[ROM][JB][4.2.2] AvatarROM 3.0 Stable (02.07)
  • 55 Antworten
Glatzi84
Dauer-User
601
CM based ROM for Samsung Galaxy S (galaxysmtd)​
Das ist ein Rom die CM10.1 als Basis hat und auf MIUI gethemte ist.​
Also das Pure Minimale gefühl einer CM mit der sehr Coolen Optik von MIUI​
Details
  • Android JB - 4.2.2
  • CM10.1
Changelog
Stable release 3.0 - 07/02/2013
As CM10.1 has hit the general release, Avatar Team is branching with stable and nightly releases.
Stable releases are marked as 3.0. This is the first stable release from Avatar Team. Stable releases will be weekly or bi-weekly and will be tested extensively by our testing team.
Nightly releases will kickstart in a few days. We will merge CM changes every day and it will also contain experiemental features from Avatar.
We highly recommend to wipe cache/data/dalvik before flashing the stable releases.
Changelog:
Based on CM10.1.0 (General Release)
  • The platform for avatarrom is CM10.1. The following components are changed on top CM10.
  • Status Bar
    • Toggles page to contain controls for toggles
    • Fixed memory leaks
  • Theme Chooser
    • Has an online theme server - head here and download cool MIUI converted themes.
    • Changed the layout
    • Added previews
  • Bazooka Launcher (market link)
    • Own launcher which is an enhanced version of Trebuchet (you can download this at the end of this post)
    • Enhanced theming by adding dockbar
    • Preview mode to edit workspaces
  • Messaging App
    • Changed message thread to make them themeable
  • Boot Animation
    • A beautiful boot animation - will be made themeable in upcoming versions
  • Settings
    • Changed statistics to point to Avatar statistics server
    • OTA updater - you can check for updates to Avatar right from your device
    • Changed to support Avatar ROMs
    • Support for Gapps - download latest Gapps package as an OTA update
  • Framework
    • Integrated with ACRA Error Reporter for system wide crashes
  • Lockscreen
    • Changed to make them themeable
    • Support for complex unlock gestures
Installationsanweisung
  • Reboot ins CWM
  • Otional wird ein Nandroid Backup empfohlen
  • Wipe Data/Factory Reset & Wipe cache partition
  • Flash the downloaded .zip file.
  • Install Gapps package.
Download
Stable Release 3.x - Android version 4.2.2 based on CM10.1
Stable 3.0
Beta Release - Android version 4.2.2 based on CM10.1
Link (Jun 16, 2013)
Gapps (4.2.2)http://goo.im/gapps/gapps-jb-20130301-signed.zip
Videos
Credits:
  • Cyanogen Team
  • Trebuchet launcher
  • MiUi Theme creators
Reaktionen: Radagast, Bödi, azubi_biff und 2 andere
Sehr interessant, dass mal jemand diesen Spagat probiert bzw. es sogar schafft, eine funktionierende Rom damit zu bauen. Bin gespannt.
So Rom ist drauf und nach einen 20 Minütigen beschauungs Test in der Pause auf Arbeit... :laugh: erster Eindruck ist echt gut... sehr schön gethemt, bin mal auf die anderen themes gespannt, wenn ich zu hause bin und Internet habe. Bin ja eigentlich ehr minimalistisch, aber bei miui mach ich gerne ein ausnahme den dort gefällts mir.
Einstellungen wie bei CM10, aber bin eh kein fan von so style ala aokp...
Einpaar kleine Einstellungen haben mir zwar gerade gefehlt aber.... :sleep:
So werde morgen mal berichten wie so bis dahin läuft und ob sie bei mir mit der beast mithalten kann :scared:
Die Rom fühlt sich auf jeden fall sehr gut an und irgendwie gemühtlich so wie sie ist :)
Bin wirklich gespannt auf die 4.2.1 Version der Rom... so und das nach 20 Minuten, jetzt muss ich weiter Arbeiten, nicht das ich die ganze zeit hier rum sitze im Büro :flapper:
Mal sehen was bei meinen kleinen Tests so raus kommt...
