tobiasth
Philosoph
- 2.559
- Themenstarter
- #821
4.2.2 Build 5 WIP
Ok guys time for a new build WIP. I will like to say apart from great*optimization and addition to Slim Pie we Added a great feature from CM (Voice shutter) we added a great "Hands Free" feature that lets you take picture with the proximity sensor. Also we decided to change our default launcher from Holo HD to Nova. We thought and discussed it for a while and even averaged out memory use in the team and came to the conclusion that Nova suited us better.
Changes and Features
Slim Pie
Added second layer (7 buttons max + longpress)
Faster trigger
Better triggering
Custom trigger height and gravity
Option to mirror right PIE on horizontal axis
Smart capture
Hands free camera
Update Slim IRC to 2.1.6
Added Vibration adjustments to Performance (select devices)
Added & improved more translations
Changed default launcher from Holo to Nova Launcher
Added actions (mark read/reply/delete) to new (stock) Email notifications
LED picker overwork
Added back 0dp navbar values
Rearrangement recents app switcher
Phone: Add blacklist unknown numbers functionality
Contacts: Allow blacklisting numbers from the call stats details menu
SMS/MMS: Overwork
Optimizations to syscore
Optimize again system stability
Device specific
Mako kernel
Updated to linux kernel version version 3.4.42
Upstream Row
Added fiops
D2 kernel
Added wheatley, dancedance, asswax & lulzactive governors
Lowered min freq to 192mhz
Added morfic colors
Added faux sound control
Added USB fastcharge
bcmdhd (wifi) driver from i9505
N7100: Updated linux kernel version 3.0.75
I9100G: Updated linux kernel version 3.0.75
Nozomi: Custom battery LED
i9100: Activated SlimPIE
Fixes
Fixed many translations FC bugs
Fixed pinch to zoom on some devices*
Fix date format DashClock and DeskClock
Recent animation bug
Device hostname setting in Developer options now persists
A lot of smaller fixes
Device specific
D2:*Fixed flickering (for good?)
Nozomi:*Fix unknown chargers does not charge
Known issues
Android Beam doesn't show confirm window
Device specific
Nozomi: HDMI does not work
Cool. Aber ich glaube ich werde diese PIE Funktion trotzdem nie ernsthaft nutzen.kufikugel schrieb:wait for build.5....SlimPIE has now a totally other feeling.....we redid the trigger detection...you will see big big difference to build.4.2Especially for the samsung devices
4.2.2 Build 5
HELLO USERS:
Time for another Slim build. Build 5 is here. We have optimized and enhanced Slim Pie further and added a nice feature from CM (Voice shutter) . Also added a "Hands Free" feature that lets you take picture with the proximity sensor (activate the feature in camera settings and flick you finger above the sensor). We decided to change our default launcher from Holo HD to Nova. We thought and discussed it for a while and even averaged out memory use in the team and came to the conclusion that Nova suited us better.
NOTE: Skyrocket is not ready for build 5 yet.
- Slim Pie
- Added second layer (7 buttons max + longpress)
- Faster/Better triggering
- Custom trigger height and gravity
- Option to mirror right PIE on horizontal axis
- Smart capture
- Hands free camera
- Update Slim IRC to 2.1.6
- Added Vibration adjustments to Performance (select devices)
- Added & improved more translations
- Changed default launcher after extended tests from Holo to Nova Launcher because it uses less RAM.
- Added actions (mark read/reply/delete) to new (stock) Email notifications
- LED picker overwork
- Added back 0dp navbar values
- Rearrangement recents app switcher
- Phone: Add blacklist unknown numbers functionality
- Contacts: Allow blacklisting numbers from the call stats details menu
- SMS/MMS: Overwork
- Optimizations to syscore
- Optimize again system stability
kingjezdi schrieb:was ist das?! kann
AIO_Aroma.4.2.2.build.5 ?![]()
