AMG Design
Dauer-User
- 1.678
PoWeRcOrSa schrieb:ständig der Kalender
Dirty oder clean flash?
Nochmal neu geflashed mit Full Wipe?
Problem danach immer noch vorhanden?
Leere mal den Kalenderspeicher. Sollte dann wieder gehen. Hatte ich auch schon ein paar mal.PoWeRcOrSa schrieb:Mir stürzt bei der v127 ständig der Kalender ab. Lg Tino
Changelog since V127
Comes with Temasek Kernel v3.93 EXP2.
- Revert "Revert "qseecom: Add support to handle multiple app load & upload""
- Updated FauxSound v3.2 to v3.5frameworks/base: Themes: Fix native crash in libandroidfw
- If a missing attribute needs to be added in somewhere in the middle
of the bag, a segfault would occur because we change curEntry to a
value that is beyond the set's allocated space. This patch stores
curEntry in prevEntry before changing it's value and memmove uses
prevEntry to index the set.frameworks/base: Keyguard: Can't enter PIN code when setting the SIM and PIN lock issue
- By original design, after unlock SIM PIN, SIM card's state is READY and it
will invoke resetStateLocked() to inflate KeyguardHostView. So there is
only one view be created in mSecurityViewContainer.
- Roll back previous solution.
Don't set mSimState before handleSimStateChange() and don't judge
isSecure() to be consistent with the original design.frameworks/av: stagefright: Move to 64 available tracks
Many games use numerous tracks. If the system
runs out of tracks, new tracks won't be able
to be created. This has been causing notifications
not to play if many apps are holding open tracks.frameworks/av: stagefright: stop audio source if player fails to startUpdated cm sources
Enjoy
Lese vermehrt, dass du keine Ahnung hast!Intentus schrieb:Lese vermehrt das diese Rom bei vielen Usern Probleme macht ... Schade!![]()
gewürzwiesel;8003163 schrieb:Lese vermehrt, dass du keine Ahnung hast!
