gewürzwiesel
Philosoph
- 2.055
AOSB Project v1.2.5 , coming up !
Changes and features:* (until now)
Merge CM lasts Changes
CRT animation: add scale down
List animation: views and interpolator
Dialer: Flip to Mute/Reject Call
Dialer: allow disabling call end sound
Dialer: Add Facebook contact sync support
InCallUI: fix non intrusive incallui layout
InCallUI: UI from blue to white
InCallUI: fix card call incoming colors in BlackUI
Bluetooth: Fix phonebook sync problems on some car kits
Bluetooth: GAP: Avoid adding device to cached device list
Settings: AOSB new Settings icons thanks lolations!
Settings: AOSB DE translations thanks mirco !
Settings: AOSB DE translations grammar fixes thanks Marcus!
SystemUI: Always show translucent decor on recents panel
Frameworks: many fixes for memory leak
add new AOSB Wallpapers thanks Tareq Halaby!
add new AOSB BlackUI
add new AOSB Bootanimation
White-ify tab colors
Add Music Tile
AppOps Minor Fix
Fix UserTile
Fix SystemUI FC at bootup
Fix expanded desktop options
Fix battery icon in status bar after reboot
LS Notifications dinamic width & blacklist options
Losckscreen Notifications fixes
Lockscreen Notifications: fix phone turning on in pocket
LS Notification dinamic width & blacklist options
added national roaming info for Tuenti Movil in Spain
added national roaming for Orange in Austria
added national roaming for BOB in Austria
BlackUI: change alert dialog to new 4.4 UI guidelines and add
BlackUI: global menu follow new 4.4 UI
BlackUI: correct seeker fb style for 4.4
Xposed update and built from source
Xposed installer hide from launcher
m7-common: Update sensor binaries
hlte: update adreno blobs
n7100: enable ZSL mode
n7100: audio: don't disable back mic upon voice call end
hammerhead: Remove bug report shortcut
hammerhead: Enable volume button wake
hammerhead: Add stereowide effect
Base: The Netherlands national Roaming
Camera : sdcard-storage option
Denke mal heute nachmittag wird soweit sein.
