[Rom][JB][4.3][CM10.2] crDroid AOSP [Build15 - 13/09/13][I9000]
  • 0 Antworten
ted27
ted27
21
..:: crDroid AOSP ::..
Zum originalen (englischsprachigen) Thread geht's -
hier
Features ::..
  • App ops (Google secutity management);
  • SELinux security by CyanogenMod;
  • Privacy Guard + Privacy Guard manager by CyanogenMod;
  • Per-user configuration by CyanogenMod;
  • Normal or Center Clock Mod with possibility to change color;
  • Custom Data formats in Status (day, month and year);
  • Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
  • Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
  • Turn screen on when plug/unplug the USB cable as an option in settings;
  • Reboot Menu Enable by default;
  • Brightness control sliding through status bar;
  • Custom Carrier Label;
  • Enable Dual Panel in Settings (Needs Reboot);
  • crDroid Version Build in Settings;
  • PIE Control Transparency and Custom Colors;
  • Status Bar Transparency and Custom Colors;
  • Status bar network speed indicator with option to custom colors;
  • Option to auto hide network speed indicator when there is no traffic;
  • Status bar quick peek;
  • Notification drawer + Notification row Transparency, custom Colors and custom image;
  • Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors; -> Read Here!!!
  • Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
  • Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
  • Lockscreen based on gestures from ChameleonOS;
  • HALO 2.0 by ParanoidAndroid;
  • BlackUI (Black Droid), TRDS from Slim Roms;
  • App sidebar;
  • LCD density changer;
  • Option to enable notifications light even with screen on; *
  • Option to enable Brightness Slider in Expanded Status Bar;
  • Reboot / Reboot Recovery Tile;
  • Reboot / Reboot Recovery in Power Widgets;
  • Camera Tile;
  • Option to enable lock screen rotation;
  • Option to hide status bar (Off, Non-permanent only and All notifications);
  • Quick settings pulldown (Off, Non-permanent only and All notifications);
  • More information on reboot messages;
  • RAM bar;
  • NFC polling mode;
  • Disable fullscreen keyboard;
  • Screenshot quick trash;
  • Permission management;
  • Open tiles in floating window;
  • QS tile fast charge;
  • Powerwidget toggle fast charge;
  • Speed up statusbar / notification drawer;
  • Alternate default app picker;
  • Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
  • Floating window from notification drawer (Long press);
  • Option to show Wifi name in notification drawer;
  • Option to flip tiles in simple press;
  • Listview Animation;
  • Listview Interpolator;
..:: Installation ::..
kommend von einer anderen Rom
- Make sure you're running a proper working ClockworkMod-Recovery
- Boot into Recovery
- DO A DATA WIPE / FACTORY RESET (otherwise your device will be stuck at boot)
- Wipe cache and dalvik cache
- Flash cDroid zip from internal SDCard
- Flash GApps zip from internal SDCard
- Reboot
- Don't restore system data using Titanium Backup!
- Restoring Apps + Data might cause problems and is not recommended, avoid it if possible!
Upgrading einer älteren Version von crDroid
- Copy cDroid ZIP to your internal SDCard
- Reboot
..:: Changelog ::..
Build 24 - 12.10.13
- Active display: Only fetch next notification if mNotification is null;
- Active display: Don't show active display if call state is not idle;
- Add never sleep screen mode (From Slim Roms);
- Privacy guard: changes part 1 (From Slim Roms) - To access App ops just long press any app in Privacy guard;
- Traffic meter: small clean up (Frameworks);
- Traffic meter: reorganization (Settings);
- Traffic meter: selectable summary timeout (thanks @Der_Schubi);
- Updated with CyanogenMod commits;
Build 23 - 05.10.13
- Media Scanner behavior on boot;
- Active display: Catch NPE;
- Active display: Next try to fix "turn off display if device gets pocket again;
- Revert "Active display: Make GlowPadView center the current notification icon for us;
- Active display: Use a default notification icon;
- Active display: Enable proximity sensor only when screen is off;
- Active display: Add some log output ;
- Active display: Fix screen turning back on directly after turning it off;
- Partial rewrite of traffic indicator ;
- Updated with CyanogenMod sources (not new CAF merges!);
Build 22 - 03.10.13
- Notification drawer shortcuts (app, activity, direct call and many more);
- Updated with CyanogenMod commits (A lot!);
..:: Download ::..
crDroid - Build 15
crDroid - Build 24
..:: Screenshots ::..
