Q
quasimodo
Gast
[ROM][ICS][AOSP]Elite Forziere Touch[Touchwiz 4.0][4.0.4] by forziere /xda
his Rom TouchWiz ICS 4.0.4 is a personalization of Rom AOSP NEXUS S/4g Elite V6 (the best one)
Giving ICS Some TouchWiz
AOSP is working as on Touchwiz as on Apex launcher
Was Geht - Was noch Nicht
Installationsanleitung
If You Are On Any ICS Rom :
1.Put rom on sdcard
2.enter recovery and wipe data and cache
3.install zip from sdcard and install
4.enjoy
If you are on gingerbread Rom
1.(optional) Flash Any ICS Rom
2.Put rom on sdcard
3.enter recovery and wipe everything
4.Flash by installing zip from sdcard
5.enjoy my work
To install Touchwiz (from recovery:
update.TouchWiz4.ICS.zip
To install as a normal apk swype :
Deposit Files
If you want Beautifull widget .. you can find on Market!
I suggest to install Midnight Kernel to improve the battery life
1.Put rom on sdcard
4.enjoy
2.Put rom on sdcard
5.enjoy my work
Deposit Files
