[ROM ICS][4.0.4] PARANOIDANDROID v1.5a [27.06.2012]
  • 36 Antworten
Radagast
Radagast
Ehrenmitglied
23.366
PARANOIDANDROID
- V1.1d: paranoidandroid-1.1d- GT-I9000.zip
- V1.1 FINALE-2
(fixed emcc): PARANOIDANDRIO V1.1 FINALE-2 GT-I9000.zip
- Install HYBRID gapps: http://paranoidandroid.d4net.org/ccount/click.php?id=1 Mirror: gapps-hybrid.zip
*Wipe caches, factory reset is a must if you're coming from another rom than CM9
Weitere DL-Links weiter unten im Post
This is a full port form nexus s development selection, i have been working all afternoon on getting this rom bug free. so if you like you can donate or at least thanks button:
Original XDA-Thread für "Thanks" und "Donation"
Hier
Anmerkungen
Um diesen "CustomRom Beitrag Sauber zu halten, bitte nachfolgendes Beachten
  • Rom betreffendes Hier Posten und darüber diskutieren - Offtopics werden Hier gelöscht
Besten Dank für euer Verständnis und viel Spaß mit dem Rom!
Video der Rom
Weitere Anmerkungen der Devs:
"This is an ongoing developer project to make way for a modification that will entirely transform your device, but retain the aesthetics and the experience of your phone. I know you've seen tablet mode roms before, they change two lines in your build.prop file which you could easily edit yourself in seconds and maybe throw a keyboard in there to make it work better. It's a start, but this ain't enough. This thing has potential, but it is wasted the moment you try to stuff a full blown tablet into your poor phone. Yet we all know our high res phones can very well handle more than silly 1-column layouts. So the magic must be in between somewhere, a place that Google must have overlooked and left blank. Yes, this rom strives to drop your device into tablet mode, but it won't stop there, it will reshape and redefine ICS to make it all a usefull addition and not just a cute novelty. we're calling it: Hybrid Mode, best of both worlds"
READ THIS:
Thanks to chkoon he discovered what was the problem that was making the phone have no signal, pin unlock is the problem, for flashing v1.1 you must disable it, if you enable it you will have no signal, if you cant live without pin unlock, for now you can use v1.0 till i know what is the problem, thanks.
Download aktuellste Version:
v1.5a: HERE
Hybrid-GApps
Settings-Fix
*Install Rom (und ältere Download-Links):
*V1.1 FINALE: paranoidandroid-1.1-Finale.zip
*Install HYBRID gapps: http://paranoidandroid.d4net.org/ccount/click.php?id=1 Mirror: gapps-hybrid.zip
*Go to Settings, System, Font size, set it to NORMAL
*Check "Auto Hide" in Settings, System, Statusbar, to finally get Fullscreen (or Hold power button, and press "Toggle StatusBar")
*Launcher Settings: margins: SMALL (If youre using Apex / Nova), show permanent searchbar: YES, Grid: 5x4, resize all widgets: YES, Wallpaper scrolling: OFF
*Wifi Hotspot not working. (It will gives you bootloop.)
