[ROM][JB][4.2.2][UNOFFICIAL] ThinkingBridge Stable [22.04]
  • 6 Antworten
Glatzi84
Dauer-User
601
Noch eine Rom von aways​
Hier gehts zu Original Thread auf XDA
Die Rom steht für Maximale Stabilität und hohe Geschwindigkeit. Die Rom basiert auf AOSP und den CyanogenMod Code.​
Funktionen/Changelog
Changelog
+- Add Share ThinkingBridge ROM into DeviceinfoSettings
+- Support Ad-Hoc (IBSS) mode
+- Support new devices
+- Screenshot rotaion
+- Status Bar Network Traffic Indicator
+- Improved SystemUI layout
+- Optimize Low-end devices
+- Hide statusbar clock also for DashClock
+- Update screenshot toggle
+- Remove lag when launching an app
+- Fixed Photosphere/Camera FCs
+- Fixed memory leaks
+- Fixed after change signal type or text color
+- Fixed many bugs
Fully Functional Features:
  • RIL (Calls, data and texts)
  • Wifi
  • Bluetooth
  • Touch UI
  • Contacts
  • Browser
  • Lockscreen
  • Settings
  • Notification drawer and toggles
  • Gallery
  • Quick Toggles
Features Offered By ThinkingBridge ROM
  • ThinkingBridge Welcome App (About the Team, Changelogs & Contacts us)
  • ThinkingBridge Wallpapers App
  • CyanogenMod FileManager
  • DSP Manager
  • Trebuchet Launcher
  • ROM Settings
  • -General UI (Add Custom Boot Animations, Custom Carrier Label, StatusBar Brightness slider, Transparency Settings, UI Mode etc.
    -Power Menu (Select what to show up in Power Menu and other Power Menu settings)
    -Navigation Bar (Enable/Disable NavBar, Add/Remove buttons, change colors, configure widgets etc.)
    -Navigation Ring (Set NavBar Ring targets)
    -Hardware Keys (Enable custom actions and enable 3-dot overflow menu)
    -Pie Controls (Enable/Disable pie, change colors, Trigger Area, Size, Alignment, Gravity etc.)
    -Toggles (Add/Change/Remove toggles, change toggle style etc.)
    -Battery (Change the battery icon on StatusBar, change colors, battery bar etc.)
    -Clock (Change the Clock icon on StatusBar, change colors, AM/PM Style, Alignment, clock actions etc.)
    -Signal (Change Signal icon on StatusBar, change colors, hide Signal bar etc.)
    -Lockscreen (Change lock options, modify widgets, change colors etc.)
    -Custom Shortcuts (Set custom shortcuts to the lockscreen)
    -Custom Targets (Add custom targets to the lockscreen)
    -Lock Clock Widget (Modify/change/remove the clock on the lockscreen)​
    -Sound (Enable volume panel, flip phone settings, headphones and bluetooth headset otpions etc.)
  • Theme Engine Support
  • Parition Info (Information about /System, /data, /cache, /sdcard and EXT partitions)
  • CPU Settings (Change Governor, Min/Max CPU freq., scheduler)
  • Koush's Superuser App
  • New Custom Toggles (Favourite contact, Clock toggle, Fast Charge, Pie, Quick record, Quiet hours, Screenshot, Signal, Sleep, Sound state, USB tether, WiFi tether, Current user)
  • Custom Camera features
Above are the features clearly visible to your eyes but still a full list of Kernel and script optimizations is still not mentioned.
Installation
  1. Wenn du die Rom zum erstenmal flashst (oder von einer anderen Rom kommst): Mache bitte, wipe /data (factory reset) /cache, dalvik-cache and /system
  2. Wenn du diese Rom nur Updatest (eine neue Version der Rom auf eine ale Version der Rom flashst] wipe /cache and dalvik-cache
  3. "Install zip from sdcard" > "choose zip from sdcard" > makier die Rom und flashe
  4. danach genau so die Gapps flashen
  5. wenn du dann fertig bist dann startest du das Handy neu
Downloads
Speicial Thank's to Team BRIDGE:
  1. htchoi5609
  2. woorim98
  3. black9
  4. DJBhardwaj
  5. Akibingbing
  6. Here Is Github
Reaktionen: grinder777 und apex
Reserviert
Erster Eindruck echt schnell und viele Einstellmöglichkeiten! Vllt. genau das was ich für mein s1 gesucht habe :) mfg
Als ich einen Anruf bekommen habe, hat sich das gerät rebootet... Davor blackscreen...steht UA eh noch beta wenn ich mich nicht irre...
Gesendet von meinem Nexus 7 mit der Android-Hilfe.de App
Akku lädt...
werde es heute mal testen und dann hier posten...:)
Thinikingbridge Stable ist da :)
mittlerweile Stable2. Läuft auch bei mir auf dem S2 (i9100).
Ist echt superflüssig und stabil. Mit dem Stable2 kamen noch ein paar Bugfixes.
Allerdings kann ich keine Nandroid Backups mit CWM mehr machen
CWM-based recovery v6.0.3.2
SD Card space free: 13324MB
Backing up boot image ...
Error while backing up boot image!
Der ursprüngliche Beitrag von 14:58 Uhr wurde um 15:01 Uhr ergänzt:
[ROM][Jellybean 4.2.2][JDQ39E] ThinkingBridge ROM [I9100][May 09,2013][Stable 2] - xda-developers
Die Photosphere-App könnten die sich sparen, kann doch auf dem i9000 nie funktionieren wegen fehlender Sensoren.
Und selbst auf meinem mi2 ist das eher ein Gag als sonst was, sehr viele Renderingfehler mit versetzten Rändern und Stufen im Bild.
Und eine gute Qualität des Bildes ist auch nicht feststellbar, eher leicht verschwommen.
Gilt auch für den Quatsch mit HDR auf dem i9000. Da gelingen einem zu 99% nie Fotos, die nicht unscharf sind, weil die Kamera für die 3 Fotos Ewigkeiten braucht, im Prinzip bräuchte man ein Stativ, um einigermaßen akzeptable Resultate mit dem i9000 zu erzielen.
scorp182
SGS-Ultra
SGS-Ultra
kingoftf
Islaris
Islaris
Sattich
