Bödi
Philosoph
- 6.180
A C H T U N G ::
Das Herunterladen und Flashen/Installieren der Roms erfolgt selbstverständlich auf eigene Gefahr und weder ich noch android-hilfe.de noch der Entwickler dieser Roms oder bspw. der Base (Slim Bean)haften für Schäden, die an eurem Handy entstehen könnten.
:: System ::
Code:
[LIST]
[*]Android 4.2.2 Jelly Bean (JDQ39 - Android-4.2.2_r1)
[*]Latest CM Kernel
[*]All Jelly Bean Features and Apps (Nothing excluded from AOSP)
%5†Ý·kìm˜ÙyûÇùŠÛ¨_ Changes!
[*]Stock Jelly Bean Look and Feel
[*]This will turn your Samsung Galaxy S into a Nexus 4 :p
[/LIST]
:: Features ::
Code:
Fully Deodexed
Zipaligned APKs
Rooted (Super SU)
BusyBox Installed
No 3rd Party App
ZERO Bloatware
Android Source Code vastly improved and optimized (i.e. Bionic, Dalvik, Webkit, Framework, libcore, SQlite etc)
Official Jelly Bean Bootanimation (From Official Galaxy Nexus Android 4.2.1 Factory Image)
Init.d Support
Rsync Support
UserInit Support
Bash & Nano Support
Native SIP/VOIP Support
OpenSSH Support (ssh, sshd, scp, stfp)
HSPA+ Support
OpenVPN Support
Ad-Hoc Network Support
EXT4 File System Optimizations
Galaxy S Device Settings As An App
Large APN & SPN List
Framework Features:
-Extended Power Menu (Reboot, Recovery, Download & Screenshot Options)
-Improved Scrolling Cache
-Tweaked Animation Values Of Progress Spinners (Silky Smooth Loading Spinners)
-Enabled Rotation Lock Tile in Quick Settings for Phones (Previously was only enabled on Tablets)
-Increased Lockscreen Widget limit from 5 to 9
-Enabled Copy/Paste in Gtalk
-Options for switching between USB Mass Storage and MTP/PTP (On Specific Devices)
Camera Features:
-Burst Shot (Up to 20 Images at once)
-ISO Mode
-Touch Focus Duration
-Power Shutter (Click Power Button To Capture Image/Video)
-Color Effects
-Shutter Timer
-Zero-Shutter Lag (On Specific devices)
-Control Zoom using Volume keys
-Touch-to-focus timeout duration settings
-Exposure and JPEG Quality settings in Video Mode
-HDR (High-dynamic-range imaging)
Browser Features:
-Increased Maximum Tab limit from 16 to 64
-Incognito Tab Option (When long pressed on an URL)
-Option To Close All Tabs With One-Click
-Allowed Any Type Of File To Be Downloaded
-Enabled WebGL (Ultra smooth browsing)
-HTML5 WebSockets
Phone Features:
-T9 Dialer Support
-Landscape Dialer Support
-Transparency To Incall Screen
-Noise Suppression
Miscellaneous Features:
-Allowed Installation Of Apps From Unknown Sources By Default
-Allowed Any Type Of File To Be Sent/Received Via Bluetooth
-Disabled Data Roaming By Default
-Removed Google's Software Updates Option from Settings
-Enabled Gesture Input By default
-Hardware Information of the device (Settings>About Device>Hardware Information)
:: Changelog ::
SuperNexus 2.0 Milestone 1 (01-06-13) Changelog:
- Updated source code to Android-4.2.2_r1.2 (JDQ39E)
- Updated APN List
- Updated SuperSU to v1.30
- Added official device support for Samsung Captivate
- Added official device support for Samsung Vibrant
- Changed Kernel to Semaphore
- Camera: Added support for Storage Location (Internal SD Card, External SD Card & USB OTG)
- Camera: Many translations
- Camera: Many fixes and code cleanup
- Dalvik: Tons of optimizations from AOSP's master branch
- Framework: Optimizations and minor fixes
- Framework: RIL Fixes
- Skia: Optimizations from AOSP's master branch
:: Installation ::
Von GB 2.3.x/Samsung Firmware kommend:
Jetzt solltest du ein funktionierendes aber nacktes CyanogenMod haben, das jetzt direkt wieder platt gemacht wird. Super Nexus installierst du nun wie folgt...
- CM von HIER runterladen, Super Nexus aus diesem Thread hier runterladen; Gapps von HIER runterladen.
- Daten sichern (Apps z.B. mit Titanium, SMS-Backup etc.)
- Boot ins Recovery/CWM
- Backup anlegen !!!
- Wipe data/factory reset (damit werden Apps & Einstellungen gelöscht)
- Wipe cache partition
- Advanced -> Wipe dalvik cache
- Mounts and storage -> Format /system
- install ZIP from SDCard
- CyanogenMod-ZIP auswählen (könnte etwas dauern - falls es sehr schnell geht [also ca. 5 Sekunden oder schneller] die CyanogenMod-ZIP nochmal flashen. Schritt 9 & 10 dreimal wiederholen!)
- Gapps flashen
- dann Reboot system auswählen, abwarten, Google-Account einrichten (aber keine Backups wiederherstellen)
- Reboot ins Recovery/CWM
- Super Nexus ZIP-Datei auswählen (Gapps sind schon mit drin und müssen nicht separat installiert werden)
- Reboot system (dauert etwas)
Von ICS/JB kommend:
:: Download ::
Hotfile: Milestone 1 (02.06.2013) (MD5: 0B4A68FA87D6FECA9606D030A2E31299)
Gapps (01.03.2013)
