[ROM][AOSP][4.2.2] LiquidSmooth v2.9 B2 12.07
  • 61 Antworten
Glatzi84
Dauer-User
601
LiquidSmooth
Original Thread <--- für Credits und Spenden​
Das ist eine Smoothe, Schnelle und Stabile AOSP Rom.
Zu dem ist sie eine schnelle und leichte (unnötige sachen entfernt) AOSP Basis mit diversen Features.
Feature
Google GCC 4.7 Toolchain
O3
Strict-Aliasing (Linaro)
C++11 Mode
Optimized String Handling Routines (Linaro/Sony)
Misc other Linaro and Code Aurora Optimaztions
Customizable lockscreen buttons and sliders
Chronus clock widget
Customizable hardware and software keys
Transparent navbar and status bar
Customizable navbar ring
Navigation bar widgets
Customizable power menu
Notification power widget
Customizable quicksettings panel
Statusbar mods
Theme engine
Quiet hours
Volume rocker music controls
Full Rotation
Customizable battery and notification light
Changelog 2.9
SaberMod GCC 4.7
-O3 Optimizations
Don't enable GPS if the requesting app is blacklisted.
Add permission that allows cancelling notifications from other apps.
Notification cancellation fixes
Ensure install-during-restore is like install-then-restore
libdrm: fix bad strncpy / snprintf calls
Make contacts app aware of blacklist being disabled
Frameworks: a bit taste of android 4.3
Frameworks: add reset option to clock color and cleanup
Frameworks: activate qs and notifications toggle for navring
Correctly release lockscreen lock on tile destroy
Add an option to allow a (subtle) notification vibration during calls.
NotificationManager : Fix security exception
Frameworks: privacy guard fix UI freeze
Prevent notification acces via HALO on protected lockscreens
HALO: keep apps in recents
HALO: halo can save last position now
HALO: Minimal Style
HALO: Master Switch
HALO: Custom Colors
SMS: add middleware layer
Add Statusbar Quick Peek
Frameworks: Privacy Guard
Profiles: Add bluetooth triggers
FIx: Phablet UI NavBar in landscape
Profiles: Add 2g/3g connection option
Profiles: Add a profile picker activity
Speed up statusbar/notification drawer
Use sticky broadcast to convey torch state
Keep notification LED on while daydreaming
Add Settings shortcut to Interface Settings Activity
WebSettings: Move Liquid tag to the end of the user-agent
Show application's package name in the "App info" screen
Settings: fixed HALO options so now they stick and function
Close notification panel when swiping away the last clearable
Frameworks: Reduce Navbar, Navrings, Slimpie observer footprints
Don't bring home to the front if we're opening a floating activity
Profiles: Fix turning bluetooth on/off when its in intermediate state
Settings: Rename 'Power sounds' to 'Charging sounds' and add summary
And Many More..
Download
Reaktionen: pjozsef54, Trucker1109, wuerfel und 2 andere
Update ist da...
Ich frage mich wie stabil es auf dem s1 rennt?
Nutze es als 2t Rom auf S2 und bin bis jetzt damit zu friden! :D:D:D:D
GT-i9100 ≥>cm 10.1-dori 9.13/sec.rom Liquidsmooth v2.1≤≤ Tapatalk 2
Also viele auf XDA berichten das sie recht gut läuft... :biggrin:
Hat hier irgendwer die Rom drauf? Bekomme gleich nach der Installation einen Force Close vom Trebuchet. Die Rom ist somit komplett unbrauchbar.
Habe verschiedenste Wege probiert.
Sofort von 2.3.6 drüber gebügelt.
Von 2.3.6 über CM10.
Von 2.3.6 über CM 10 über Mackay.
Immer mit allen Wipes. :confused2:
2.2 ist draußen wird nachher in post 1 eingefügt
Der ursprüngliche Beitrag von 19:53 Uhr wurde um 21:23 Uhr ergänzt:
So Post 1 ist aktuell
Reaktionen: Radagast
Rom wurde neu hoch geladen und im Post 1 ist ein neuer Link
Wie ist denn der Akkuverbrauch so?
Warum finde ich im s2 Bereich nix über liquid???
Finde nur für s1 s3 HTC und so weiter komisch oder bin ich blind?
GT-i9100 ≥>cm 10.1-dori 9.13/sec.rom Liquidsmooth v2.2≤≤
SGS1 >>Xbean 3.0<<
Tapatalk 2 *****
Update auf v3 :scared:
Update auf V4 in Post 1
Hab sie gerade geflasht und bin wirklich sehr überrascht. Sie läuft sehr flüssig und das einrichten klappte sehr schnell und problemlos für das erste...
Macht ihren Namen immo alle Ehre :thumbup:
Bin an einem kleinen Bericht von dir interessieren wie sie allgemein so rennt.
Überlege noch ob ich sie auf mein s1 machen soll den auf dem S2 is sie der Hammer!
GT-i9100 ≥>cm 10.1-dori 9.14/sec.rom Liquidsmooth v2.2≤≤
SGS1 >>Xbean 3.0
Im groben :D
Sie läuft im ganzen und bei mir im Alltag sehr gut und zuverlässig.
Mehr brauch man nicht sagen. ;)
Ok dachte ich mir schon werde sie die tage mal selber testen.
SGS-1≥>X-bean 3.0
Tapa 2
Update ist da... V2.3 :thumbsup:
bin mal gespannt, die vorherige Version lief Super...
Nehme mal an diese rom ist fast gleich fit der carbon rom,die devs sind dort auch teilweise.aber kein pa oder ähnliches dabei wie ich annehme?
Hat jemand einen Vergleich zum CyanAOSP Rom, was ja auch zu den schnellsten Roms gehören soll?
Jemand schon die 2.5 drauf?
Gesendet von meinem GT-I9100*TURBO mit Tapatalk 2
Wo gibt es die den? Hab noch keine v2.5 gesichtet... Nur das aways demnächst ein update bringt.
kingoftf
Islaris
Islaris
scorp182
SGS-Ultra
SGS-Ultra
tobiasth
  • Angepinnt
  • tobiasth
26 27 28
djfelix