greetz
Der ursprüngliche Beitrag von 11:24 Uhr wurde um 11:25 Uhr ergänzt:
Einpaar Screens von mir gibts dann auch noch in Post 1, sobald ich ihn Aktuallisiert habe.. (Morgen oder heute Abend)
Reaktionen: Bödi
habe vor einer weile die Avatar Rom 4.1.2 3 Tage genutzt und muss sagen... sehr gute rom
Akku hielt wirklich gut
sehr super gethemte
super smooth und lag frei
antutu spuckt wirklich gut werte raus und das sogar bei einpaar test direkt hintereinander und das mit nur minimalen 20 punkten unterscheid bei 6 antutu läufen :razz:
was nur schade ist das die themes an den bazooka launcher perfekt angepasst sind und bei einen launcher wechsel die themes nicht mehr an allen punkten gleich sind :confused2:
bin somit echt gespannt was sie aus 4.2.2 machen :thumbsup:
im anhang sind paar screenshots...
Reaktionen: Radagast und Bödi
Download Link funktioniert nicht mehr .... :confused:
Ich schätze das die Avatar in 4.2.2 in an Marsch ist :thumbsup:
Das war ja auch so angesagt. Eine gute Stunde haben die Kollegen ja noch - zumindest nach unserer Zeitzone. ;)
Weiß ich jaaaa :razz:
hoffentlich ist sie im upload oder es wird gerade geplant
Das Update ist da. Leider mit einem kleinen Bug, aber damit kann man erstmal leben glaube ich. An einem Fix wird gearbeitet.
bippi79 schrieb:
02/24/2013
  • 50 new themes
  • OTA Fixes
  • Lockscreen fix - time not coming along with unlocker
  • Launcher updated with profiles
  • Weebo app (Tasker like application - Beta). Currently supported only in 4.1.2.
  • Latest merge with CM code base
  • Bug fixes, Performace improvements and many more
Issues: (only in 4.2.2)
When lockscreen is set to slide and if the phone goes to landscape mode, the graphics are distorted and sometimes phone cannot be unlocked. We are working on the FIX.
Work around
1. If the issue occurs, pull down the statusbar, go to settings and you will have access to you phone.
2. Don't set lockscreen to slide and instead choose any other security mechanism.
3. Disable phone rotation.
Reaktionen: DarkAngel1971
Hmm...jetzt werd ich aber doch neugierig auf die Rom
Gleich ist sie fällig...Bin ja mal gespannt.:D
Update is da von Gestern...
weiß nur nicht was :confused2:
Post 1 wurden screens von der 4.2.2 hinzugefügt.
Die Rom läuft soweit sehr gut und schön gethemet auch hier ist wieder alles auf den bazooka abgestimmt.
Hab nichts gefunden was bei mir nicht funktioniert hat, deshalb voll alltagstauglich....
Update vom 02.03 in Post 1 gelistet... :cool2:
Hat schon wer die Rom getestet oder nutzt sie immo und kann auch noch zusätzlich mal einpaar woret zu der Rom schreiben??? :thumbsup:
greetz
Update. :)
bippi79 schrieb:
03/09/2013 - AvatarROM 2.2b Release
  • Latest CM 10.1 code merges (upto Mar 7th 2013)
  • Bug fixes from 2.1b Avatar Release
  • Integrated Weebo
  • Changes to make toggles screen more themeable
  • Chages in Error Reporter to point to new document
If you are using Avatar 2.x there is no need for a wipe on data/cache/dalvik. Download the zip and flash it.
Reaktionen: Glatzi84
Post 1 aktuell
Auch die macher der Avatar Rom schlafen nicht ein und haben heute eine neue Version rausgebracht, zu finden wie immer in Post 1
Neu avatar Rom in der Version 2.5b steht bereit vom 31.03.
Post 1 wird später angepasst, sobald ich zu hause bin vom osteressen... :)
Update auf 2.6b ist da :lol:
Some features of AOKP is on our list but Paranoid ROM features will come before that.
Im nächsten release wahrscheinlich...
Neue Themes verfügbar und das Team will versuchen jede Woche eine neues Theme für die Avatar raus zu bringen... :scared:
Neue Avatar auch hier verfügbar... alles weitere in Post 1
Reaktionen: Wassilis
kingoftf
Islaris
Islaris
Bödi
IronSkyline
I
scorp182
sgs9000A
sgs9000A
