[ROM][CUSTOM AOKP][IMM76I] °•KANGYU•° 2.2.1 • Smooth • …The…Bombardier°…. saving...
  • 4 Antworten
xHCx
xHCx
Ich oder Android-Hilfe.de übernehmen keine Haftung dafür! Ihr seid für euer Handeln selbst verantwortlich!!!
Banner von quasimodo (Danke!)
This is fully ported from nexus s to captivate, i fixed all bugs
xda-Link: [ROM][CUSTOM AOKP][IMM76I] °•KANGYU•° 2.2.1 • Smooth • …The…Bombardier°…. saving... - xda-developers
Anmerkungen
Um diesen "CustomRom Beitrag Sauber zu halten, bitte nachfolgendes Beachten:
  • Rom betreffendes Hier Posten und darüber diskutieren - Offtopics werden Hier gelöscht
Besten Dank für euer Verständnis und viel Spaß mit dem Rom!
What is Kangy Ultra?
Kangy Ultra is one of the custom AOKP ROM + Great abilities, optimized tweaks for gaming and performance. KU has an AnvilINV UI by etoy n' decalex... High Bigmemory has been patched and new Icons has been added in this ROM.
Features:
-Based on Android 4.0.4 IMM76I
-Based on AOKP
-Optimized Tweaks
-Google Apps are included (GApps)
-Apex Launcher
-AnvilINVert2 (decalex's version)
-Custom Themes**
-AOKP Features
--Customizable Navigations Bar
--Customizable Statusbar
--Customizable Recent Apps
---From Stock to Sense 4 to WebOS
--Customizable Tweaks
--Themes Chooser
--DPI Resizer
--AOSP Toggles
--Many More!
Scrennshots: siehe Post 3
Download (2.2.1 bombardier): KANGYU_2032123 GT-I9000 Bombardier.zip
  • Mods & Fixes
ICS Tipps & Tricks - Wissenswertes / Know How - Liste Mods, Fixes
Credits to:
-Google (The awesome one.)
-bedalus (My friend and personal tester. )
-KaliMochaoAz (The one who is behind supporting Nexus S.)
-Brainmaster (The tweaks was discovered by him.)
-MathKid95 (You should know better.)
-Zeppelinrox (Tweaks)
-Krarvind (Slim)
-djdarkknight96 (The one behind the inverts.)
-Ricardo Ceiquerra (Who is behind the merged of Theme Chooser & Holo Purple.)
-Android Does (Apex Launcher)
-AOKP (Romanbb and the team)
-Etoy and Decalex (For the wonderful AMOLEDBLUe)
-CM Team (To make this happen)
-Andrew Neal (For CM Music update 4.0.4)
-Goo-inside.me (Google Apps)
-RcrdBrt
Press Thanks if you like the rom- Or if you like you can DONATE to me
(Dafür an den Entwickler bei xda melden!)
BUGS:
All fixed by me.
Emmc (external sd not mounting) comon bugg, i will fix it
Installation:
1:place the zip in the sd
2:flash it via cwm
3:reboot
4:enjoy
Changelog: siehe Post 2
Erste Eindrücke:
von caipi75
Von mir (xHCx) ein Danke an:
bvt-1
caipi75
quasimodo
Handymeister
und weitere..
Reaktionen: caipi75, Radagast und raXoN
Changelog
2.2.1 Bombardier°°
221250
-Fixed Few Icons
-Fix Terminal Emulator FC
-Add new boot_sound
-Updated Nexus S4G kernel
221087 (17-5-2012)
-Added Nexus S4G Support
-Fixed Gtalk problem + SonnySekhon's themes
-Deleted boot_sound
-Fixed Icons
2.2 Bombardier°
220980 (15-5-2012)
-Updated ApexLauncher 1.1.5
-Fixed PlayStore problems
-Removed Music
220812 (Testing only)
-Based updated to .36 changlog
-Added Gummypapers (Cuz i love it!)
-Weeeeird bootsound lol (for now.)
-Able to update through goomanager
-Goo.im for every stable versions
Issue
-Icons is ****ed up.
2.1.1 SharpShooter°
211014 (14-5-2012)
-Kernel Baseline Reverted due to Flashing Errors
-KickAssKernelizer Tweak (Thanks Zeppelinrox!)
-Updated Google Services
-Fixed GTalk
-Added what is available on the previous kernel based line.
-Clean Up
Issues
-Purchasing apps on Play Store gives a funny error. (Fix.)
2.1.0 Jester°
210100 (12-5-2012)
-Kernel Baseline Updated
-Fixed Camera FC
-Rebranded Settings since merged 2.0 new icons settings
-Updated few themes
-Added Black Infinitum (Thanks Razer!)
-New Messaging Style App
-New AnvilINVert by Me + Me Friends
-Optimized Tweaks
-Remove Supercharger
-Bigmem Support Re-added (As its missing earlier in 2.0)
-Fix GTalk problem
-Added Lucid's Google Play Music
2.0 dIamonD°
200XXX (8-5-2012)
-Rebased on AOKP Build 35
-Added Two Themes by rmcee
-Based on Stock kernel
-Added BIGMEM Patch
-Optimized Tweaks
-Fixed some shits....
1.1 cRystal
-Initial Release
Screenshots:
Habe dieses Rom im Testeinsatz gehabt!
Nachgeflasht: TW5 Port
Theme: Sense4
  • schönes Theme AOKP Rom (ähnlich RemICS)
  • gute Performance - läuft Smooth
  • schnelle Menüführung - auch zu den Kontakten
  • externe SD Karte nicht gemountet
Meine Screenshots
Und damit es nicht Untergeht
Bericht aus Vorstellungsbeitrag von caipi75
caipi75 schrieb:
So, ich hab mich nun mal an die Rom gemacht und diese mit einem lockeren 3er Wipe geflasht. Die flasherei geht Flott und ohne Probleme.
Hier meine ersten Eindrücke:
Die Rom selber ist schnell und flüssig, läuft sauber. Zum Akku kann ich leider noch nicht viel sagen, hält sich aber bis dato gut.
GPS fix funktioniert, auch das Wiederherstellen mit TB klappt einwandfrei. Externe Speicherkarte wird noch nicht erkannt, wird aber sicherlich noch gefixt.
Einzig was mir negativ aufgefallen ist, es ist kein Explorer in der Rom integriert und der Terminal Emulator schliesst sich nach dem öffnen sofort wieder.
Alles in allem aber eine saubere Rom, schnell, flüssig und auch schön dargestellt. Es sind sogar Themes integriert die geändert werden können, was für mich positiv ist.
Hier habe ich noch ein paar Screenshots der Rom nach dem Flash.
Edit: zur Akkulaufzeit morgen dann mehr. :D
Reaktionen: xHCx
Danke xHCx für die Neuvorstellung der Rom. :thumbup: ;)
Noch kurz was zur Akkulaufzeit, ich finde sie hält sich gut für diese coole Rom. :thumbup:
via Tapatalk 2
Reaktionen: xHCx
kingoftf
Islaris
Islaris
scorp182
sgs9000A
sgs9000A
Sattich
