MIUI Scotland V4 2.6.15 & GB 2.4.17 [18.06.2012] --- KEINE UPDATES MEHR
  • 33 Antworten
2.5.14 Update Online - steht in Post 1 zum Download bereit!
MIUI Scotland Fixes
  • Included English Lockscreen with old lockscreen wallpaper.
  • Improvements to SD Card read and write speeds.
  • Latest Siyan v3.2+ Kenerl for I9100.
  • SD Card fixes to I9000 rom.
  • Improved Framework and Services smali hacks I9000.
  • Improved Bluetooth Audio on I9100 and I9000 builds.
  • Improvements to Contact syncing.
  • Stability tweaks to System.apk and improvements.
  • I997 WIFI Issues Resolved.
  • OS Drain Issue Resolved (Battery calibration - Full charge, then allow to drain and recharge).
  • Gapps issue resolved included Google Gallery.
  • Other small tweaks.
MIUI Scotland 2.5.18 Update Online - steht in Post 1 zum Download bereit!
MIUI Scotland Fixes
  • Tweaks to system for UI improvements.
  • Tweaks to Battery for improved life.
  • Sensor Tweaks.
  • Improved Update handling on I9100.
  • Removed Google Gallery.
Update Version : 2.5.19
Translator : Benson
Language : Multi Language Translation Pack
(arabic, brazilian, czech, danish, dutch, french, german, greek, hebrew, hungarian, italian, korean, persian, polish, portugese, russian, slovak, slovenian, spanish, thai, turkish, vietnamese)
Kann mir bitte jemand sagen was ( S Talk ) heißen soll!!!
Ich habe noch nicht davon erfahren.
Danke
MIUI Scotland 2.5.25 Update Online!
MIUI Scotland Fixes
  • Updated I9100 to latest Siyah Kernel.
  • Improved USB read & write speeds on I9000.
  • Removed unrequired files within I9000 build.
  • Basically a whole rewrite to the I9000 has been done to fix a lot of issues! To many to note here!
  • Correctly implemented sensor tweaks in I9000.
  • Improved WIFI signal.
  • Updated I9000 to latest mnics Kernel (A nice little Kernel with some advanced features!).
  • Improvements to 720p recording on I9000.
  • Fixed battery drain on 3G usage on I9000. (This was a very serious bug, that drained phones in less than an hour!)
  • Removed Google Apps (please download from here)
Reaktionen: mialwe und Radagast
Auch Hier dürfte das neue LP Pack von Benson funktionieren. Zu finden in seinem bei Uns Neu veröffentlichten Beitrag. Erfahrungsberichte kann man auch dort platzieren.
Gesendet von meinem GT-I9000 mit der Android-Hilfe.de App
Update steht in Post 1 zum Download bereit!
MIUI Scotland Fixes I9000 2.5.27
  • Corrected an updater issues.
  • Replaced kernel with CM9 Latest Kernel.
  • Re included Gapps.
  • Corrected Drivers for WIFI, SMS and RIL issues.
  • Corrected an issue with SMS not being sent.
  • Corrected issues with init.d scripts not being read correctly.
  • Improved lag issues within MIUI Home.
  • Fixed issue when entering Music Application and Artists lead to FC.
  • Corrected issues with Sensors not responding.
  • Other small tweaks to prevent bootloop issues.
Reaktionen: Radagast
hallo ich habe ein plm und zwar auf diese video von scootland miui steht sd card unter einstellung 13 gb ich habe unter einstellung nur 5,74 GB was musst ich tun damit ich auch 13 gb habe besitze zwar nicht miui scootland sondern von andy miui 2.5.25 bitte hilf mir.
mfg
windeck
Miui Scotland 2.6.1
Download-Link: Klick mich
Changelog:
MIUI Scotland Fixes
  • I9100 Updated to Latest Siyah Kernel
  • I9000 Small Fixes to RIL issues
  • Version 2 of the I9000 fixes rooting issues, along with a few other bugs.