*You tell me? All possible visual bugs can be fixed changing PAL & PAD parameters
This is an ongoing developer project to make way for a modification that will entirely transform your device, but retain the aesthetics and the experience of your phone. I know you've seen tablet mode roms before, they change two lines in your build.prop file which you could easily edit yourself in seconds and maybe throw a keyboard in there to make it work better. It's a start, but this ain't enough. This thing has potential, but it is wasted the moment you try to stuff a full blown tablet into your poor phone. Yet we all know our high res phones can very well handle more than silly 1-column layouts. So the magic must be in between somewhere, a place that Google must have overlooked and left blank. Yes, this rom strives to drop your device into tablet mode, but it won't stop there, it will reshape and redefine ICS to make it all a usefull addition and not just a cute novelty. we're calling it: Hybrid Mode, best of both worlds.*
Donations to CM
Donation Tracker - CyanogenMod Forum , to molesarecoming , http://forum.xda-developers.com/dona...hp?u=4491046tohttp://forum.xda-developers.com/dona....php?u=3484876http://forum.xda-developers.com/dona....php?u=4297715 D4rKn3sSyS , to me
v1.5a
-Everything worked fine
-Video Recording now working
-Much more smoother
-Tethering works (not usb, but bluetooth and wifi)
-You tell me?v1.5
Built from source - 25/6/2012 - 11:3:12
Improvements on OTA app, scheduled checkups
Improvements on Backup app, now it automatically launches on startup after you install a newer (or older) version
Hybrid speedup, less lag, considerably faster list scrolling when pad/pal is in action
Keyboard scaling, an androids first
PAD/PAL bugfixes for apps that still crop images in lower dpis
Settings revamp, speed preferences to switch between modes without having to set up anything, less clutter
Trebuchet extras: 3x4 widgets, speed dial menu button, ... and some weird rocket button which im sure will be very useful to most of you
Pad.prop revamp, new preferences that should pretty much nail it. Im sorry but this trashes your old settings again, do not attempt to restore them unless you do it in a text editor
v1.4
Built from source, 3:03pm COT. Synced with latest Paranoid sources
Fixed most of the issues with pad & pal, now facebook, whatsapp, keyboards, etc will be shown just fine
PAD/PAL work in phonemode 100%, no weird toggles and stuff like that. you get full tablet apps without caveats
Settings cleanup, most of the garbage dpi options are gone, should be more intuitive - i ask you to not bring your old pad.props though some things changed. if you know what you do take a look and edit by hand
Trashed our LatinIME repo - not needed anymore
Fixed OTA 100%, now it should never hang on 99%
Navbar editor is now hidden on tablet mode ... ups missed that one.
v1.2
Built from source, 04:27 CEST.
Updated kernel to latest CM Kernel
Patched linaro spare parts
Fixed Tethering
First unified release, compiled from our git
New panel (You already know it if you used betas)
Added ParanoidBackup app
Fixed bugs on beta releases (Battery swapping, overlaps, ui bugs etc)
Recent apps improvement on tab mode (bigger preview)
Error where app shows up in the wrong UI will be fixed
Scaling lockscreen dialogs and so on
Removed hardcoded framework values (yay! )
Removed "Global density", if you STILL want to mess with this one with v1.2, you've not even tested a 50% of what this ROM can do.
Fixed a lot of other things on pad & pal, cleaned up sources
Fixed themes crash on tab mode, still crashes sometimes on phone mode. [Seems this one is totally fixed now. Need to test a bit more]
A HUGE amount of fixes, improvements and so, this version should be rockstable.
V1.1d
Improved performance a lot!!!
removed unecesary apks.
PIN unlock must be tested
V1.1
Kanged from source, 9:26am COT. All features included (even the ones that are on CM9 changelog but not on latest nightly)
Updated kernel to latest Pete's kernel
Fixed Bigmemory problems
Fixed Bluetooth?
Fixed navbar on phone mode, and now doesn't removes statusbar transparency
Fixed Utils.isScreenLarge() method, now it checks for LCD Density, wich reduces % of error to 0
Improved panel a LOT, including a cool action bar for saving or discarding changes
.force pad feature implemented, now you can resize widgets
Added more descriptive strings to panel
Added customizable toggles for tablet mode. You can choose now between 9 toggles, and a max of 6 of them. You can also reorganize or remove all the toggles.
Removed some battery styles, and HC lockscreen, searching for a common base
Translated a lot of things in spanish XML's (Gerrit Code Review)
v1.0
Kanged from source, 1:04pm COT. All features included (even the ones that are on CM9 changelog but not on latest nightly)
First time in Android history that Per-App-Layout has been realized
Comes with a better panel
Fixed pin screen hot reboot
v0.6
Kanged from source, 2:52pm COT.
Updated kernel to latest siyahKernel
Fixed tablet mode swapping not overriding sense recent apps option
Automatically disable all the DPI options if PAD is not enabled
General fixes. We're now stable. This version is not a beta but a RC
Fixed reset button on PAD panel
Fixed tablet mode keyboard popup (Is little but there it is, not cutted anymore)
Force to hide statusbar (Global menu option)... finally fullscreen gaming!
