ist z.b. ist nach wie vor recht gemächlich. K9-Mail z.B. etwas flotter als unter der Mackay
  • Externe SD im Recovery nicht verfügbar
  • Wenn man über die Schnelleinstellung GPS (Standort) aktivert und anschließend unter Systemeinstellungen -> Einstellungen -> Standort nachschaut ist GPS (Standort) aber noch aus. Erst wenn man hier auf "An" schaltet ist GPS (Standort) aktiv. Das könnte das Problem mit der Navigation in Maps erklären (Und evtl auch bei anderen KK Roms so sein. Muß ich beim nächsten Wechsel mal drauf achten)
  • Wenm man unter Systemeinstellungen -> Einstellungen -> Standort auf "Aus" stellt ist GPS (Standort) auch in den Schnelleinstellungen aus.
  • Wenn man den Slider mit den Infos nach unten zieht läßt sich der nicht mit der Zurück Taste schließen. Man muß ihn zum schließen nach oben schieben.
  • PowerAMP Full Version Unlocker läßt sich nicht installieren. Kann nicht auf den USB-Speicher bzw. der SD-Karte zugreifen
Mehr habe ich noch nicht probiert und mich erst mal auf die Punkte konzentriert die mir schon gestern aufgefallen sind.
Seit wohl schon gestern gibs eine neue Version:
Goo.im Downloads - Downloading du_galaxysmtd_20140129-2341.zip
Schau mer mal ob da ausser den offiziellen Changes nach evtl. noch der eine oder andere Punkt wie z.B. GPS gefixed wurde :)
Update:
  • Keine Änderung bis auf das ein und auschalten von GPS. Das läßt sich nun auch nicht mehr über die Schnelleinstellungen deaktivieren.
  • --> Grad gesehen. Für GPS gibts noch einen eigenen Button in den Schnelleinstellungen. Damit läßt sich zumindest GPS aktivieren. Der GPS Button hat aber keinen Einfluß auf den Standort.
  • Die Appbar funktioniert bei mir nicht. Solange ich in den Einstellungen für die Appbar bin wird sie angezeigt und ich kann die darin abgelegten Apps starten. Schließe ich die Einstellungen schließt sich auch die Appbar.
  • PowerAMP Full Version Unlocker läßt sich nach wie vor nicht installieren weil es nicht auf den Speicher zugreifen kann.
Update 2:
  • Die Appbar funktioniert doch. Allerdings war dazu wohl bei mir ein Neustart des Gerätes nötig.
  • OsmAnd+ kann nicht auf die externe SD zugreifen weil es mit der Ordnerstruktur nicht zurecht kommt. Screenshot habe ich angehängt. Verlinken geht nicht da ich hier keinen Zugriff auf Abload habe.
  • MapFactor Navigator kann ebenfalls nicht auf die externe Karte zugreifen. Ich kann den Speicherplatz nicht frei wählen bzw wird mir die externe Karte gar nicht angeboten sondern die Kartendownloads landen direkt auf der internen. Schlecht bei 3,4 Gig Datenmaterial für Europa
To be continued ...
Update 3:
  • In OsmAnd+ läßt sich der Speicherplatz doch frei wählen. Unter den Einstellungen gibt es einen Punkt wo man den Pfad "zusätzlich" per Hand eingeben kann. Dann erscheint auch in der Auswahl.
  • Heut früh beim Kartenupdate. Handy hat nicht mehr richtig reagiert als ich die Infoleiste runterziehen wollte, ist eingefroren und hat einen Reset hingelegt
Ich find die Rom echt schnell und hat mir persönlich zu viele Einstellungen.
Wer soll denn da noch durchblicken?:confused:
Ich finde sie schneller als die alte Mackay Omni Rom. Die neue ist auch wieder schneller. Ich denke nicht dass sich da viel tut.
Leider hatte ich auch schon 2 Neustarts.
Jetzt bin ich erstmal wieder bei der Mackay gelandet.
Die läuft schnell und stabil.
gesendet von meinem I9000 mit KitKat
Jepp. Geht mir genauso.
Ich werde die Tage wohl auch wieder zur Mackay OMNI zurück gehen.
Update 4:
  • Jetzt grad im Recovery wie ich wieder die Mackay flashen will bemerke ich das die externe Karte erkannt wird. Warum sie vorher nicht erkannt wurde? Keine Ahnung.
  • Heute Mittag wollte ich telefonieren. Ich tippe auf die Kontakte... das Galaxy freezed und rebootet kurz darauf von allein.
Das war der 3. Freeze mit anschließendem Reboot. Deswegen geh ich erst mal wieder zurück zur OMNI Mackay.
@Blade Runner
Bitte Post 1 gem. [OFFURL]https://www.android-hilfe.de/samsung-allgemein/527852-team-info-vorgaben-tipps-zur-gestaltung-von-rom-threads.html[/OFFURL]
überarbeiten.
Genau deswegen wollte ich keinen thread aufmachen.
Bin zur Zeit nur mit dem Handy unterwegs und dann wird das echt schwierig. ;)
Habe diesen ROM nun auch auf meinem i9000. Ich muss schon sagen, für die vielen Funktionen, die dieser ROM mitbringt, läuft er echt fluffig.
Bleibt erstmal drauf!
Grüße
Ich habe die ROM auch wieder mal installiert.
Navigation funktioniert immer noch nicht. Es bleibt beim Standbild. Als Verbindung wurde H mit Vollauschlag angezeigt
Telefon App ist abgestürzt wie ich telefonieren wollte.
Akku Verbrauch ist momentan stärker als sonst. 9 Stunden und der Akku ist komplett leer.
Meine Galaxy reagiert auch ungewöhnlich träge. Da war die alte Version wesentlich besser
In Mapfactor Navigator kann ich die Karten nicht auf die externe SDKarte verschieben. Navigator sagt das anscheinend nur eine SDKarte vorhanden ist.
Möglich das das auch bei anderen KK Roms so ist. KAnn ich erst heute abend testen wenn ich wieder wechsel.
Dann Versuch doch vorher nochmal die neue unicorns.
Ist gerade hoch geladen worden.
Nö. Immer noch träger.
Und Mapfactor findet die externe SD noch immer nicht.
Reaktionen: wolder
Ich hab sie mal installiert.
Läuft im Moment ganz gut, sehr flüssig und viele gute Einstellmöglichkeiten.
Mal abwarten wie sie sich weiterhin verhällt.
Das einzige was mich persönlich stört ist dieses dumme + Symbol in der Symbolleiste, was auftaucht, wenn die Uhr und Datum in der Mitte steht.
Ist das auf rechts eingestellt, dann ist das weg.
Aber damit kann ich leben.
Gruß wolder
