[ROM - AOSP - Jelly Bean - 4.1.2] MIUI - KingSoft v4 2.11.9 RC2 EN
  • 31 Antworten
Q
quasimodo
Gast
Ich, Android-Hilfe.de oder die Entwickler/Publisher der ROM oder Mods,
übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
Support findet Ausschließlich beim Entwickler King Soft / xda statt
Auch dieses MIUI Mod wollte Ich Euch nicht vorenthalten-
Futures entnehmt Ihr der Change Log
Inhaltsverzeichnis
  1. Installationshinweis
  2. Download Rom
  3. externe Linksverweis zu Mods
Post 2
Change Log
Post 3
Reaktionen: Radagast, efendy46 und tobiasth
Installationshinweise
INSTALLATION JB
Raccomended for Stability: a full wipe data, cache and dalvikcache
Instal kernel Mackay and reboot recovery If have old miui installed(If you have installed CM10 new partition layout installs directly with wipe)
Wipe data factory reset
install
Reboot phone wait a minutes
Reboot
if have problem go in recovery (wipe data factory reset)
reboot
Download
Rom
Mods
Reaktionen: Radagast und tobiasth
CHANGE LOGS
RC2 (Build 13)
Kernel: Mackay_kernel_0.97_VC_BLN/Semaphore_JB_2.5.0sc/Semaphore_JB_2.5.0sv (391MB), support 720P
- browser add a new version of the home page bookmarks and Internet navigation; applications in the App Store have a new version update log; details see MIUI 114 weeks update log
- focus or theme, this week to do a lot of improvements, improve licensing issues, but not all! There are any problems, then please go to BUGLIST look at assisting feedback
Brush open theme style first need to be converted, the conversion time is based on a number of topics of your native storage, the longer the greater the number of multi-conversion time, be patient
- About unlock delay, it seems more or less have VC kernel swap students can replace the color is not interested in non-VC version of the kernel can improve
Build 11
- This week there are a lot of new features: 1, contacts intelligent grouping capabilities and intelligent avatar 2 network SMS support send MMS, Desktop a key Clear gadget
, contacts, text search, the new version of the photo editing function to increase "fisheye", "border" effects see MIUI ROM 2.10.26 Full Changelog (Video) - News - MIUI Official English Site - Redefining Android
- kernel: Mackay_kernel_0.93_BLN/Semaphore_JB_2.4.5sc/Semaphore_JB_2.4.4sv (392MB), ROM support 720P
- period of time then consider joining the center, follow-up adjustment, after all I have to change a lot of code increments; additional software is consistent with the previous version!
-MultiLang flash from cwm
RC1
-Added Samsung Apps
-more responsive home button
-- kernel: Semaphore_JB_2.4.0s/Semaphore_JB_2.4.0sc/Semaphore_JB_2 .4.0 sv (392MB), ROM supports 720P
-- Added full samsungized Miui ROM very smooth and stable
--Fixed SU errors
--Added galaxy s3 sounds and s.apps with last touchwizz and modify for best performance on miui rom
- Kernel: Mackay_kernel_0.7_i9000 (389MB) / Devil3_1.6.1_i897_CMC (378MB) ROM support 720P
-ROM for support Devil3 1.6.1 Semaphore 2.2.0 Mackay kernel 0.7 and above, the Build 8 version of the previous ROM Do not brush the latest kernel
- using the new CM10 partition, software installation partition using a different way, the size of 1.45G, solve many the distress you 422M partition too small
- fix desktop can adjust the size of the plug-FC; to increase MIUI voice assistant dialect function; new camera UI, comes with new RE Manager UI ( From MIUI )
- the built-QingsBox (time centered), super mount D nuclear control software (to facilitate using the D nucleus Friends of the machine), DSP management , weather and game center update
- added GNEX libs from lastest rom for Sprint
- added MultiLanguage as ADDON
Build 9 Coming Soon!
http://www.youtube.com/watch?feature=player_embedded&v=tYpelHKA2v4
CHANGELOGS
Build 9
- Android 4.1.2 see changelogs MIUI ROM 2.10.12 Full Changelog (VIDEO) - News - MIUI Official English Site - Redefining Android
-T959 added in Beta stage .
