Muppi
Enthusiast
- 2.808
Android JB 4.3 Makay ROM von kasper_h basierend auf den CyanogenMod Sourcen.
Changelog
Changelog of 3.3.1 - 02-Oct-2013
-Updated CM10.2 codebase to 3-Oct
-Fixed the Settings>buttons FC
-Fixed translation error in Mackay Settings
-Removed reboottocwm.zip script as kernel is TWRP-only
-Added option for delayed SMS sending
Please read carefully, otherwise you will loose your data
When coming from Mackay ROM 3.0.0-3.0.5 or from a CM10.1 before 16 August, your device will be repartitioned!
The latest Mackay ROM will repartition your device, enlarging /system (+200MB) at the cost of /data (-200MB). To keep your data/apps/settings, follow the steps below:
CWM:
-make a nandroid backup
-flash ROM
-you will see an error
-flash ROM a second time, this time it will succeed
-flash gapps
-backup&restore -> advanced restore -> restore data of your latest backup
-flash ROM
-flash gapps
TWRP:
-make a backup
-flash ROM
-flash gapps
-restore -> select latest backup -> only select data (I saw an error that /data couldn't be mounted after flashing ROM/gapps, so I rebooted TWRP in between the flash & restore steps, but I think this is not necessary - the message was still there but harmless)
-make a backup
-flash ROM
-flash gapps
This way, you don't loose anything. The data restore won't affect partition size. Next updates will be normal updates again: a simple flash & reboot
Full changelog of 3.3.1 compared to stock CM10.2:
CM10.2 sources of 03-Oct-2013
Installation:
Coming from stock Samsung ROM/CM7:
-The safest way is to flash CM9 first and then flash Mackay ROM. Going directly from Samsung ROM/CM7 to Mackay ROM may lead to loosing IMEI.
Fresh install:
Can be flashed on top of any CyanogenMod build:
-Do a factory reset
-Flash ROM
-Flash a gapps packages of choice
-Reboot your phone
-Do a factory reset
-Flash ROM
-Reboot your phone
Update:
-Flash ROM
-Reboot your phone
(no wipes or other things needed, just flash & reboot)
-Flash ROM
-Reboot your phone
-Custom kernels can be used only if specific for JB4.3
-Mackay kernel 0.507: http://forum.xda-developers.com/show....php?t=2397502
-Christopher86's cortex-A8 optimized Linaro toolchain (September version)
-O3 optimization
-updated to linux kernel version 3.0.97
-SLQB memory allocator (default, should be slightly faster)
-XZ compression of kernel & initramfs
-395MB RAM
-SIO scheduler
-Added Lagfree governor
-ROW scheduler (tweaked, default scheduler)
-FIOPS scheduler (tweaked)
-395MB RAM
-many improvements to IO schedulers in general
-Deadline tuning (thanks to DerTeufel)
-Ondemand tuned (updated based on code of stratosk)
-SmartassV2 governor
-Interactive governor (updated to android 3.4 code + fixes)
-Wheatley & Lulzactive governors
-Conservative tuned
-Call volume hack (use Settings>Mackay Settings* to set volumes)
-Reduced battery polling interval
-Fast charge (activate through Settings>Advanced Settings* or the QuickCharge toggle in MackayROM)
-WiFi PM_FAST mode selection (activate using Settings>Mackay Settings*)
-Battery life extender (set through Settings>Mackay Settings*)
-CustomVoltage (set using NSTools)
-USB OTG support (needs external power supply)
-1100-1400MHz OC steps
-Custom kernel splash (Thanks to Malcho)
-Updated charging logo to match open charger
-Disabled swap & zram
-Improve memcopy/memmove
-Improve the performance of memcpy and memmove
-Kill task closest in size to memory needed to free
-LOAD_FREQ (4*HZ+61) avoids loadavg Moire
-Entropy tweaks: Russell: Sources of Randomness for Userspace [LWN.net]
-backport CPUIDLE from 3.5
-arm/crypto: Add optimized AES and SHA1 routines
-Unaligned CPU access
-Improvements to RWSEM code
-Improvements to binder code
-Improvements to tmpfs
-Added frandom (much faster random number generator)
-Updated to lowmemorykiller with PID whitelist (thanks to stratosk)
-Many parts of the code build as module to reduce effective kernel size
-Updated wifi driver to 5.90.195.114
-Updated GPU driver to DDK 1.8@2198402
-Proportional Rate Reduction for TCP
-Introduce timer slack controller
ROM comes with stock colour. Version with voodoo colour can be downloaded from:
rootaxbox.no-ip.org - /kasper_h/kernels/JB43/
-O3 optimization
-395MB RAM
-SIO scheduler
-395MB RAM
-Conservative tuned
Kernel for switching internal & external SD
Because vold.fstab is no longer used and has been integrated in fstab.aries (which can only be changed before compiling the kernel, as it ends up in the ramdisk), I made a special kernel version with switched SD cards:
http://rootaxbox.no-ip.org/kasper_h/...JB43/switchSD/
*Available through Settings>Mackay Settings
CWM:
-Clear NSTools settings
-Clear init.d settings
-Show battery status in recovery
-Aroma FileManager
-Include using soft keys to navigate the menu (thanks fishears for the idea)
-Enable holding keys for repeated presses
-Themed orange
TWRP:
-Themed orange
-Run recovery-apps (zip files should be present in /system/mackay, launch them through advanced->run app)
-Build in a script to reboot from twrp to cwm*
*To use this feature from TWRP, tap advanced>run app>rebootcwm.zip. Then from the homescreen choose: reboot>recovery
Added apps:
-AngryGPS
Removed apps:
-VideoEditor & demo VideoFiles
vendor/cm:
-Adapt for custom MackayROM building (bootanimation, ROM&file name)
-Custom bootanimation (Thanks to Malcho)
vendor/samsung:
-Added scripts for Mackay Settings
-Added AROMA FileManager
-Revert GPS blobs to CM10.1
device/samsung/aries-common:
-Sets app-close to 1000 ms
hardware/samsung:
-F4k 720p patch for bigmem kernels
AriesParts (Mackay Settings in Settings menu):
Add mackay kernel settings options:
> WiFi PM mode selection
> BLX settings
> BLN activation
> Navbar selection
> Processor settings (governor/frequencies)
> IO scheduler
> Recovery selection
frameworks/base:
Changed USB page icon from Android to Cid
Set QS panel opening to outer 15% of statusbar
FastCharge toggle for QuickSettings/Powerwidget
RAM bar
SystemUI: Option to display Quick Settings when there are no ongoing notifications
FastCharge Tile & PowerWidget button
Call breath & MMS option
Battery bar
Active display
Mms:
Breathing notification
Phone:
Transparent incoming call screen
Settings:
Disable on/off toggle button for profiles on Settings main page
RAM bar
Added option to always pull down quick settings
Battery bar
Active display
Google Apps
Goo.im Downloads - Browsing gapps
