[ROM][AOKP] Tsunami X 5.6 [03.07]
  • 252 Antworten
Glatzi84
Dauer-User
601
Original-Thread bei Androidiani.com
HIER
XDA-Link
HIER
Offiziele Rom auf AOKP Basis
Offizielle Neuigkeiten hier AOKP Official
und vom Team TSUNAMI hier Tsunami official
Features
  • Base AOKP build android 4.2.2
  • Kernel SEMAPHORE
  • HugeMem Patch (396 or 404 MB)
  • GAPPS Inverted
  • Faster FIX GPS
  • System Tweaks
  • Fix APN
  • Fix AOSP Keyboard
  • Patch video 720p
  • Google Apps Updated
  • Nova Launcher
  • Themes x Theme Chooser
  • Titanium Backup
  • ES Explorer
  • QuickPic
  • MX Player
  • Notification weather
  • Google Music inverted
  • Theme X-Wish S3
  • Taskmanager Galaxy S3
  • Sms Pop-Up - CM10 Style
  • New Bootanimation
  • multi-DPI support
  • OTA in Setting menù
Changelog Tsunami X 5.6
    • Base AOKP Merged (30 June 2013)- new Kernel SEMAPHORE 3.0.0S
      - new ram manager Fly-On 3.0
      - new System LIB
      - new scripts
      - GMAIL 4.5.2 inverted
      - new youtube inverted (3G mod)
      - new Google music inverted
      - NEW Google Now Inverted
      - new Play Store inverted
      - New functions from AOKP
      - Sound from HTC ONE X (ringtones, allarms)
      - New Camera and Gallery from Android 4.3
      new addons in Tsunami rom Comtrol
      – change backgroung for notification
      – change background for lockscreen
      – superuser in menu setting
      – CRT animation mode
      – toggle style (traditional or tile)
      – Ribbon
      – Change UI
      – call statistic
    • add Dashclock
    • add kill button
    • chronus from cm10.1
    • change tweaks for performance
    • new Hangout
    • new Google music inverted
    • new function for CAMERA (HDR)
    • fix many bugs
    • Faster FIX GPS
    • System Tweaks
    • Fix APN
    • Fix AOSP Keyboard
    • Patch video 720p
    • Nova Launcher
    • Titanium Backup
    • ES Explorer
    • QuickPic
    • MX Player
    • Theme X-Wish S3
    • Sms Pop-Up
    • answer with home button
Installation
Kommend von einer Jelly Bean Rom:
  • Download ROM
  • Wipe Data
  • Wipe Dalvik/Cache
  • Format System/Cache/Data/
  • Flash rom
  • Reboot!!
Kommend von GB oder ICS:
  • Download ROM
  • Flash ROM Tsunami X JB
  • Bootloop from change recovery
  • Remove Battery
  • Reboot into recovery
  • Wipe Data
  • Wipe Dalvik/Cache
  • Flash rom
  • Reboot!!
DOWNLOAD
TSUNAMI X 5.6 Galaxy S GT-I9000
Sollte jemand den Download von der Originalseite nicht Downloaden können, muss einen Rechts klick auf den Download machen und ''in einen neuen Link öffnen'' auswählen!
Credits:
  • Robinrg86 -Team TSUNAMI
  • MALCHO (for build AOKP... every day)
  • Romann and the Team AOKP
  • TeamHacksung
  • Aquariusoft
  • Sixstringsg
  • Stratosk
  • DerTeufel
  • Perka
  • Pawitp
  • mnazim
  • KINO87
    And many thanks from Team Tsunami for donations:
  • diddsen
  • hadkeren
  • Doreen (I don't know the nick)
  • mindphaser2k9
  • master_og
  • rad007
Reaktionen: MonkyBong, DJ-Fastfire, FCB-Fan und 5 andere
Später für Changelogs, weitere Screenies usw
Changelog
V3.2
  • Base AOKP Merged (10 nov 2012)
  • DEVIL kernel 1.8.1
  • Playstore inverted 3.9.17 (from android 4.2)
  • GMail 4.2
  • Launcher 4.2
  • Keyboard Android 4.2 with swype
  • DesClock 4.2
  • Google Music 4.2
  • DSP Manager
  • GoogleNow 4.2
  • Fix TaskManager
  • New patch for service and framework
  • New patch for Host file
  • Sound from Galaxy Nexus 4
  • New lockscreen OPTIMUS 4 (enabl from setting menu – security – CIRCLE
  • Fix Dalwik memory management
  • Add customizable options for Circles Lockscreen
  • Add group mms threading
  • add hardware info
  • Add setting to set Circles Lockscreen
  • Add themes support to Mms (ala handcent theme ability)
  • core and telephony: Additional HSPAP support
  • Default device volumes not initialised
  • fix aspect ratio for notification wallpaper
  • Fix multiple haptic feedback while switching Toggles
  • Fix volume track skip control with 3rd party applications
  • Lefty Mode for NavBar
  • Lockscreen: Add Circles Lockscreen to AOKP
  • NavRing: Long press actions
  • Notification: add option to show connected wifi network
  • Restore correct volumes when headset is plugged
  • ROMControl Widget Fixes
  • ROMControl: Ability to set navbar width/height to 0
  • Set Stock music layout for Lockscreen while enabling Circles style
  • Suppress String resources build warnings
  • SystemUI – fix Kill App
  • SystemUI: Cog Circle Mod Battery
  • SystemUI: Fix NavRing inflate
  • SystemUI:Widgets fix & Class Move
  • telephony: neighboring cells are now handled properly
  • TransportControl: Remove unnecessary check, also #blamexoomdev
  • UserInterface: apply build.prop edit to fully remove bootanimation
  • Weather panel actions and clock/date derp
  • Weather panel: Redo click options and add longclick
  • WeatherPanel: Add options to hide weather panel
Ältere Versionen:
Version X 2.0
- Base AOKP Build 4
- New partition (system 400 mega, data 1.4 giga, datadata 400 mega)
- fix mount sd ext
- fix toggle (data hotspot, tethring)
- updated system library
- Tweaks for ramdisk, ram management (framework)
- many tweaks in BUILD.PROP
- new Bootnamation (ahhaha I change every build....)