  • Normal Speed and UI tweaks within Rom
  • Other tweaks to stabilise Rom
MIUI China Fixes
[System]
  • Fix some applications, pressing the back key player gif results in locking
  • Remove the “Disable” button to disable the system applications on app info page to prevent incorrectly shutting down core services which may lead to stability problems
[Phone]
  • Optimise light-sensor strategy to tackle screen lighting issues
  • Optimise (CDMA) call ended still shows the green return to call information
  • Fix problems leading to FC caused by database errors
  • Fix in some cases the answering interface, vertical slide does not show the correct details
[Messaging]
  • Fix creating new message from the contact list of selectable contacts does not disappear after choosing contact(s)
[Lock screen, Status bar and notifications]
  • Added support for displaying music spectrograph animations
  • Optimisation without SIM card will display the phone in Airplane mode
  • Optimisation of lock screen to provide 720P HD support
  • Repair the wrong call in green text colour problem
[Desktop]
  • Added support for 720P resolution icons on desktop
  • Adding 4×4 Music Widget playing music sometimes leads to desktop not responding
  • Fix in some cases the Desktop widgets cannot be used
  • Fix in some cases long pressing the desktop (Home) button to open recent tasks list causes FC
  • Fix problem updating the default wallpaper
[Themes]
  • Optimise package download logic
  • Optimisation of theme thumbnail masks, description text is now clearer
  • Fix in some cases online themes does not show listing
  • Fix in some cases theme manager FCs
  • Fix select “Ringtones” through other applications such as Music player cannot play problem
[Camera]
  • Fix in some cases the scene mode cannot be opened from the function menu
  • Fix open shutter for zero delay, restoring the default camera settings still sets size to 8M pixels
  • Fix restoring video mode default settings and returning to view finger screen leads to FC
[Gallery]
  • Optimisation of the image details page, double-click the small pictures are enlarged up to three times that of the original image
  • Optimisation, the filter does not display the size of a picture of 0 bytes
  • Fix image details page animation when opening pictures
[Backup Manager]
  • Added support for backup and restore of emoticons, lunar calendar / birthdays and Network Assistant (Monitor)
  • Fix problems restoring MMS attachments
[Settings]
  • Optimisation to indicate incoming Bluetooth file transfer interface layout
  • NEW Allow to show / hide system FC error messages (See developer options for further details)
  • Added restore factory default settings can be opened to delete application(s)
  • New Factory Settings
  • New Bluetooth information display and phone name info
[Download Manager]
  • Optimisation to delete all entries, exit edit mode more efficiently
  • Repair the switch “To download / download / downloaded” leads to potential memory leak problems
[Calendar]
  • Fix creating a birthday notice is not updated in calendar
  • Fix delete a contact’s birthday calendar, birthday reminders to all empty (also requires you to manually clear the data: enter “calendar store” in the Application Manager, click the “Clear Data” button)
[Browser]
  • Optimised the default setting is turned off for “Automatically adjust page” feature to solve the wrong layout of web pages in some cases
[Traffic Monitor]
  • Optimisation of traffic usage over limit, status bar prompts once per day only
Post 1 Aktualisiert auf 2.6.1 - Version 2
MIUI Scotland 2.6.8 Online - Siehe Post 1
- noch kein Sprachpaket von Benson
MIUI V4 Scotland Fixes
I9000
  • Updated to latest CM9 Base
  • Improved SD Card Transfer Speeds
  • Correctly implemented MIUI and Samsung RIL, PLEASE CREDIT if using in other roms!
  • Improved Data Connection and Transfer Speeds
  • Optimized UI Speed
  • Optimized Ram
  • Other small tweaks within System Files
  • Version 2 fixes Root Issues.
Ist die Version deutsch?
MIUI Scotland V4 Downloads 2.6.15
Download: Samsung I9000169.6 MiB
I9000
  • Switched Kernel to Semaphore for stablity
  • Optimized Ram
Bin sehr erschüttert über diese Nachricht!
Lieber Mathew,
Im Namen der MIUI Gemeinde Hier, wünsche Ich deiner Tochter das erlebte Martyrium gut zu Überstehen. Meine Gebete sind bei deiner Familie. Amin!
Das Du in solch einer Situation nicht weiter machen kannst und willst ist mehr als Verständlich.
Nochmals Vielen Herzlichen Dank für deine bereichernde Arbeit die Du und dein Team geleistet hast.
Dein Qasim
Dear MIUI Scotland fans.
With the saddest regrets I'm having to close down, please let me take the time to thank everyone in the MIUI Community, including our fans who we are sure to miss.
I know that I've closed the site before and made a return, however this will be my final goodbye, as serious issues out with rom development have occurred.
Please let me explain further as I think you deserve to know the truth.
At the start of the year my daughter was sexually abused, and this has had dramatic impact on my ability to think clearly and also keep my mind focused on fixing roms and repairing issues.
It has also affected my health, both physically and mentally, and as such my time and effort for development is that of nil, and I don't think it is right to continue to push roms out when they could damage your handsets due to me missing something.
I know some will argue that I shouldn't go, and I've left people in the dark, however I have to say that I don't care, my daughter and my family are what is important to me.
I would recommend that if you are after the BEST experience and BEST support for MIUI that you visit either:
MIUI.US or MIUIANDROID.COM
Both these communities strive to maintain a high standard within the MIUI Community and both provide the roms weekly every Friday without delay!
I once again thank everyone for their support, help and understanding and hope that the friends I've gained will continue to be friends.
Take care everyone,
Mathew.
Q
vivanco
V
Q
quasimodo
Q
Q
yosenami
Y
