[ROM][ICS][4.0.3][AOSP+] CodeNameAndroid 1.3.3 (Update delayed)
  • 336 Antworten
id.goPLAY
id.goPLAY
Codename Android is a fully open source rom that focuses on speed, usability, and getting every feature that we can get CRAMMED in there .
Our mission is to spread the Open Source Android love to as many people as possible, and get as many people involved as possible. Along with the rom there will be tutorials to get more people involved and learning how to build android step by step.
Official Thread: [8 FEB][ROM] Unofficial Port | CodeNameAndroid 1.3.2 - xda-developers
Check THIS post for FAQs and other guides.
I am not responsible if the above causes your device or explode or if it starts World War III or an alien invasion!
Anmerkungen
Um diesen "CustomRom Beitrag Sauber zu halten, bitte nachfolgendes Beachten
Rom betreffendes Hier Posten und darüber diskutieren - Offtopics werden Hier gelöscht
Rom übergreifendes in der Diskussionsplattform & Newsletter ICS Rom - Zubehör Übergreifend *platzieren - diskutieren
Kernel spezifisches in der *Diskussionsplattform ICS Kernel Übergreifend platzieren - diskutieren
Modem spezifisches in der CM7/MIUI Modems - mit Umfrage Modem Übersicht / Region für MIUIplatzieren - diskutieren
Besten Dank für euer Verständnis und viel Spaß mit dem Rom!
Features:
  • All launguages
  • Uncentered stock unlock down layout
  • Custom SMS App on four target unlock down lockscreen
  • Much nicer big clock lockscreen layout
  • Updated the method of which the Google Apps are installed (fixes nfc, adds exchange support, and instant app restore)
  • Google Apps built in
  • Ability to switch the recents button with search
  • Sim toolkit
  • Facebook synchronization
  • Adb over network (CM)
  • Fixed init.d start-up tweaks
  • Reverted backlight on by default
  • Speaker Proximity Sensor
  • Customizable Nav button Glow Speed
  • Quick unlock - Unlock password/pin lockscreen without pressing enter button
  • Powerkey shutter - Allows user to use the power key to take pictures/videos
  • Updates to phone and contacts App (CM)
  • Updated and reorganized performance settings
  • Overclocking settings now displays your "Current Frequency" (CM)
  • Moved disable boot animation to performance settings
  • Reverted "smooth zooming" in the camera (not much smoother and caused small graphical glitch")
  • Customizable menu visibility and location (original idea - Paul Obrien, settings - romanbb, fixed to update imediately (no reboot needed) and modified for CNA - codenamedroid)
  • New battery options (Customizable battery sytle and more)
  • Huge lockscreen cleanup and configurablilty update
  • Increased speaker volume (codenamedroid) (Galaxy Nexus)
  • Update to Codename Android kernel 1.3.2 (Galaxy Nexus)
  • Fixed hdpi lockscreen graphics (Nexus S - GSM/CDMA)
  • Updated proprietaries and build fingerprint to 4.0.4 (Nexus S - CDMA)
  • Fixed TV Output problems
User Review's:
• Under The Hood: First Look with Screenshot's (German) (Thanks to Bavaria_Blues)
Available versions:
Download: CNA 4.0.3 v1.4.0 / (Mirror)
Download: CNA 4.0.3 v1.3.3 / (Mirror)
Download: CNA 4.0.3 v1.3.2 / Mirror
Install Instructions - Coming from other ROM's
  1. Download & copy the CNA_4.0.3_1.X.X_I9000-signed.zip on SD Card
  2. Boot in CWM Recovery
  3. Factory Reset + Wipe cache
  4. Flash CNA_4.0.3_1.X.X_I9000-signed.zip from SD Card and restart to CWM Recovery
  5. Factory Reset + Wipe Cache
  6. Reboot to install completely
Install Instructions - Update to last version
  1. Download the last version & copy to your Internal SD Card
  3. Flash CNA_4.0.3_1.X.X_I9000-signed.zip from Internal SD Card (No Wipe Required)
  4. Reboot to install completely
If you have rebooted and your phone will not go past the kernel screen.[/I]
  1. Boot into CWM and wipe data/factory reset and wipe cache partition
  2. Reflash the appropriate kernel
  3. Reboot
CHANGELOG
1.4.0 - Released on 20/02/2012
  • Stock CM Kernel (Flash Glitchy kernel or Semaphore)
  • Mixed ThunderBolt
  • BrainMaster's Tweaks
  • Added New Music Player
  • Remove existing Tweaks
  • Launcher: Nova Launcher Beta 15 (Additional)
1.3.3 v2 - Update Canceled
  • Kernel Updated: Devil 1.1 CFS
  • Bootanimation changed to be darker
  • Optimized system
  • Few Google Apps updated to 4.0.4 IMM26
  • Camera Resolution fixed - 4MP (W) Now working!