- the kernel: Semaphore_JB_2.3.0s/Semaphore_JB_2.3.0sc/Semaphore_JB_2.3.0sv (392MB) ROM support 720P
- Repair photo frame widget no method to replace the picture new basis of sound Beats Audio optimization phone T9 search can switch between the "alphabet" and "phonetic"
- Removed Qings.OGG audio and reworked his base
Reaktionen: efendy46
Build 9 ist Online - Siehe Post 2!
Danke quasi echt Super Rom :thumbup: bis jetztz der beste JB MIUI was ich probiert habe...aber wie hast su den build 9 auf deutsch.übersetz
bei mir ist Englisch und chinesich:mad:
Hallo efendy46,
Deutsch ist nur das von Sammy System,
Englisch von MIUI kommend.
Mir ist auch ein Rätsel warum der Entwickler es als Multi bezeichnet.
Eventuell bezieht es sich auf ein noch kommendes Update (reine Vermutung).
Paar Screenhots von meiner seits bin şehr begeistert von dieser Rom und Theme:thumbup:
Sent from my GT-I9000 using Tapatalk 2
Was ist das denn für ein Theme.
Verstehe ich das richtig, das die >Rom< nicht auf Deutsch ist.
Hallo leider ist der Rom noch nur Englisch und Chinesisch:mad:... zu den Thema...habe ich heute zufällig bei xda gefunden "Metall v2" heisst der echo seeeehr gelungene Thema
efendy46 schrieb:
Hallo leider ist der Rom noch nur Englisch und Chinesisch:mad:... zu den Thema...habe ich heute zufällig bei xda gefunden "Metall v2" heisst der ec.ht seeeehr gelungene Thema
Reaktionen: Radagast und DarkAngel1971
Naja...dann heißt es warten, bis da etwas deutsches angeboten wird...:eek:
Gibt es diesbezüglich schon irgendwelche Infos?
Gesendet von meinem GT-I9000 mit Tapatalk 2
So, nun habe ich die Rom seit einigen Stunden getestet.
Mein Fazit: alles in allem gelungen. Kompass will nicht richtig funktionieren und bei der QingS Box hatte ich 2FC's...
Man wird aber durch die sehr weiche Oberfläche und die schnelligkeit der Rom entschädigt. Wenn man davon eigentlich sprechen darf.:rolleyes:
Highlight ist für mich das Theme von Efendy.:thumbup:
King's bringt laut meiner Info bei XDA schon bald ein neues Update. Hoffentlich ist dann auch mit einem deutschen Sprachpaket zu rechnen!
Sent from my GT-I9000 using Xparent SkyBlue Tapatalk 2
Update befindet sich im Upload!
mit Mühe und Not herunter geladen:cursing:....sehr smooth sehr butter:ohmy: wie versprochen:thumbup: aber problem mit Themen .....sie werden nicht komplett übernommen...helle Hintergrund usw...gibt es Lösung....bin wieder zurück build 9
Habe den Dev mal direkt auf XDA auf die Problematik angeschrieben.
Hoffe es gibt bald eine Lösung.
Bin auch erstmal wieder auf v9 zurück!
Build RC1 ist raus ...
Download:
http://www.wuala.com/KingSoftROM/Documents/KingSoft_for_I9000_RC1.zip/
Changelog
RC1
-Added Samsung Apps
--Fixed SU errors
zɘlυ;;я мoя-ɔ* -* zelnɹ ɯoɹ-ɔ* -* C-RoM rulez
Der Download Link lässt sich derzeit aber nicht öffnen!
Edit:
Bei Firefox nicht bei einem anderen Browser schon.
Ziehe Euch noch ein Mirror, so wie der Download abgeschlossen ist.
Dauert aber eventuell ein Stunde!
Habe gestern Nacht herunter......echt sehr schnell der RC 1 aber Probleme mit Themen gehabt.....gibts da eine Lösung oder fix...?
efendy's i9000
