[ROM] BOYPPC-SHIFTPDA GALAXY S GINGER 2.3.4 CM7 HoneyComB V1 & MIUI V2
  • 10 Antworten
Q
quasimodo
Gast
Zwei weitere AOSP Roms mit den Namen
BOYPPC-SHIFTPDA GALAXY S GINGER 2.3.4 CM7 HoneyComB V1 - Basiert auf Cynogenmod 7
und
Galaxy S MIUI V2 - Basiert auf MIUI 1.5.6. / sind seit dem 14.05.2011 Online gegangen!
Inhaltsverzeichnis:
  • Anmerkung & Fortschritt Verfolgung
  • Download
  • Installationshinweise
  • weitere Downloads - Kernel - Modem - Skins - etc;
  • weitere Link-Verweise
  • Quellen
  • Häufig gestellte Fragen
  • Kommentare - Umfragen
Näheres bei xda: KLICK
Galaxy S V1 \ Link2
Features:
Custom apps, honeycomb themes, honey comb livewallpaper, new market for android 2.3.4,
new file manager, nemo music, ll apps included that come stock with CM7, 3G / Data, Audio,
Bluetooth, GPS, Wi-Fi, Phone, Camera (5MP), Camcorder (800x480), 720P video playback,
-Hosts file to stop most web ads, FM Radio, New Market, USB File Transfer, -ADW Launcher,
LED Notification, CyanogenMod CPU Performance Menu.
___________________________________________________________
base and App: stock rom CM7
Mod: honeyComB lock screen, flip animation, boot animation, fix system.
Add app: MIUI music, task manager, qick office, yahoo mail and chat, root explorer,
HoneycomB themes, coloriza widget, GL 3D weather clock widget.
und BOYPPC-SHIFTPDA GALAXY S GINGER 2.3.4 CM7 HoneyComB V1 & MIUI V2
Galaxy S MIUI V2 \ Link2
Base rom and App: MIUI 1.5.6 Ginger 2.3.4
Language: WWE / Sprachpaket Deutsch KLICK
Mod: Lock screen, Flip Animations, mod DefaultThemes honeycomB style, add hy5.8 & Hive V0.3 themes.
Add App: Facebook, twitter, yahoo mai & yahoo chat, quick office, Spare parts.
Change log
V2 Fix boot, fix power menu, add new boot animation, add honeycomb live waalpaper.
remove Facebook, twitter, yahoo mai & yahoo chat, quick office, Spare parts (you can download from market)
Installationsanleitung in Englisch
How to install Rom
1 download and copy rom to phone
2 root phone by GalaxyS_One-Click_Root_All_Models
3 Flash cm7-galaxys-initial-kernel.tar by Odin
4 Flash boyppc-shiftpda rom by Recovery
in Deutsch
Wichtig: Stellt sicher dass ihr von einer Froyo Firmware kommt und auch einen Froyo Bootloader habt
(also vorher auch keine Gingerbread Version drauf hattet). Falls ihr das nicht sicher wisst, flasht JPU
[[[ DOWNLOAD ]]]
mit Odin (mit 512er Pit und Re-Partition an). Wie das geht? Siehe hier ->[[[ KLICK ]]]
zunächst diese 4 Dateien
  • initial.zip ( notwendige Kernels und EFS Backup, nach dem Download ENTPACKEN) )
dann wie folgt vorgehen
  1. Alle Datein (außer cm7-galaxys-initial-kernel.tar & speedmod-kernel-k13c-500hz.tar) auf die interne SD kopieren
  2. speedmod-kernel-k13c-500hz.tar als PDA mit Odin flashen (KEIN Repartition) und warten bis das Handy neu gestartet ist
  3. Handy ausschalten
  4. Mit 3 Tastencombo (Vol. up + Home + Power) ins Recovery Menü starten
  5. galaxys-efsbackup.zip installieren
  6. Akku raus und wieder rein
  7. Mit 3 Tastencombo (Vol. down + Home + Power) ins Download Menü
  8. Mit Odin cm7-galaxys-initial-kernel.tar als PDA flashen (KEIN Auto Reboot und KEIN Re-Partition)
  9. USB-Kabel entfernen und aus dem Download Modus mit der 3 Tastencombo (Vol. up + Home + Power) ins Recovery Menü starten
  10. Unter "mounts & storage" system, data und cache formatieren
  11. GalaxySense installieren
  12. Fertig
Update installieren von CM7/MIUI aus:
zunächst herunterladen
  1. Aktuelles Realise auf die interne SD kopieren
  2. Unter "mounts & storage" system, data, cache & datadata formatieren
  3. BOYPPC-SHIFTPDA GALAXY S GINGER installieren
  4. Fertig
Weitere Nutzbare Modems:
>>>Klick<<<
(die "cm7-galaxys-radio-xxx.zip Dateien)
Kernel:
Zacharias , Glitch , Bilboa
Habe es selbst noch nicht getestet. Viel Spaß beim Flashen!
Reserviert
Kann ich dieses Rom einfach über das Goa Rom aufspielen?
Und muss Ich vorher etwas beachten??
Habe Gingerbread 2.3.3. drauf und das filessystem auf ext4 sowie den damian kernel CF-Root-XW_NEE_JVH-v3.2-CWM3RFS drauf.
Wie ist die Speed von diesem Rom ?
Wie Eingangs geschrieben, habe es selbst noch nicht geflasht!
Am besten bei xda nachschauen, was es weiteres zu beachten gibt.
Nachtrag: Habe den Installationshinweis erweitert!
es ist CM7 oder MIUi
also sind die gleichen Schritte zur Vorbereitung nötig !
Steht oben in Post 1!
[[[ DOWNLOAD ]]]
zunächst diese 4 Dateien herunterladen
Danke ,
habe es heut morgen gelesen, stand gestern abend jedoch noch nicht da :winki:
Was sind denn das für Wetter Widgets?
Gefällt mir eigentlich sehr gut, wer aber nur nach dem Style geht, kann sich eigentlich auch das Theme Honeycomb auf CyanogenMod installieren. ;)
Sieht nach Go Weather aus. ;-)
Reaktionen: PJF16
Ich hab ein paar Probleme mit dem Mod. Einerseits werden Youtubevideos nur mit Ton aber ohne Bild abgespielt und ausserdem ist die Menuetaste nur noch dazu da um einige wenige Programme zu steuern. Ist da was schief gelaufen?
LG
Tafkam
Hallo tafkam,
welche Variante (MIUI oder CM7) hast Du den genommen, von wo gekommen und
wie bist Du beim Flashen vorgegangen?
kingoftf
Islaris
Islaris
Sattich
scorp182
sgs9000A
sgs9000A
