MIUI V4 for i9000 by Andy Thomson [MIUI England] & DE/EN Mod by mmuuhh
  • 57 Antworten
Q
quasimodo
Gast
Ich oder Android-Hilfe.de übernehmen keine Haftung dafür! Ihr seid für euer Handeln selbst verantwortlich!!!
Hi All
If like me you're frustrated that the i9000 seems to have been overlooked when it comes to the latest MIUI v4 goodness, then this is the ROM for you.
I've used the MIUIANDROID Nexus S ROM as a base and ported it to the i9000.
A big thanks to Mark and the Team for giving permission for me to release this to the world.
I hope you like it? It's by no means perfect, but it's getting there..
If it proves popular then I intended to build in my Extended Settings MOD. I've already added my version of the Extended Power Menu and modded the Launcher slightly.
KLICK
Meine letzten aktuellen Screenshots
Hier könnt Ihr die letzten Beiträge im Vorgänger- Beitrag (der geschlossen wird) verfolgen!
MIUI V4 for i9000 Latest Version 2.4.20 [Neu EnDe Fullrom 1.4.21] - Update to 4.0.4
Inhaltsverzeichnis
Post 1
Installation Instructions :-
Upgrading from Gingerbread MIUI.
  • Reboot into Recovery using 3-button-combo (VolumeUp+Home+Power)
  • Do a Nandroid Backup or your choice backup application (optional)
  • WIPE (wipe data/factory reset + wipe cache partition)
  • Install the ROM from internal sdcard
  • At this point it will restart and continue boot looping – DO NOT PANIC!!
  • Install the ROM from internal sdcard a second time.
  • Done/reboot
The ROM comes with the excellent Devil Kernel, but feel free to flash a different one if you want.
Rom
Sprachpaket für (Andy's) MIUI V4 by Benson 17
Custom Kernels
Modems
ICS Tipps & Tricks - Wissenswertes / Know How - Liste Mods, Fixes
MIUI Themes
Changelog [ICS]
Post 2 DE/EN Mod von mmuuhh
Post 3 Reserve mmuuhh
Post 4 Reserve
Post 5 Archiv
Reaktionen: tjengo und -MaD-
Languagepack 2.5.11
nur mehr einen KLICK entfernt!
bitte zuerst die original rom installieren und das telefon starten. dann erst den LP!
falls superuser nicht funktioniert zuerst app installieren und dann cache&dalvic wipen
externe sd-karte wird nach installation des LP nicht erkannt
da die apps vom nexus s importiert wurden bitte keinesfalls ein onlineupdate durchführen!
Reaktionen: Radagast, vivanco, sUsH667 und 3 andere
mmuhh reserve
Reserve 1
Leute,
sieht wirklich sehr gut aus - kriege aber die externe SD nicht zum laufen (weder im internen Dateibrowser sichtbar, noch am PC) :confused2:
Kann bitte einer kurz helfen ob das bei dieser Version normal ist...
PS: Habe jetzt mal als Gegenprobe die orig. 2.4.21 + Multilanguage Pack installiert und habe dort die Probleme nicht!
DANKE!
Hallo
Ich habe Andy's miui v4 2.4.21 geflasht!!
Und habe das problem das es mir mein Netz immer von selbst auf roaming umstellt auch wenn ich nicht auf automatische netzsuche bin.. Dann hab ich mal den telefonstatus angeschaut und festgestellt das unter Netzwerk unbekannt steht der rest ist aber in ordnung
kann mir bitte jemand sagen woran das liegen könnte und mir villeicht helfen ??
Mfg
Gesendet von meinem GT-I9000 mit Tapatalk
hab die rom jetzt auch geflashed, wie bekomm ich da eine deutsche sprachdatei drauf ? oder gibts die gar nicht ?
lp für 2.4.27 steht zum download bereit.
Reaktionen: tjengo, MayJay, skodaslx und eine weitere Person
Ist das lp für odex oder deodexed?
Oder spielt das keine Rolle?
gibt es iwo einen superuser fix zum flashen? funzt bei mir auf der 2.4.27 nicht
Gesendet von meinem GT-I9000 mit Tapatalk 2
Superuser 3.0.7 <<<DOWNLOAD>>>
Wird gleich mal in Post 1 verlinkt, so das andere betroffene Zugriff haben
Reaktionen: alex13
Funktioniert das Languagepack von der ersten Seite auch mit der aktuellen Version 2.5.4?
(oder muss auf eine angepasste Version von mmuuhh gewartet werden...?)
Hallo LaCroatino, das Sprachpaket wird mit jedem Update angepasst, das Vorgänger kann daher nicht genutzt werden.
Danke für die pfeilschnelle Antwort - ich wart´ gerne auf´s angepasste Sprachpaket. :thumbsup:
lp 2.5.4 steht im zweiten post zum download bereit!
auch diesesmal gibts die bereits bekannten fehler:
superuser fix wird benötigt & externe SD wird nicht erkannt
Reaktionen: nataschk, snowtear, KeyBlack und eine weitere Person
Hallo
Hab mir mal dein LP drauf geflasht!
Und festgestellt das Ics Control app nicht mehr geht und die Email app ein fc bekommt wenn man eine Email öffnen will!!
Sonst läuft alles supper! danke für deine Arbeit :)
KeyBlack schrieb:
...und die Email app ein fc bekommt wenn man eine Email öffnen will...
den Email-Fehler habe ich auch, hat jemand einen Tipp, wie daas zu umgehen ist?
Einfach die app vom originalen rom in das system kopieren mit root explorer!! Ist dann allerdings wider auf englisch
... wenn ich die "originale" email-app in System\app usw. einkopiere, dann kann ich die aber nicht installieren, auch mit schreibberechtigung. Hat jemand noch eine Idee hierzu?
