[ROM JB][4.1.2] RemICS-JB V3.0.1 [20.10.2012]
  • 362 Antworten
Radagast
Radagast
Ehrenmitglied
23.366
Remics-JB v3.0.1
Rem-Team hat nun seine JB-Rom herausgebracht ...
FEATURES:
dazu erstmal Neuerungen v3:
3.0
  • new Base
  • custom hardware acceleration (get the double "butter" experience!)
  • lots of Bug fixes
  • Accuweather widget removed due to some issues.. will be re-added in the UpdateMe app soon
  • TONS OF SPEED IMPROVEMENTS
  • new kernel (Semaphore 2.3)
  • theme updated
new Android Base 4.1.1 JellyBean
new ROM base SlimBean 2.2
new Semaphore kernel
build.prop tweaks
Touchwiz!
Nexus S hw acceleration
all the cool the Samsung stuff that you guys like! (Memo, Samsung keyboard & more!)
Update me OTA app
new CWM Script
new Bootanimation
great Samsung theme
Solid Explorer added
about 200MB of size
init.d tweaks
S3 like UI
S3 sounds & wallpaper
Buglist in Post 3
SCREENSHOTS in Post 2
(nach den neuen Regeln: Bildschirmfotos :razz:)
Changelog und Buglist in Post 3
INSTALLATION
1. Neustart ins Recovery
2. Wipe data/ factory reset
3. Wipe cache
4. Advanced -> Wipe dalvik cache
5. install zip from sdcard
6. warten bis "install from sdcard complete" erscheint
7. reboot
8. Fertig
----> bei Bootloop, z. B. von GB-Rom kommend:
Akku raus und wieder rein, erneut ins CWM und erneut
die Rom-zip flashen, fertig
XDA-Thread:
Hier
TEAM REMICS
Creators
monish1995
XYunknown
Jarmezrocks
Vlad87do
Supermaster34
smalldookie
Porters
GalaxyUser
bradman117
patrick8996
Vasishta Reddy
luiseteyo
WebDev
Benjamin Cohn
support us by hitting THANKS
CREDITS
be18
DerTeufel1980
mkalter, who got the first running jb rom
elitemovil
stratosk
teamhacksung/pawitp for cm10 sources
Reaktionen: Pipediver, pussy123, beicuxhaven und 4 andere
Screenshots
Reaktionen: beicuxhaven und pannes
CHANGELOG
Buglist
  • 3.0.1
    • lots of Bug fixes
    • Accuweather widget fixed & re-added (needs Gapps to work!!)
    • new kernel (Semaphore 2.4.0)
    • UpdateMe re-added
  • 3.0
    • new Base
    • lots of Bug fixes
    • theme updated
2.0
  • new Base
  • Nexus S hardware acceleration (get the full "butter" experience!)
  • lots of Bug fixes
  • UpdateMe re-added, content will be added later
  • All the TW stuff added
  • new kernel (Semaphore)
  • theme updated
  • 1.0.1
    • updated Base
    • Google Now and Search widget fixed
    • UpdateMe removed because it was so unstable
    • SolidExplorer added
    • TONS OF BUG FIXES
    • maybe I forgot something
  • 1.0
    • initial release
Bugs:
Here is the actual Buglist for RemICS-JB 2.0 (02.09.2012, 12:43 MEZ):
- the Samsung keyboard FC's sometimes when using the special popup keys
- low space for apps, a but fix is on the way! Until then you can move apps to /system or use app2sd
- I included no "Bugs" that might occur when you don't follow the installation guide (for example camera FC or "OMG! Why does this ROM has no MP3 player??")
ich auch !
Moin scorp ... Fällt mir nun auch auf, dass die Rom ja RemICS-JB heißt ... ändere ich bald ...
Gesendet von meinem GT-I9000 mit Tapatalk 2
Reaktionen: scorp182
Läuft perfekt bei mir. Habe den kernel geändert auf Devil3_1.0.4_jb_i9000_CFS_BLN_CMC_20120727 seit dem blinkt auch nicht mehr das display auf wenn man die tasten entsperren will. Ansonsten sauber arbeit wie immer freue mich schon auf weiter updates
Reaktionen: pannes
hallo
wo ist der link für die rom ?
alles gefunden!! sorry
mfg
smoky
Da der apex louncher sehr träge ist mit der rom habe ich jetzt mal auf den nova louncher gewechselt aus den playstore. Der läuft deutlich besser mit der rom .
Gesendet von meinem GT-I9000 mit der Android-Hilfe.de App
gibt es endlich irgendwie die Möglichkeit die Kamera-Photos direkt auf die SD-Karte zu speichern? Oder übersehe ich diese Option nur?
Gibt es eine Möglichkeit das Theme mit den Samsung Icons einzeln in irgendeiner CM10 zu installieren?
Update Me Jamerd immer rum das 1.0.1 verfügbar ist aber man kann nichts runter laden was soll sowas denn...
Wird schon kommen. Ein Update ist ja schon seit heute Mittag angekündigt. Die Herren machen es ja wie alle anderen kostenlos. Also etwas Geduld :)
Finde ich aber lustig seit dem ich es geschrieben habe ist die meldung wieder weg :)
Hoffe mal das in der neuen version gleich der nova drin ist weil der alex absolut schlecht läuft bei mir.
Ich verfolge seit Tagen (oder gar Wochen?) die Entwicklung von DerTeufel's Helly Bean, und da konnte ich natürlich nicht widerstehen, diese ROM zu testen. Läuft bisher echt super flüssig und flott, Installation (Full Wipe natürlich) war auch gar kein Problem.
Allerdings habe ich eben bemerkt, dass der integrierte Apex Launcher keine Einstellungen speichert, die ich ihm mitteile (z.B. wie er die Apps im App-Drawer zu sortieren hat). Habe dann eine Apex-Sicherung von gestern via Titanium Backup wiederhergestellt und da geht's.
Der Apex:D launcher läuft mit Helly Bean Base auf das dieses Mod ja auch basiert flüssiger.
Reaktionen: Radagast
Ja habe den jetzt mal deinstalliert und den nova drauf gehabt und jetzt hab ich den apex neu geladen aus den playstore jetzt läuft er perfekt. Vorher konnte man auch die einstellungen in louncher nicht speichern aber wenn man den deinstalliert und neu lädt aus den market ist alles perfekt.
@quasimodo: Ich schätze, du wirst das oft gefragt und eigentlich hatte ich auch damit gerechnet, dass hier schon längst jemand gefragt hat. Nun muss ich selber: welches Wetter-Widget ist das in deinen Screenshots? Ist das im RemICS-JB dabei?
@Bödi, MIUI Wetter Widget heißt das Gute Stück!
findest Du, schnell für dich upgeloadet und gelistet Hier: Kompatibel mit allen ICS Roms
Reaktionen: pannes, Bödi und Sarocc