New PAD code. No lags at all, rotation is smoooth.
v0.5
Kanged from source, 11:10am COT. All features included
CherryPicked a few CM things that I'm sure they will merge soon (and what if they dont )
Home button long press on tablet mode now handles recent apps (just like on phone mode)
New PAD panel. Moles didn't sleep today
Fixed most of the crashes (99%, maybe I missed something)
Fixed lockscreen music transport overlay
Fixed Can't install apps to external sd, installing them causes acore fc
Tablet mode onScreen buttons toggle
Instant changes, SoftKeys (Not even on AOKP )[/quote]
Gesendet von meinem GT-I9000 mit Tapatalk 2
Mein Wlan geht immer noch nicht und im XDA-Thread wird berichtet, dass per PC der DL gehen soll. Kann mal wer den Link hier posten .... Danke!
Edit:
Wenn, dann kommt alles auf einmal, nun ist mein Netzteil noch kaputt :banghead:
Wenigstens erstmal ein paar Screenies:
Reaktionen: efendy46
Ist es ein aokp"klon"?
Paar Screens von mir.....bis jetzt ein Traum Rom:) :) :) :)
Das ist der Hintergrund falls ihr brauchts:)
Gesendet von meinem Nexus S mit Tapatalk
Reaktionen: Meikel_61, BaltRavens und Radagast
neue versoon und nun offiziel
p.s. bald kommt 1.1
Reaktionen: efendy46 und Radagast
die Version 1.1 rc 2 ist da! Gerade bei den xda devs gesehen!
Hier mal der link zur aktuellen Version:
http://d-h.st/fqk
Also kurze info von Version 1.1 rc 2..habe drauf gehabt,Home Button wurde gefixt aber Browser bringt Force Close:(,external SD immer noch Problem,bin jetzt mit Anarkia Rom unterwegs :)
und wieder eine neue Version die 1.1 RC 3 ist draußen!!!
PARANOIDANDROID-1.1-RC3.zip
und eine mini changelog:
*Fixed FC´S
*might fixed pin on startup
*no buggs for now.
Reaktionen: Radagast
funktioniert bei euch usb tethering?
bei mir nicht...
@balt: hast dus schon drauf? funktioniert bei dir die pin eingabe? weil es bei mir nicht erscheint
Oo man.... schon wieder updateted ..also noch ein Versuch.!!
und ich könnte kotzen :banghead:
WLAN geht immer noch nicht, daher nochmals sorry ...
Aber morgen muss mein Chef mal damit leben, dass ich Post 1 aktualisierte.
Vielen Dank an Euch fleißigen Poster :thumbup::thumbup::thumbup:
Kann die Rom nicht mal downloaden, weil kein Wlan auf Arbeit und mit GPRS ... ne ne :(
Nein die Pin Eingabe wurde leider noch nicht gefixt, soll aber heute noch dran gearbeitet werden
Also im moment wird daran gearbeitet die externe sd zum laufen zu bekommen und es wird am wifi Hotspot gearbeitet
Ich denke mal das es vielleicht noch ein update gibt heute Nacht also ich würde mit dem Flash warten bis zumindest die externe sd läuft
Reaktionen: Radagast und BaltRavens
kann ich leider nicht bestätigen da ich meine sim sperre nicht weg bekomme
aber mehrere user bestätigen das!!!
Ick gehe jetzt erstmal zur AOKP B37 zurück, wie ich finde der beste Release was akkulaufzeit betrifft!!!
Wenn das problem mit dem Netz gelöst ist werde ich nochmal die paranoid rom probieren. Aber jetzt ist erstmal schluss mit dem rum geflashe!!! 4 Roms in 12 Std!!!!
FLASHAHOLIC durch und durch!!!!!
du musst auf system-sicherheit-sim kartensperre einrichten
und dann hackerl bei sim karte sperren wegtun :biggrin:
ja ich weiß aber er sagt mir immer das es die falsche pin sei, auch wenn ich sie kurz zuvor geändert habe.
Also wie gerade mitbekommen habe wird heute die Final erscheinen (hoffentlich mit dem Pin Fix)
wenn die erschienen ist werde ich es nochmal probieren!
leider wird auch in der Final der emmc bug noch nicht behoben sein
Hier mal die Aussage des Developers!!! :
Guys im uploading PARANOIDANDROID FINALE today,
* pin unlock must be fixed now
pending bugs:
*emmc (need an expert here)
*wifi-hotspot (known bug)
edit: that i put finale doesn´t mean i stopped developing, but all big bugs have been sorted out
Die Rom ist so geil
kingoftf
Islaris
Islaris
scorp182
sgs9000A
sgs9000A
Sattich
