wohak
Dauer-User
- 697
...und ich habe zusätzlich noch die Interne "gesäubert" (fast formatiert), damit mir da keine "Reste" irgendwie reinbatzen. Schaun 'mer mal.
Changelog
Frameworks: Clean up trigger code
Frameworks: Fix lockscreen bottom trigger on expanded desktop
Frameworks: Completely revamp and fix transparency mode for navbar/statusbar
Frameworks: Rework navbar/status bar color handling
Frameworks: Simply custom lockscreen background code
Frameworks: Move complete KeyEvents into SlimActions
Frameworks: Bring navring/pie/navbar vibrate/sound inline with AOSP
Frameworks: Add accessibility events to navbar/pie/navring
Frameworks: Add expanded desktop to SlimActions
Frameworks: Add power menu to SlimActions
Frameworks: Add torch to SlimActions
Frameworks: Add DeviceSupportUtils helper class
Frameworks: Fix framework reboot on format of SD card
Frameworks: Hide new non-standard APIs and permissions
Frameworks: Add filter method for supported phone features
Frameworks: Center keyguard shortcuts when only 1 or 2 set
Frameworks/Native: Forward port surface dithering from CM10.1
Frameworks/AV: Audio flinger/LPAPlayer fixes
Frameworks/AV: Featurize QCOM's VOIP feature
Frameworks/AV: Camera fixes
Frameworks/Opt/Telephony: Fix MMS auto-retrieval
Frameworks/Opt/Telephony: Various fixes
Bluetooth: HID: Add support for set idle/get idle commands
Bluetooth: Add trust device feature
Bluedroid: USB: Abort writes if device is absent
Bionic: Merge in CM's bionic
Bionic: Add NEON optiomized memmove
Settings: Fix USB settings tile
Settings: Correct wallpaper custom image size toe new keyguard size
Settings: Add development animation transition mode 0.75
DashClock: Collapsed mode conditions
QCOM: display/audio/media updates and fixes
Major device branch bring-ups and fixes
Add T-Mobile IPV6 APN
Correct Tele2 APN
Add Eastlink Wireless APN
Gapps: Fix Hangouts video call FC
Gapps: Google+ update
Device specific changes
Known issues
Voice dialer is currently broken
Bugreport (Developer options) does not work in 4.3
Device specific issues
Captivate & I9000: Camera FC after unlock of lockscreen
Bödi;6329206 schrieb:Ich warte aufs Nexus 5.
konsumhaus schrieb:Moin.
Ich habe das Problem, dass der Kalender nicht mehr mit Google synchronisiert
Letzter Sync war 23.8..
Liegt das an der Slim oder hat einer eine Idee?
Gesendet von meinem GT-I9000 mit der Android-Hilfe.de App
