Anti_
Mal abwarten, bald kommen eh die ganzen L Builds und bis dahin läuft die 152er ja einwandfrei
Dazu musst du ihn nicht mal auf Twitter verfolgen.Schneckmeier schrieb:Keine Panik - der hat öfters Anwandlungen und postet ab und zu überreagiert. Wer ihn auf Twitter schon länger folgt weiss was ich meine![]()
Sooo leicht wird das glaub nicht mit Lollipop...Anti_ schrieb:Mal abwarten, bald kommen eh die ganzen L Builds und bis dahin läuft die 152er ja einwandfrei![]()
temasek schrieb:Build V155
PLEASE READ BEFORE FLASHING
Introduction of F2FS Support
From V155 onwards, there will be support of multiple file systems on a mount point. That means, users get to choose between maintaining existing EXP4 filesystem or the use of F2FS. Both will be supported.
What is F2FS?
Flash Friendly File System (F2FS) | Linux.org
What are needed for F2FS support?
- Custom recovery that supports F2FS. I've compiled all 3 variants of HLTE with Philz Touch 6.58.7 with F2FS support.
- Custom kernel that supports F2FS. In Build V155 comes with Temasek Kernel v3.98.2. This release supports F2FS.
- Custom ROM Supporting multiple filesystem on a mount point. This is important so that at anytime you wish to convert from EXP4 to F2FS or F2FS back to EXP4, the rom will still support. In V155 onwards, this will be true.
What partitions with F2FS can Temasek Kernel v3.98.2+ support?
- Data
- Cache
- External SDCard (Natively support, doesn't require additional support)
Why /system partition is not in the list of F2FS support?
- This is because atm HLTE family cannot mount /system partition onto a F2FS filesystem, or at least I cannot figure out.
If I don't want F2FS, what should I do?
- Nothing
Preparing for F2FS
- If you want to perform FULL WIPE, skip this section. If not continue with the following steps.
- Clear your contents of your external sdcard in preparation of some space to backup stuffs
- Flash custom recovery with F2FS support
- Custom backup /data & /data/media (your internal sdcard) & /cache to your external sdcard
- Backup your internal sdcard contents again to your computer (optional)
- You are ready. Proceed to "HOW TO CONVERT TO F2FS?"
How to convert to F2FS?
WARNING: Your INTERNAL SDCARD WILL BE WIPED!!!
Assumed you have backup your /data & /data/media (internal sdcard).
- Download V155 into your external sdcard. If you do not have external sdcard, you need to perform sideload flashing of V155 via recovery.
- Download custom kernel with F2FS support to your external sdcard. If you are using Temasek Kernel, you can skip this as V155 includes kernel with F2FS support.
- Boot to custom recovery with F2FS support
- Select "Wipe and Format Options"
- Select "Custom Format Options"
- Toggle f2fs <-> ext4 migration
- It will display "ext4 <-> f2fs conversion enabled"
- Select "format /data and /data/media (/sdcard)"
- Select "format /cache"
- Restore your /data & /data/media from your backup
- Flash V155
- Reboot
- Enjoy
V155 will be available for ALL supported variants. A separate flashable kernel & recovery will also be made available for ALL. I am posting this in advance for ALL to read before I proceed to upload all relevant files.
CREDIT: [MENTION=4898097]arter97[/MENTION] who helped me in making F2FS possible for HLTE.
Enjoy![]()