- New option in phone (internet call....)
- Add Awesome BEATS audio and propretary libs
mmmmh... I'dont remember.....
Version X 1.5
- New base AOKP Build 3
- Patch EXINOS3 like CM10
- ADOBE Flash Player for Jelly Bean
- Kernel SEMAPHORE 2.1.2 HUGEMEM
- Semaphore Manager 1.1
- New Bootanimation
- New Calculator
- New clock (timer, countdown)
- New SupereUser by Chainfire
- Weather widget S3 for any Launcher
- New app for find Theme
- New App ThinkFree
- New tweaks Build prop
- New MEMO app from galaxy S3
- Patch Framework and service jar for memory management
- Library patched for HUGEMEM
- New mod for Keyboard
- Mod icons S3 style for launcher
- New task Manager
- fix for APN
- Fix for GPS
- many system fixs
- patch for video playback
- many addon in OTA
- Galaxy S3 clock
- MMS inverted AOSP
- MMS inverted - long message (no split)
- AROMA GAPPS for normal and inverted
- Sony XPERIA S Walkman
- Sony XPERIA Keyboard
- Many Bootanimations
- Many Fonts
- Kernel DEVIL 1.5.4 bln
- Kernel Cyanogen
- 4 themes for Weather
- Many porting from Galaxy S3
- VOODOO Sound
- Holo theme for theme chooser
- many battery
- TouchWix UX Launcher from Glaxy S3
- Theme for Swith
- Samsung App Store
- MIUI Compass
- SWIPE keyboard
- Spirit Radio FM
- AngryGPS
- MIUI Launcher
- New Modems
TSUNAMI X 1.1:
- new script for move to system partition from data.... automatic mode
- notification bar transparent (50%)
- updated library for HUGEMEM
- many fix
- new themes
- new addon in OTA
- new tweaks for service jar and framework
- updated many app
- fix gallery for video playback
- new semaphore 2.1.0s
- new tweks for build prop
- add porting from galaxy NOTE 2 and galaxy S3
.... and much more
TSUNAMI X 1.0:
AOKP offiacial Build
New MMS porting and inverted
New Playstore and Google Framework Service Patched for multidpi
New Google Talk Inverted
Updated all app aviable
Fix APN - automatic config
Fix GPS
Tweaks system and framework
Add:
- SEMAPHORE 2.1.0
- Semaphore Kernel Manager
- Dsp Manager
- Kit Auto
- New calculator
- More graphics change
- New themes
From AOKP
Kill all button in Recents panel
Backlight settings
Tablet UI
DPI switcher
Custom Vibrations for Phone Calls
ADB over network
Volume music controls
Boot animation preview
Power menu options (airplane, screenshot, navbar toggle)
Hide signal bars
WiFi & Cell signal text
Version X 0.1
Changelog from X0.0 and X0.1
- FIx video playback
- Tnew theme like TsunamICS
- Update Me place in Setting menù
- Update system library
- update google apps
- Fix exchange problem
- SMS pop-up like CM10
- Tweaks for stability and velocity.... and battery life
Screenshots
Reaktionen: beicuxhaven
[*]Riavviare --> Starten !!!
..... Ich fand 2 in Update FIX heruntergeladen werden kann und flasharli (?)
Was ist damit gemeint und zu was sind die fixes ?
Und ist dies auch auf deutsch ?
Gesendet von meinem GT-I9000 mit Tapatalk 2
Gute Frage, kann ich Die zur Zeit nicht beantworten, bin jetzt erstmal auf einer anderen Rom, schaue bald nochmal ...
