r4ff0r
Dauer-User
- 365
wie siehts eigentlich mit TB und dem restoren aus? also keine systemdaten ist klar, aber der rest? hab n backup gemacht von GB und dann erst jpu geflashed gehabt
Step 1: type "su"
Step 2: go to root directory. If you type "ls" and can you see "emmc" you are right position.
Step 3: "chmod 777 emmc" or "$chmod 777 emmc" (for write and read permitted.)
Step 4: Reboot the phone
- Reboot into "Stock 2e" or "ClockworkMod" Recovery using 3-button-combo and apply "kernel-cm-7-INITIAL-DEVICE-signed.zip"
- Don't use "reboot recovery" command or other shiny things to do this!- Reboot. Your Phone should automatically start flashing "update-cm-7-INITIAL-DEVICE-signed.zip". If it doesn't, simply reboot again.
- Wait until your Phone has booted fully up. There's a lot to do, be patient. Welcome to CyanogenMod 7.
