kingoftf
Ehrenmitglied
- 50.144
Lucianno hat es endlich geschafft, die langersehnte V5 der MIUI aufs i9000 zu portieren.
[ROM]MIUIv5.JB.i9000.3.3.29.Multi 4.1.2 SGS [02/04/2013] - xda-developers
Changelog gegenüber der alten Version:
Kernel Semaphore 2.6.6s
update miui 3.4.12
Added MultiLanguage
Added apn
added Miui Keyboard
added semaphore manager
Whatsapp full working
INSTALLATION FROM GALAXY S ROM STOCK:
Root your device and install ClockworkMod Recovery
Or Using ODIN flash CF-Root for you firmware.
Reboot into Recovery using 3-button-combo (VolumeUp+Home+Power)
Do a Nandroid Backup or your choice backup application
wipe data factory reset, wipe cache partition and dalvikcache
Install ROM from internal sdcard
It will restart and continue looping remove battery
Go back to recovery (VolumeUp+Home+Power)
Install rom from internal sdcard
reboot
Finish
INSTALLATION - CM7 OR ANY ROM ICS :
Copy the rom on internal sdcard
do all wipe (wipe data factory reset, wipe cache partiotion, wipe dalvikcacke)
Go on install zip from sdcard
Select the zip and install
Reboot and wait a few minutes
reboot
You have finished
DOWNLOAD
https://hotfile.com/dl/201263228/bbe2093/MIUIv5.I9000.JB.3.3.30.Multi.zip.html
Gapps sind nicht enthalten, nur der PlayStore
Man nehme diese hier, offiziell:
Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip
Screenshots der V5
Sind die von der Stock V5, nicht die von Lucianno, allerdings unterscheidet sich das wohl absolut nicht.
MIUI V5 Screenshots - News - MIUI Official English Site - Redefining Android
CREDITS:
MIUI Italia*
miuiandroid.com
Rtfpessosa For your script
Stratosk (For Semaphore Kernel)
kasper_h (For Mackay Kernel)
Teamhacksung
update miui 3.4.12
Added MultiLanguage
Added apn
added Miui Keyboard
reboot
Finish
reboot
You have finished
DOWNLOAD
Screenshots der V5
CREDITS:
MIUI Italia*
miuiandroid.com
Teamhacksung
