Glatzi84
Dauer-User
- 601
Nightlies
Pac-Rom V22.x.x
Pac-Rom V22.x.x
FATURES
* Linaro Optimized Kernel
* All in One Rom [CM, AOKP and PA]
* PhoneUI * Latest Version 22.x.x
* Some Features from AOKP
* All Feautures from PA
* All Features from CM
* Ofcourse JellyBean 4.2.2
Changelog
-Add keymapping for select BT headsets
-FM Radio: avoid deadlock when disabling RDS
-Only disable pie on lockscreen if lockscreen is secure
-enable usb audio hot plugging
-Enable Ethernet tab in data usage
-Settings: fix incorrect value in autobrightness adjustment
-Adding configurability of frequency cap (min/max) files path.
-LockscreenPattern: Fix toggle dots/error pattern visibility
-Fix the message when Bluetooth is turning off while on the tethering
-Settings: ElectronBeam get some love
-Quick Pulldown, Pulldown settings & hide QuickSettings patch.
-Hide QS Panel Toggle
-Quick Settings Pulldown: Left or Right side option
-Settings: Quick Settings pulldown without notifications
-Add back backlight curve adjustment.
-Wifi: Enable IBSS options only if IBSS is supported
And More
And More
Download
Screenshot
