[Galnet MIUI] Jetzt "Miui Scotland" V4 – 2.4.16 - Builds (ICS Android 4.0.4)
  • 157 Antworten
Q
quasimodo
Gast
Hier geht es Offiziell weiter: MIUI Scotland V4 - 2.4.16
Video
I9000@ MIUI V4 - 1.12.16 builds (ICS 4.0.1) - YouTube
V4 – 2.3.20 Builds (ICS Android 4.0.3)
  • 1.0 - Installationsanleitung - Bitte vor dem Flashen Lesen!
Gingerbread to ICS How To
  • Wer vom CM9- oder onecosmic Rom kommt geht folgend vor
  1. Kopiere Galnet MIUI V4 – Build auf die Interne SD Karte
  2. gehe in den CWM Mod - mache einen Fullwipe - flashe das Galnet Rom
  3. Reboot - Fertig!
  • Anleitung von Galnet
These builds are not what we would class as being stable builds at present. The include the new MIUI V4 layout, and come with an array of issues.
PLEASE READ BELOW BEFORE FLASHING ON I9000 / I9100:
1. To flash on the I9000 / I9100 you must do a FULL WIPE, including Dalvik Cache
2. You must flash again after flashing the first time
3. The phone will now boot (First boot may take about 4 minutes)
4. Give the phone time to boot, go make a coffee or tea, and then come back
5. Reboot once MIUI v4 boots.
  • 1.1 - was geht schon - was noch nicht
2.3.19 V4 – I9000
What Works
Everything bar FM Radio, you tell us..!
- SD Car Internal and External
- USB Mounting Internal and External
- RIL correctly implemented and working
- WIFI Scanning and I.P acquiring
- Auto Brightness
- Motion sensors
- Proximity sensors
- Loads more…..
What Doesn’t Work
- FM Radio
- TV Out
  • 1.2 - Change Log
2.3.31 V4
Galnet MIUI Scotland | Change Log
2.3.20 V4 – I9000
- Removed 4 way reboot
- Improved Samsung TouchWiz support
- Implemented changes to permissions across rom
- Improved ram handling
- Upgraded to Glitch V14 Rom (BLN support)
- Quick SD Card read and write
- Fixed Gallery FC and Rotation Issues
- Gallery Widget FC fixed
- Other small tweaks..!
V4 – 2.1.13
Change Log Here
V4 for I9000 - 1.12.23 Build
Change Log:
Data now working
New FuguMod Kernel thanks to OneCosmic
Unfortunately camcorder is broken again and video playback
Market Fixed
USB Mounting Fixed
Change Log – 1.12.19
Fully working Camera and Video Recording (May be choppy on some devices)
Boot Animation Fixed
Market Install Issues Fixed
Optimisation Of Applications on Install
Video Playback Resolved
Google Applications Added
Startup Wizard Included
Internal and External SD Cards Working
USB Working
Face Unlock Working
MIUI Themes Working
Auto Brightness Working Correctly
Sensors Working Correctly
Battery Lasting Around 18+ Hours
Music/Audio Working Correctly
Sound Settings FC Repaired
Rooted and Super User Included
Ram Tweaks and Management
Corrected ISO Settings within Camera
Panoramic Photo Setting In Camera Working
WIFI and Mobile Data Working (Toggle WIFI on and off may be required and Data may not work on some networks)
Minor Fixes to Stabilise Rom
And Loads More Now Resolved Under The Hood (Clean up etc..)
