wolder
Philosoph
- 3.861
Android KK 4.4 Makay ROM von kasper_h basierend auf den CyanogenMod Sourcen.
Originalthread: [KK 4.4][ROM]Mackay ROM 4.0.1 (16-Nov-2013) ALPHA! - xda-developers
The ROM is based on Cyanogen sources with the following changes:
-Mackay Kernel:
-Set of cherries picked from gerrit (differing by the day)
-Some additional patches I did myself to the source code
Feature request are OK, but remember:
1. I try to stay close to stock
2. I will not include additional apps, unless they can be build from source
3. The time I spend on features depends on how much I like them myself
Coming from stock Samsung ROM/CM7:
-The safest way is to flash CM9 first and then flash Mackay ROM. Going directly from Samsung ROM/CM7 to Mackay ROM may lead to loosing IMEI.
Fresh install:
Can be flashed on top of any CyanogenMod build:
-Do a factory reset
-Flash ROM
-Flash gapps
-Reboot your phone
If you get an error (like metadata or anything), do the following:
-Download omni-4.4-kernel_selinux.zip from:
xdafileserver - for your daily dosis rom!
-Flash this kernel from you current recovery
-Choose reboot recovery (this should bring you to a blue-colored TWRP)
-Continue with the steps above
Update:
-Flash ROM
-Reboot your phone
(no wipes or other things needed, just flash & reboot)
Downloads:
XDAfileserver
Rootaxbox
Version Information
Status: Beta
Edit: Aktueller OpenPdroid-Patch mit angehängt
-Mackay Kernel:
Changelog of 4.2.3 - 17-Feb-2014
-CM11.0 codebase of 17-Feb
-New kernel (no more CMA, improvements to zram & ksm)
-Enabled KSM by default
Fresh install:
-Do a factory reset
-Flash ROM
-Flash gapps
-Reboot your phone
Update:
-Flash ROM
-Reboot your phone
Downloads:
XDAfileserver
Rootaxbox
Version Information
Status: Beta
