[ROM][JB][4.2.2] FISHEARS für den iNand With Original Partition Layout 17.02
  • 12 Antworten
Glatzi84
Dauer-User
601
Standing on the shoulders of giants like Pawitp, the CyanogenMod Team and all their contributors, nothing happens unless they do it first.
Diese Rom basiert auf CM10.1 nur der entscheidene Teil an der Rom ist das, dass Originale Partitions Layout von CM10 verwendet wird.
Fishears Kernel Changelog
    • Kernel 3.0.65
    • Live OC
    • Aroma Filemanager (1.80) in Recovery
    • Kernel compiled with Linaro 4.7-2013.01 + O3 optimization
    • RAM Size selectable through Memory Management Settings. 383mb (default), 396mb (bigmem), 409mb (hugemem - breaks 720p video recording so set camera to 480p before reboot)
    • Media libs automatically patched at reboot when RAM Size changes
    • 720p recording option removed from camera settings in hugemem mode (thanks Kagadar)
    • CPU unaligned accesses enabled
    • Deep Idle
    • BLN 9
    • FastCharge
    • Touch Wake
    • Battery Life eXtender
    • Battery polling reduced
    • Smartassv2 governor
    • Lulzactive governor
    • Lazy governor
    • Wheately governor
    • IntelliDemand governor
    • Interactive governor tweaks from 3.4
    • SIO I/O Scheduler (updated)
    • ROW I/O Scheduler
    • BFQ I/O Scheduler
    • ZEN I/O Scheduler
    • tuned CFQ Scheduler
    • Overclock @ 1400, 1300, 1200, 1100
    • LOAD_FREQ (4*HZ+61) avoids loadavg moire
    • Logger from 3.4
    • Lowmemorykiller from 3.5
    • Time gpio from 3.4
    • Battery indicator in Recovery
    • Clear NSTools settings from Recovery
    • Clear init.d from Recovery
    • Touch key control in Recovery (Menu=up, Back=down)
  • Fishears ROM Changelog:
    • Optimized read-ahead values for storage
    • Dual Panel mode
    • Adjustable auto-brightness light levels(Settings->Display->Brightness)
    • External Storage option in Camera
    • Alternative app resolver (one-click selection)
    • Media Device & Camera Device options for USB Connection (Settings->Storage)
    • Add any widget to Lockscreen
    • FastCharge Quick Settings Tile and Power Widget Button
    • Option to always show Quick Settings (if no notifications)
    • CallerID screen transparency
    • Volume Adjust Sound on/off setting
    • In-call volume settings (in Settings > Advanced)
    • Call settings: option to return to last activity on end call
    • Call settings: option to enable landscape rotation
    • Developer settings enabled
    • High-end GFX option
    • Translucent Notification panel (with High-end GFX)
    • Status bar date on 2 lines
    • Battery bar
    • Advanced statusbar clock/date settings
    • Recents RAM Bar with settings
    • Home to unlock option for Lockscreen
    • NSTools included for advanced kernel settings
    • Goo Manager included for OTA ROM updates
  • Installtionsanweisung
wenn man von einer anderen kommt die nicht auf CM 10 basiert, muss ein Full Wipe gemacht werden da das Partitions layout gewechselt wird. Zusätzlich sollte man unbedingt System und Data formatieren.
Factory Reset würd ich auch noch machen!
Downloads
Changelog 17/02 (plus Official CyanogenMod Changelog):
Code:
+ Android 4.2.2 upstream fixes+ its faster!
Sollte Rechtlich oder im Sinne der Entwickler, irgendwas nicht in Ordnung sein bitte eine PN an mich, werde es dann schnellstens korregieren. Danke​
Ich oder Android-Hilfe.de sind nicht die Entwickler der Rom, daher flashen auf eigene Gefahr.​
Verbesserungsvorschläge für den Thread, bitte per PN.​
So auf XDA wird berichtet das die Rom soweit super läuft und das diverse Spiele wie Asphalt 7 und MC4 und andere sogar lagfrei laufen sollen...
Frohes neues an alle
Edit: Post 1 angepasst
Gesendet von meinem GT-I9000 mit Tapatalk 2
Reaktionen: beicuxhaven
Wie läuft das hier eigentlich, wenn die Rom das alte Partitionslayout verwendet und man will die Rom wechseln, muss er ja immer wipen, oder? Gibt's da Erfahrungen von jemandem? :)
via SGS
Ja du musst ein Full Wipe durchführen und zusätzlich noch Systen und Data formatieren.
Werde es auch in Post aufschreiben.
Post 1 angepasst + neue Version
Post 1 wieder aktuell :cool2:
Reaktionen: Muppi
"ROM" link ist falsch und gibt's ein Update.
Reaktionen: Glatzi84
Danke hab post 1 wieder aktuell und angepasst
Wer nutzt diese erstklassige ROM?
Niemand?
Warum?
Habe fast alle JB ROM ausprobiert. Diese ist eine der beste ROMs.
Sent from my GT-I9000 using Tapatalk 2
Auf xda gibt es auch viele positive feedbacks zu der Rom...
Da ich leider nur ein movienand habe... Wurde mich das schon interessieren wie der Vergleich zwischen einer Rom ist die auf den inand abgestimmt ist
Der ursprüngliche Beitrag von 18:48 Uhr wurde um 18:49 Uhr ergänzt:
Die Rom wird super supportet auf xda und steht aktualisiert :cool:
Ich habe auch MoviNand und sehe keine Nachteile von der ROM.
Das kann gut sein... Das sie schlechter läuft hmmm glaub ich sehr weniger ... Hatte sie selber auch schon drauf und lief super..
Halt evtl. nennt Vergleich mit nem Inland Modell wäre ja nicht schlecht, ob dann was merkt ... :confused:
Was verstehst Du unter Inland Modell? Ich habe GT-I9000.
kingoftf
Islaris
Islaris
Glatzi84
scorp182
SGS-Ultra
SGS-Ultra