  • 2.0 - Rom
Samsung I9000 V4 139.8 MiB
Samsung I9000153.6 MiB
____________________________________________________
  • Rom Archiv
Samsung I9000 2.3.27 153.3 MiB
ICS I9000 2.3.27 Updated
  • Resolves issues with 2G/3G selection
  • Resolves issues with applications not seeing /emmc folder
  • Resolves issues with screen lock security fc
  • Kernel swapped to Semaphore 0.9.7
  • USB mounting on both Internal and External when connected to PC
  • Additional ram available thanks to new kernel
  • 4 Way reboot added thanks to Andy Thomson
  • Additional under the hood tweaks
2.3.20 (ICS MIUI V4) Rom
2.3.19 (ICS MIUI V4) Rom
V4 –
2.1.17 - kein DE Sprachpaket
Samsung Galaxy S
File Size: 154MB
Languages Supported: English/Chinese
My Multidownload
I9000 Mods 2.1.17:
  • Improved Signal and Wake Up
  • 720p Recording Fixed
  • Voice/Audio when calling Fixed
  • Mobile Data working
  • Faster WIFI scanning and ip obtaining
  • Additional fixes to HW acceleration
  • Home button now wakes phone from sleep
  • Improved Audio and Media playback
  • Changed kernel to NEO 3.0.8 (Thanks Zach)
  • Improved ram and battery
  • Full Root Access
  • Working Video Effects
  • Incoming and out going calls working
  • Touch Focus and Zoom Working on Camera
  • Other small tweak
Externe SD Karte wird immer noch nicht erkannt
V4 –2.1.13
Samsung Galaxy S
File Size: 138MB
My Multidownload
V4 – 2.1.11
Samsung Galaxy S
File Size: 145MB
SuperUser RootingSuperuser.v.3.0.7.zip
V4 I9000 2.1.6 :
downloads.galnetmiui.co.uk/2.1.6/miuiscot…
SuperUser
(12.1.1)
Samsung Galaxy S
File Size: 147MB
http://downloads.galnetmiui.co.uk/12.1.1/miuiscotland_V4-I9000-12.1.1.zip
1.12.23
Samsung Galaxy S
File Size: 150MB
My Multidownload
ROOT : MEGAUPLOAD - The leading online storage and file delivery service
[FONT=&quot]i9000 (UPDATED – 19th Dec 2011 – 1.12.19)[/FONT]
Samsung Galaxy S
File Size: 165MB
Change Log: Click Here
http://ota.miuiscotland.co.uk/ota/1.12.19/miuiscotland_V4-I9000-1.12.19.zip
My Multidownload
LP miuiscotland_I9000-1.11.27.zip
1.12.16
Samsung Galaxy S
File Size:
My Multidownload
Kernel
Modems
ICS Mods & Fixes
SuperUser kompatibel mit v4- 2.1.6 RootingSuperuser.v.3.0.7.zip
Superuser Fix
Superuser-3.0.7-efghi-signed
Credits & Thanks!
  • CyanogenMod Team
  • MIUI Dev Team
  • Galnet MIUI Team
  • Pawitp (Kernel)
  • DerTeufel (Kernel)
Falls euch meine Arbeit gefällt, könnt ihr gerne
Klicken
*jeweilige Liste die Euch gefällt, Informiert fühlt
Reaktionen: caipi75, 1n2du5t und CrazySW
Archiv
Official GalnetMIUI Scotland
FOR DEVELOPERS AND TRANSLATORS:
APKTool for translators for MIUI V4 can be downloaded from here: http://www.galnetmiui.co.uk/APKTool-V4-MIUI.zip
(Remember framework-res.apk and framework-miui-res.apk will be required to decompile and recompile)
So firstly do: apktool if framework-res.apk
Then do: apktool if framework-miui-res.apk
Regards,
Galnet
Originaltext: Galnet
Already Ported to SGS...!
YES...!!!
You read correctly, we already have ported the NS build of V4 MIUI across to the SGS I9000.
Want to see?
Look at the attachments.
Release it?
No, as the V4 build for the NS is still in development, we are not going to release this to the public. What we are going to do though is send the port across to MIUI for them to develop V4 on the I9000.
Now who called us copy and paste developers?
Oh yer, we know who you are! Now what was your quote? "LOLED"..!
Next Message:
Just to let you know what is working and what's not:
WORKING
  • WIFI
  • BLUETOOTH
  • AUDIO
  • DATA
  • 3G/2G
  • PHONE CALLS
  • HW ACCELERATION
  • SENSORS
  • COMPASS
  • TOUCH SCREEN
  • SD CARD (INTERNAL & EXTERNAL)
  • USB MOUNTING
  • DEBUGGING
  • CHARGE WHILST OFF
NOT WORKING
  • BOOT ANIMATION
  • FM RADIO
  • VIDEO RECORDING
  • TV OUT
Everything is running smooth and is VERY quick! We will post a video shortly.
Regards,
Mathew.