B.v.t. - TapatalK - .t.v.B
Hallo zusammen, die Rom ist auf deutsch. Hab sie gestern mal angetestet. Läuft sehr flüssig das
Ganze. Was mich persönlich stört, dass manche Apps auch mit einem Root Uninstaller nicht gelöscht werden können.
@ Bvt: da ist er ;-)
Reaktionen: Radagast
Kannst titanium versuchen um was zu löschen
Glückwunsch ;-)
Für die anderen: ist ein Insider ...:D
@pannes
@bvt
kannst du mal einen benchmark machen und hier einstellen?
Leider sind die Benchmark-Bilder weg, aber von der Rom habe ich einige, die kommen heute abend.
Kann per Tapatalk kein Bilder mehr einstellen, ohne zu bezahlen ... App gekauft, andere Rom geflasht, App weg :confused:
So habe die ROM jetzt auch drauf, läuft wirklich sehr - wie man es ja gewohnt ist! :)
Bloss das einzige was mir auffällt ist, dass ich die Einstellung nicht finde, womit ich Apps beenden kann mit länger drücken des Zurück-Buttons!
Das sollte unter Rom-Control sein, bei einem der Punkte 'Allgemein', ob nun beim ersten (Benutzeroberfläche) oder zweiten (weiß gerade nicht, wie der Menü-Punkt heißt) weiß ich nicht...
Edit:
Hmm, habe das wohl mit den ICS-Rom-Control-Einstellungen verwechselt, den Punkt, den ich meine, gitb es nicht.
Habe es so auf die Schnelle auch nicht gefunden, sorry
Einzige Möglichkeit, da ich wieder mal was anderes probieren wollte und Tsunami eben nicht drauf habe:
Entwickler-Optionen --> gaanz unten "App beenden", ist der Eintrag da? Andere Roms haben das da, wenn Tsunami das nicht hat, weiß ich auch nicht weiter ...
Update ist da, nun heißt die Rom nicht mehr XX 0.0 Alpha sondern X 0.1 ...
DL-Link:
http://d-h.st/R3k
Änderungen u.a. Devil-Kernel 1.4.1 ...
Post 1 ist bereits angepaßt ...
P.s.: Multi Mount SD-Card lite ist bereits vorinstalliert ....
Der Devil 1.4.1 ist nicht vorinstalliert, sondern der Sema 2.0.6
Den Devil dann einfach via Tsunami OTA (in Einstellungen) herunterladen
Viel Spaß
Edit:
Die Themes laufen auch und sehen nett aus, werde da noch Screenshots posten ...
ich find die rom läuft schon super smooth, aber mit der Speicherverwaltung komm ich überhaupt nicht klar. Ich fühl mich, als hät ich eins der ersten HTC´s in der hand, wo man alles auf die SD verschieben muss, weil der interne Speicher zu klein ist, schade
Vielleicht wird da ja noch das ein oder andere passieren bei den JB-Ports, die sind ja noch recht frisch ...
Dafür hat Xlory, der Dev, zugesagt, er werde u. a. die Screenshot-Funktion im Powerbutton-Menü mit aufnehmen --> hatte ich im heute eröffneten XDA-Thread erfragt.
Wer auch bei XDA mitlesen will:
H I E R
Werde ich im 1. Post auch mit aufnehmen
So, mal janz langsam hier. Ich habe es noch nicht mal geschafft die 0.0 zu installieren und schon ist die 0.1 Version am Start? Geht gar nicht! Also, ich teste die jetzt mal an...
Der ursprüngliche Beitrag von 09:21 Uhr wurde um 10:04 Uhr ergänzt:
Erstes RESUMÉ
Installation: Problemlos von GB kommend, zwar bootloop, aber akku raus, start ins RECOVERY, noch mal flash beginnen und gut...
ext. SD-Karte: Das ist doch sehr verwirrend, zumal es da bei den anderen ROMs KEINE Probleme mit mounten gibt..
Sehr flüssig alles...
So habe jetzt auch das update drauf... läuft sehr gut!
Das einzige was stört, sind jetzt bei euch die Smiley's auch so riesen groß? Also in der SMS...
Was ich zu der Rom sagen kann. Es hat das beste GPS aller JB-Roms.:D
Schön ist auch das man verschiedene DPI Auflösungen OTA runter laden kann.
Montag wird voraussichtlich die neue Version kommen, Changelog bei Facebook, ganz unten im ersten Post bei XDA ist der Link, keine Lust mehr jetzt, das zu kopieren ;)
Gute Nacht ...
Reaktionen: Wassilis, efendy46, SGS_Fan und eine weitere Person
Wo stellt man Benachrichtigungstöne auf lautlos. Finde ich nicht.
Reaktionen: DarkAngel1971 und Radagast
