firefoxx123
Läuft jetzt alles prima. Die 2.1 war vermutlich nich online.
Zitat von der Homepage:
Slim Bean 2.2
All Devices
- Landscape soft reboot fixed
- Lots of feature changes ( too many to list), picked from CM versus AOKP ( some of the old ones are gone)
- Sync with AOSP
Slim Bean 2.2
All Devices
- Sync with AOSP
- Features added - thanks CM
- Lockscreen Wallpaper
- Lockscreen Targets - Slider shortcuts
- Customizable Hardware Keys
- Notification Count same as aokp
- Power Widget instead of Aokp toggles
- Power Menu with screenshot
- Status Bar changes to CM
- Weather on Lockscreen, same as last release
- Calendar on Lockscreen
- CPU/Performance modifications - OC etc at your own risk
krarvind schrieb:Ok fellas, 2.2 released. Please read the changelog carefully and get the download from download tab on the website. This release needed a lot of effort would be an understatement that my betas would appreciate. Anyway show support via thanks/donate. Please don't fill up the thread with known issues and minor issues.Cheers
Slim Bean 2.2
All Devices
SGS 2/ SGS 3 ( d2att and d2 vzw)
- Sync with AOSP
- Features added - thanks CM, aokp, cna
- Lockscreen Targets - Slider shortcuts (1-5 or 6 -8)
- Centered Clock on Lockscreen clock optional
- Centered Lock on lockscreen on all options.
- Enable custom nav bar with upto 5 targets
- Enable custom nav har ring with 3 targets - thanks team eos
- Enable hardware back key to kill app via settings/developer settings/apps
- Change LCD density via settings/developer settings/Reboot needed
- Device information, Network selection etc via settings/developer settings/Device Information
- Customize root access to none, apps, adb, apps and adb via settigns/developer settings/misc
Known Issues for 2.2 ( Do Not Report)
- You will see two Galleries, one with upto 8MP camera, one with picasa sync ( part of common). It stays that way as i like the picasa sync feature, but you can remove it from common 2.2 before flashing.
This version is probably the most feature rich version of slim but keeps the slim concept well and good. Lots of effort ( i mean lots 3-4 hrs a day) fellas has gone into this. I expect every single user to read this carefully. Will really appreciate it. Do hit the thanks button and donate if possible.
- kill app via customizable nav bar restarts systemUI.
- NFC doesn't work on d2att and d2vzw
- 1-5 lockscreen cuts off a bit at the bottom, not a real issue as you can get to all 5, use 6-8, all is well. it moves up.
- GPS sees fewer sats but locks on some devices, temp fix seems to be to grab libandroid_servers.so from CM10, push it in. mnazim has a flashable zip, credit him for that.
- In Gnex and Nexus 7, if the shortcut to camera doesn't work, go to settings, interface, lockscreen, slider shortcuts, select it again by touching the big text message that gets displayed.
How to Install:
- Download device.zip and common 2.2 .zip
- Wipe cache/dalvik, Flash device FIRST, then common, then whatever extras/addons you need
- If there are problems, repeat step 2 but with a full wipe and format /system. Enjoy!
Changes on the way. Github set up for my betas to sync and compile. Moving forward slim builds will be produced by the following
SGS Variants - prbassplayer
Nexus S Variants - tchaari
GNex Variants - Nebucatnezer/krarvind
SGS2 - krarvind/AvRS
SGS3 Variants - krarvind
Nexus 7 - krarvind
Slim Gapps ( has modded play store for multi dpi), Extras, GNow and Face Unlock - maintained by mnazim
All links will appear as usual in this website. mnazim will also make an AIO ( All In One) package which will include Slim Gapps, Extras, GNow and Face Unlock. No other customized packages will be made. If you flash another gapps, find multi dpi play store zip in MyLifeRocks10 a RC @ sgs2 thread and thank him for creating it.
All Devices
Latest sync with AOSP source
Added UMS, MTP , PTP options via settings, storage
Browser FC fix when scrolling
Changelog All Devices:
- Latest sync with AOSP source
- Added UMS, MTP , PTP options via settings, storage
- Browser FC fix when scrolling
- GPS Fixed natively, no patch needed
How to Install:
- Download your device zip
- Download Slim Gapps ( no more common)
- Enter recovery, wipe cache, dalvik, flash Device first, then slim gapps. If you flash another gapps, you will break multi dpi market. Don't post in the thread with issues.
- If wipe cache/dalvik gave you issues, do a full wipe & format system
prbassplayer schrieb:So it was my mistake I missed the libs in the build process when we changed some things. And when I flashed Devil kernel (that included such libs) I assumed semaphore was outdated. My mistake sorry Stratosk.![]()
Sent from my Slim Bean powered I747 using Tapatalk 2
Fabian-88 schrieb:bin seit langem Nutzer von SlimICS, aktuell in der Version 4.2.
Nun zwei kurze Fragen:
1.) tut sich auch auf dem "alten" Galaxy S noch geschwindigkeitstechnisch etwas zwischen SlimICS und SlimBean
2.) Ist SlimBean bereits eine ausgereifte Alternative zu SlimICS oder würden die bisherigen Nutzer noch von einem Wechsel abraten?