---------- Post added at 04:58 PM ---------- Previous post was at 03:17 PM ----------
WIFI Fixed at 16:57 - 07/12/2011
---------- Post added at 05:52 PM ---------- Previous post was at 04:58 PM ----------
Boot Animation seems to be caused by a lib change within MIUI. Hopefully MIUI will be able to resolve this.
---------- Post added at 06:44 PM ---------- Previous post was at 05:52 PM ----------
All I can do to make this work correctly has been done. Passing file across to MIUI China for official support
---------- Post added at 07:11 PM ---------- Previous post was at 06:44 PM ----------
Files now passed across to MIUI China
Reaktionen: susdiehl und tobiasth
Ist Online und in Post 1 gelistet!
hallo! komm von MyICS beta 1.12.11.
habs grad mit vorhergehendem full-wippe draufgespielt.
läuft bei mir leider irgendwie zäh und langsam.
und sehr warm wirds auch. leider.
bin wieder zurück zu myics.
Mache noch mal einen Reboot, eventuell wird es dann besser!
Bist Du so vorgegangen: To flash on the I9000 you must do a FULL WIPE, including Dalvik Cache
Ich bin von CM9 gekommen und alles lief bestens und Heiß wird Mein Handy auch nicht.
Kann mal jemand die Benutzeroberfläche mit ScreenCast oder per Screenshots aufnehmen? :)
ja. hab full wipe inkl dalvik cache gemacht, und gleich drauf geflasht.
Also bei mir ist es ähnlich. Habe alles wie in der Anleitung gemacht. Nach dem reboot waren meine ganzen Dateien von der externen sdcard verschwunden, habe dann sdcard raus und wieder reingesteckt, dann kam die Meldung das die sdcard einen defekt hat und neu formatiert werden muss. Hat das auch jemand gehabt?
PS: Bin grad auf die offizielle Miui 1.12.16, da sind plötzlich meine dateien auf der sdcard wieder zu sehen...
@quasimodo Ist es bei der auch sehr laggy, gegenüber der CM 9 beta?
Gesendet von meinem GT-I9000 mit Tapatalk
Hallo philippsp,
Ja, es läuft nicht annähernd so Gut wie CM9!
Habe es mit dem letzten Kernel von DerTeufel versucht,
der ist zwar kompatibel, Ruckelig bleibt es aber.
Backup geht zwar, nimmt aber meine gespeicherte Einstellungen nicht an,
war auch zu erwarten.
So Richtig MIUI ist das auch noch nicht, da haben Sie sicher noch ne Menge Arbeit vor sich.
Der erste Schritt ist aber schon mal getan. Gelle!
Bei Mir kommt es erst mal wieder Runter und mein lieb gewonnenes MyICS wieder drauf.
Habe das Rom doch noch mal drauf gelassen!
  • Für Root steht in Post1 der Superuser Fix bereit
Könnte jemand mal Screenshots machen? :flapper:
Working on fixing some issues on the I9000 V4 MIUI build, mainly Boot Animation and Market Issues, along with making the rom alot more stable and faster ;)
Hallo drigg0r, da bin ich mal gespannt wie eine Flitzebogen!
weiteres Zitat
People tend to forget who 1st got ICS booting on the SGS, and first to port MIUI V4 to another device. Oh and the party isn't stopping, just yet!
Das ist ja klar... Weil denen doch vorgeworfen wird nur copy und paste zu können.
Aber gerade der letzte Teil... Und die party hört nicht auf, jetzt schon... Was meinen die damit?!
//Edit: Oder meinen die "noch nicht" Ich hasse Englisch... Da ist manches zweideutig und auslegungssache... Wenn es noch nicht heißt dürfte es ja klar sein... Das heißt dass sie ICS noch auf manch andere Handys porten werden...
//Edit:
Der Changelog ist draußen
Change Log for Miui V4 - I9000 - 1.12.19 Build
USB Working
Face Unlock Working
MIUI Themes Working
A FULL WIPE IS RECOMMENDED ON FLASHING
ROM IS UNDER TESTING AND WILL BE RELEASED SHORTLY.
Regards,
Mathew aka (galnet)
//Edit: "Final Testing Stage if this is successful then rom will start being uploaded ;)" kam vor 3 Minuten in Facebook. Man kann also gespannt sein. Ich rechne gegen 18 Uhr mit der neuen Version.
