[ROM][N9005][6.0.1]Temasek's UNOFFICIAL Build[CM13.0]
  • 2.041 Antworten
Dort sind 2 Versionen... welche sollte man laden?
beide. das mit dem datum ist das rom, und das andere ist ein update dazu.
Ich würde erster die rom flashen, dann booten, nochmals ins recovery und
dann das update hinterher flashen.
changelog von dem update
V16.3 TINY UPDATE
This is to flash over V16.3 only
FIXED - Status bar header battery icons overlapping other icons.
FIXED - Super Duper BIG RECENTS nav bar button in landscape mode
FIXED - Funky nav bar sizes
Added - More font styles for clock and weather in status bar
Reaktionen: Trejay
also ich habs versucht zu flashen kommt fehler mit corupt
:huh:
fehlerhafter download?? ich hatte keine Probleme
ne stand download fertiggestellt ... ich lads nochmal runter und probiers nochmal
Reaktionen: d407974
Build V16.4
Those on V16.3, recommended to update asap.
More bug fixes + 1 potential reboot issue fix
Also now u can enlarge the status bar clock font size.
Reaktionen: Trejay
V16.4 - Those with Settings FC on statusbar settings, Pls try deleting /data/data/com.android.settings
Build V16.5
CHANGELOG
  • FIXED - Settings FC immediately after uninstalling an app in "Applications"
  • FIXED - TRDS statusbar header
  • FIXED - 4th navigation bar button not appearing in landscape mode
  • FIXED - Possible overlapping of Power Button in navigation bar when IME switcher is shown concurrently.
  • Added - Up to 14 font variants to Status Bar Clock. Original feature by yours truly.
  • Added - Up to 14 font variants to Status Bar Weather
  • Added - Font size for Carrier Label in Status Bar
  • Added - Lockscreen Rotation
  • Added - System App Removal in "Privacy" settings
  • Added - Option to show Volume Panel in expanded mode by default in Sounds Settings
  • Added - MOTO X Ringtones and Notification Tones (This caused increased in overall fize size. I may remove it on next build)
  • Updated - Change in pictures for Custom Headers (Not confirm will stay. I'll see if I like it or not)
  • HEADS UP moved to "Notifications"
  • Misc frameworks bug fixes
  • Updated cm sources
Quote:
NOTE: Since V16.4, some users encounter FC on statusbar settings. Solution is delete /data/data/com.android.settings using a file manager with root access. This is a one time action for your phone to upgrade the settings database. Those not affected have already good settings database.
V16.6 ist da.
- Includes @arter97_dev latest jemalloc which gives better performance and memory efficiency.
- Updated cm sources
Quote:
Take note on the following
Status bar clock & Display font size FC issues are inter-linked
- Temporary solution is to delete /data/data/com.android.settings
- When you choose the clock font size option it will be ok BUT when you proceed to display settings font size, it will FC (Vice versa). You have to delete /data/data.com.android.settings again.
- This is troublesome but for now its a temp solution.
- I will attempt to find a proper solution.
temasek's Files :: BasketBuild
Reaktionen: Cpt. Future
FIXED - Status Bar Settings FC &/Or Display Font Size Settings FC
Tiny Update flashable available.
Instructions:-
1. Download V16.6-Settings.zip
2. Flash the file over V16.6
3. On boot, delete /data/data/com.android.settings. This is one time action only.
4. Proceed to Display settings and set font size back to 100% or your desired size. It forgots the setting.
5. Your Status bar settings will be ok as well as your Display font size settings. Both will be usable.
Download
https://basketbuild.com/filedl/devs?...6-Settings.zip
Mirror
http://temasek.rajasthanautoworks.in...6-Settings.zip
d407974 Danke das du so aktiv dabei bist! Top Job!
Reaktionen: Manu95 und d407974
Ich finde leider nichts konkretes zu meinem Problem von daher Frage ich hier. Wieso hat man bei CM grundsätzlich ein Problem mit Videos streamen ? Egal ob in der Focus Online APP oder über den Chrome Browser, die Videos laden meist nur bis zur Mitte und danach ist Diashow...kennt das jemand ?
Hab mir die ROM auf mein Note 3 geladen. Finde sie echt super und schnell zum vergleich der Original Samsung Firmware.
Nur was mich etwas Iritiert.
Wenn ich das Note 3 im Ausgeschaltetem Zustand auflade, erscheint weder eine Ladeanzeige noch sonstiges wo ich sehen kann, ob der Akku lädt bzw. wie voll er schon ist.
Gibt es dafür in den Einstellungen etwas oder ist das einfach so?
PS: Kann man das Update V16.8 einfach flashen ohne dass die Daten verlohren gehen?
das mit dem laden im ausgeschaltetem zustand ist leider so. das kriegen die von CM einfach nicht hin. (closed source von Samsung)
ja, du kannst das update einfach drüberbüglen. da geht nix verloren.
ab und zu ein backup machen ist aber auch nie verkehrt. es kann immer mal was schief gehen.
