kingoftf
Ehrenmitglied
- 46.233
Gesendet von meinem GT-I9000 mit Tapatalk 2
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
Shaddix schrieb:Habt ihr eig. etwas installiert. Wenn ich ein "nacktes" System habe, schafft man solche Werte. Sobald man viele Sachen installiert, wie FB, Wetterapp, Nachrichten,... schaff ich min. 0,5% pro 1h.
kasper_h schrieb:Update to version 1.4.5
Changelog:
-Mackay kernel 0.93: http://forum.xda-developers.com/showthread.php?t=1842324
updated to linux kernel version 3.0.47
OC 1.2GHz
Apps:
YouTube HD (wifi, normal colour scheme) included in zip (updated)
Asus email widget
removed NSTools (doesn't work well with the kernel)
frameworks/base:
Changed USB page icon from beandroid to USB logo
Add SET_ALARM permission for SystemUI
Enable navbar
Right/center clock
Kill all button (new)
DSPManager:
Move DSP Manager into settings
Contacts:
Cleanup and improve T9 search code
Also search nickname and organization in T9 search
Mms:
Add new feature 'Add SMS to Calendar remind'.
Settings:
Enable navbar
Right/center clock
Trebuchet:
Add 2 Hotseat preferences
Download:
http://www.xdafileserver.nl/mackayrom/
kingoftf schrieb:Und WLAN ist superschlecht 1m vom Router 2 Balken
kasper_h schrieb:Small update to 1.4.6.
Changelog:
Updated CM10 sources
frameworks/base:
CircleBattery: Revamped charging animation
Fix lockNow() failing to turn off screen
Fix ringing audio focus handling
telephony: Display Supplementary Service Notifications
Add notification type constants
inputmethods/LatinIME
Make keyboard hints better visible
Download:
rootaxbox.no-ip.org - /kasper_h/roms/JB/
XDA File Server - For all your ANDROID ROMS! /Files/
MiSeRy schrieb:Wie bekomme ich es hin, das mein Provider wieder oben links steht?
Originally Posted by erpurohit
No I don't think there is any improvements in any jb ROM in terms of WiFi strength.. they all are same...
I think wifi signal is a pure kernel thing. DerTeufel has quite some changes compared to the CM10 wifi driver:
https://github.com/DerTeufel/samsung...ireless/bcmdhd
https://github.com/CyanogenMod/andro...ireless/bcmdhd
Shaddix schrieb:zum wlan: wi-fi idle timeout: Es sollte noch die möglichkeit geben, gar nicht auszugehen.
