Glatzi84
Dauer-User
- 601
Ich oder Android-Hilfe.de übernehmen keine Haftung dafür! Ihr seid für euer Handeln selbst verantwortlich!!!
Banner from Signature Banners
KLICK
KLICK
Video - V11
Screenshots von btv-1. Besten Dank!
https://www.android-hilfe.de/forum/...s3-aokp-miui.210879-page-10.html#post-3303225
V12: www.mediafire.com/download.php?ars862j5adg78aa
Multiupload.nl - upload your files to multiple file hosting sites!
Camera Fix
Data Fix
Doc's Master ICS V11 TR
Important Note: Rom includes 2 Lockscreen
-Stock Honeycomb Style ICS Lockscreen
-MIUI Lockscreen
Please chose one and disable another...Because using both cause overlapping...
Disabling ICS Lockscreen: System settings-Security-Lockscreen-none
Disabling MIUI Lockscreen: Open MIUI Lancher-launcher Settings-Uncheck Use MiHome Locker
Archiv
Changelog
Hinweis: Infowars Animations kompatibel mit V11
Installation:
-Firstly you must have rooted + CWM installed (you can flash over any rom)
-GB Bootloaders recommended...
-If lagfix enabled then disable it.
-Recommended removing external sd before flashing also.
-Copy rom to internal SD and Reboot into Recovery
-Wipe Data + Cache + Dalvik Cache
-Go "Mount and Storage" and format system
-Flash rom and reboot. At least 5 minute wait for first opening.
----if you get bootloop(probably you are coming a sasmsung based rom),remove battery, reboot into recovery using 3 button combo and reflash rom!
-When first opened let it at least 10 minute settle then reboot again...
-After second opening Enjoy your new rom...