  • Removed Power Shutter (Will implent it when its updated)
  • Fixed Tweaking in Performance Settings (Flash Glitch kernel, the tweaks works well with it)
  • Change new fingerprints
  • New FileExplorer!!!
1.3.3 - Released on 09/02/2012
  • Revert Kernel to Devil 15.1
  • Added Codenameandroid Tweaks (So i assume the performance > tweak will work...)
  • Added 3G Tweaks (To ON your network faster, press n hold power button and deactivate airplane mode)
  • Updated Galaxy S Settings
  • Removed zRam aka CompCache
  • Updated Gapps
  • Fixed TV Output problems (Thanks to rtfposseoa!)
  • Fixed emmc problems
  • Added DSPManager
  • Removed Bloatwares
  • Google Wallet
  • Audio Tweaked
1.3.2 - Released on 08/02/2012
  • Added Devil Kernel 1.0 BFS
  • Fixed RIL Issues (Thanks rtfpessoa)
  • Added PlusOne.apk (Google Plus)
  • Added Maps.apk (Google Maps)
  • Added NFC.apk (NFC)
  • Added TagGoogle.apk/Tag.apk (Google Tag)
  • Added ThinkFree.apk
  • Added some tweaks
  • System Boost Up
  • Ported to GT-i9000
Bugs/ Known Issues:
  • When booted up, Airplane Mode is on
  • Reboot > equal to Reboot into Recovery
  • External Sdcard is unreadable (not confirm)
  • Cant change 2G/3G Connection (Not Even using *#*#4636#*#*)
  • Signals are not shown properly
SCREENSHOT'S
Reaktionen: mamaitalia, mobilkom, ThaLor und 14 andere
CHANGELOG 1.3.4 - Next update 12/02/2012
  • Kernel Bootscreen updated
  • Optimized system
  • Google Apps updated to 4.0.4 IMM26
CHANGELOG 1.3.3 - Released on 09/02/2012
  • Updated Gapps
  • Added DSPManager
  • Google Wallet
  • Audio Tweaked
CHANGELOG 1.3.2 - Released on 08/02/2012
  • Added some tweaks
  • System Boost Up
Bugs/ Known Issues:
  • Wifi Tethering is not completely on
  • Lockscreen is big and buggy (On Four, Six, Eight) Use centered layout...
Reaktionen: Drangis und xsmokyx
Wer ist der erste? :D
na du!!!!!! :)
Hehe ich habs auch schon gezogen. Gerade der 8-way-unlock-screen reizt mich.
"leider" soll morgen schon die 1.3.3 kommen...
Da bin ich auch mal sehr gespannt, danke an Dich, iPLAY, für die Vorstellung; dann kann ich es mir ersparen, die Rom in meinem Thread vorzustellen...
Werde aber kurz darauf hinweisen und auf diesen Thread verweisen, wenn es Dir, iPLAY, recht ist ...
Kein problem, ich gib dir auch mein password wenn du es brauchst! :biggrin:
So habs gerade geflasht und bin mal gespannt. Was ich sehr schätze ist die Anpassbarkeit von Statusbar und Sperrbildschirm! Näheres später...
Wenn es dir nichts ausmacht, uns paar screenshots zu schicken damir ich die vom Nexus (Post 3) auswechseln kann.
Next update...
DaxIΠFIΠITY;22304589 schrieb:
Ok, new test release may come soon at night...
-v1.3.3 sources
--Paritially fixed wifi tether (i guess, must test)
--Tweaked 3G to work properly
--Add Greek Keyboard...
Mir egal, ich flash das :D
Kann jemand bestaetigen das Sim toolkit mit dabei ist und funktioniert?
Schnell Akku laden, downloaden und flashen :D
Screenshot update im Post 3
Reaktionen: SCIIAS und Bavaria_Blues
Gibt es einen Empfohlenen kernel?
Sim-Toolkit ist dabei und geht.
Der Kernel vom Teufel ist integriert (3.1.10-galaxy+telus-257255-g0b9d335-dirty)
In den speziellen CNA-Menüs lassen sich die Batterieanzeige und diverse andere "Feinheiten" einstellen.
Und WLAN geht :thumbsup:
Ich seh grad, dass die Uhr ne Stunde nachgeht. Muss man halt einstellen :D
Screens:
Reaktionen: id.goPLAY
Was ist denn mit "custom carrier label" gemeint? Lässt sich da "DBT" einstellen?
Bin gerade auf der Arbeit, habe die ROM noch nicht drauf :D
