[ROM][JB][4.1][ROM]Mackay ROM 1.9.0 (16.02.2013)
  • 340 Antworten
Glatzi84
Dauer-User
601
Das ist kasper_h's Mackay JB 4.1 Rom​
Basis ist die CM10 mit neuem Partitions-Layout.​
Dazu dann sein selbst entwickelter Kernel und etliche Optionen zur Konfiguration (Navigationsleiste, Batterie usw) und eigene Patches.
Resultat ist eine sehr schnelle und flüssige ROM.​
Kernel findet ihr jetzt auch hier Mackay Kernel
Original-Thread auf XDA:​
Changelog und Download​
Changelog 1.9.0
The ROM is based on CM10 with the following changes:
-Mackay Kernel: http://forum.xda-developers.com/show....php?t=1842324
-Set of cherries picked from gerrit (differing by the day)
-Some handmade patches I did myself to the source code​
Feature request are OK, but remember:
1. I try to stay close to stock
2. I will not include additional apps, unless they can be build from source
3. The time I spend on features depends on how much I like them myself​
Changelog of 1.9.0 compared 1.8.5:
CM10 sources of 16-Feb-2013​
Kernel:
-Updated to linux kernel 3.0.64
-Ported all new features of the JB4.2 kernel (improvements to ROW (default) & BFQ + Interactive (default), added 1100/1300MHz steps)​
Full changelog of 1.9.0 compared to stock CM10:
Mackay kernel 0.190: http://forum.xda-developers.com/show....php?t=1842324
-updated to linux kernel version 3.0.64
-396MB RAM
-SIO scheduler
-Deadline tuning (thanks to DerTeufel)
-BFQv5 scheduler (with upstream improvements)
-ROW scheduler (tweaked, default scheduler)
-many improvements to IO schedulers in general
-SmartassV2 governor
-Wheatley governor
-Conservative tuned
-Interactive governor (default - updated to android 3.4 code + fixes)
-Call volume hack (using “Settings>Advanced Settings”* to set volumes)
-Reduced battery polling interval
-Fast charge (activate through “Settings>Advanced Settings”* or the QuickCharge toggle in MackayROM)
-WiFi PM_FAST mode selection (activate using “Settings>Advanced Settings”*)
-Battery life extender (set through “Settings>Advanced Settings”*)
-CustomVoltage (set using NSTools)
-1100-1400MHz OC steps
-Custom kernel splash (Thanks to Malcho)
-Updated charging logo to match open charger
-Disabled swap & zram
-Improve memcopy/memmove
-Improve the performance of memcpy and memmove
-Kill task closest in size to memory needed to free
-LOAD_FREQ (4*HZ+61) avoids loadavg Moire
-Entropy tweaks: Russell: Sources of Randomness for Userspace [LWN.net]
-backport CPUIDLE from 3.5
-arm/crypto: Add optimized AES and SHA1 routines
ROM comes with stock colour & stock LED. Version with voodoo colour, BLN, and VC+BLN can be downloaded from:
rootaxbox.no-ip.org - /kasper_h/kernels/JB/
*“Settings>Advanced Settings” only available with Mackay ROM 1.8.5+
*also available through the Galaxy S & Mackay app in the launcher​
AriesParts (App name “Galaxy S & Mackay) – now also shown in launcher:
Add mackay kernel settings options:
>WiFi PM mode selection
>Fast Charge
>BLX settings
>Processor settings (governor/frequencies)
>IO scheduler​
bootable/recovery:
Mackay recovery (based on CWM 6.0.2.7)
Clear NSTools settings
Clear init.d settings
Remove wipe battery function
Add reboot menu
fix default backup format selection menu
Show battery status in recovery
Aroma FileManager
Include using soft keys to navigate the menu (thanks fishears for the idea)​
Added apps:
-Gapps (121011)
-AngryGPS
-YouTube HD (wifi, 3G, also with screen off, normal colour scheme)
-Asus email widget​
vendor/cm:
Adapt for custom MackayROM building (bootanimation, ROM&file name)
Custom bootanimation (Thanks to Malcho)​
device/samsung/aries-common:
Sets app-close to 1000 ms
Set default to ondemand governor​
external/wpa_supplicant_8:
Save frequency to network config​
hardware/samsung:
F4k 720p patch for bigmem kernels​
frameworks/base:
Cid icon when USB connected
Changed USB page icon from beandroid to USB logo
Option to enable gfx effects
Right/center clock
Monitor device storage directly in /data/data
Navigation bar
Add an "Automatically Connect" option for WiFi networks
Allow purging of assets
Add option to enable/disable Electron Beam Animation​
frameworks/native:
surfacetexture: Select texture target based on pixel format​
Calculator:
Calculator feature degrees/radians in SIN/COS/TAN​
DeskClock:
DeskClock: Fix the build​
DSPManager:
Move DSP Manager into settings​
Email:
download ZIP (and many other filetypes) files attached to emails​
Exchange:
Exchange: calendar sync window linked to email sync window​
Settings:
Change Profiles to use the default header
Right/center clock
Removed user stats
Navigation bar
Change behavior when back pressed in PerformanceSettings
Fix issue with Portuguese translations
Trebuchet:
Add 2 Hotseat preferences​
providers/MediaProvider:
Make sure to always release the wake lock​
Coming from stock Samsung ROM/CM7:
-The safest way is to flash CM9 first and then flash Mackay ROM. Going directly from Samsung ROM/CM7 to Mackay ROM may lead to loosing IMEI.​
Can be flashed on top of any CM9/CM10 build:
-Coming from CM9 or CM10-builds with an old/different partition layout (older than 0817, helly bean): your phone will be wiped (except SD card)
-Coming from a recent CM10 build (0817 or later): this is a non-wipe update
>Gapps is included in the zip since 1.2.0, so separate flashing of gapps is not needed!​
-Custom kernels can be used only if patched for the new partition layout
Credits:
-teamhacksung/pawitp for making CyanogenMod work on our ancient phone
-stratosk/DerTeufel/Mialwe for the inspiration I got from their kernels
-theos0o for creating such a nice YouTube HD app
-rootax &xdafileserver for providing a high-speed server for high quality downloads
-Malcho for his bootanimation & kernel splash​
Downloads:
Credits​
Credits:​
Meine Empfehlung für eine neue Gapps Installation​
Reaktionen: Shaddix, rodman, Trucker1109 und 3 andere
Ich habe die Rom auch schon seit einem Monat drauf... Bisher hatte ich keine Probleme alles läuft schnell und gut... Auch das GPS funktioniert einwandfrei. Der Akku hält bei mir auch wesentlich länger als bei anderen Roms. :thumbup:
Gesendet von meinem GT-I9000 mit Tapatalk
Reaktionen: Radagast
Welches Modem hat die Rom integriert?
Na endlich stellt mal einer die Rom vor :thumbup:
Danke kingoftf
@Fireworker:
Mensch, Dich gibts hier auch noch, lange nix gelesen von Dir :thumbup: :tongue:
Könnte einer von euch so nett sein und ein paar Screenshots machen? Danke
Gesendet von meinem GT-I9000 mit Tapatalk 2
Bvt schrieb:
@Fireworker:
aloha Bvt :cool2: ...ja hatte leider nicht viel zeit für mein handy und war sonst viel auf xda unterwegs, vor allem weil die rom nur dort vertreten "war"...danke für den thread kingoftf
erstmal die neue version flashen :thumbsup:
Zum Thema Screenshot kann ich leider nix beitragen, ich bin im Moment mal wieder auf der neuen Elite, Schei**** Flash-Sucht :cursing:
Ein paar Screenshots vom mir ,hoffe ich konnte helfen. :thumbup:
Reaktionen: Trucker1109, Zwerkel, casakorte und eine weitere Person
Was für ein Theme ist das?
Das müsste das cm9/cm10 cobalt sein. Gibts auch noch in anderen farben im store:)
Reaktionen: kruemelgirl
ah, und das funktioniert dann also mit alles Rom's auf CM10 Basis, richtig?
Sieht echt schick aus. Danke dir.
Richtig... CM9 und CM10... Gibt ungefähr sechs Themes kostenlos und noch einige paid...
So sieht Kiwi aus
So, nun genug OT ;)
.oOo. BvttvB .oOo.
Reaktionen: Onkel Ede und kruemelgirl
Auch schick ;-) ich mag das rote pers. am meisten. Aber wieder back2topic!! :)
Ich installiere es auch grad mal aus purer Neugier...
irgendwas was nicht funktioniert?
hab Mackay vor 2 Tagen installiert. 1.Tag ok, heute Android OS bei 70 %
New update to 1.3.2
Changes compared to 1.3.0
-No-wipe coming from 1.3.0 but wipes if coming from an older Mackay ROM
-Kernel 0.75 (ondemand is default governor again)
-CM10 sources updated yesterday night
-system/core: charger: allow home button to wake
-Apollo: Rewrite image fetching and caching
-Contacts: fix Caller name disp not sticking for missed calls
-Mms: Insert Emoji and Smiley (and template) at Cursor position
Biggest change is the upstream change to Power HAL. Music stuttering should now be solved.
The power HAL has been optimized for ondemand governor. It is no longer possible to change governor in NSTools (maybe I can get it back), but due to the improvements in ondemand, I don't see the need for an alternative governor. This power HAL will be used more often for cpu response improvement in future, but only with ondemand. If you still like to use another governor, you can change it through Settings>Performance>CPU.
Download: rootaxbox.no-ip.org - /kasper_h/roms/JB/
Also bei mir ist alles im grünen Bereich !!! : Thumbsup:
Reaktionen: silversurf
ich versuchs mal mit der 1.3.2:razz:
Ebenfalls keine Probleme. Akkuverbrauch ist sagenhaft.
danke, man siehts. Hoffe mit 1.3.2 läuft meins ebenso sparsam. Neuinst. der 1.3.2 hat bei Beibehaltung aller Apps u Widgets schon mal reibungslos geklappt
