[ROM][N9005][4.4.4] *22.11.2014* Temasek's UNOFFICIAL Build V162 [CM11]
  • 1.250 Antworten
Im lockscreen ist meine statusbar noch transparent, aber wenn ich entsperre wird sie schwarz. Kann ich das irgendwo ändern?
Build V85
md5sum: b2405d4820383df622fa849a54f65d1c
  • Comes with Temasek Kernel v3.63 - Updated CM Kernel Sources
  • Updated Adreno blobs - https://github.com/temasek/proprieta...eb9fb029ec2478
  • Clock - Add ability to include seconds. A minor bug atm if u enable AM/PM, the seconds will come after AM/PM. So if you wanna enable seconds, pls use 24 hrs or don't display AM/PM.
  • Don't animate the circle battery meter when battery is fully charged
    Rotating a full circle is unnecessary, no need to redraw the battery
    meter every 50ms
  • MSimNetworkController: disable log spew
    Some logging statements are not properly guarded leading to logcat
    flood every few seconds.
  • Framework: Fine SeekBar control
    Allow user to move their finger in the Y direction
    to change the speed at which the seekbar will seek
    on moving their finger across the X direction
  • PEEK: Beautify bridging layers code
    - Save new instances for Peek and PowerManager:
    Create it only in BaseStatusBar when start() method is called. That one
    will be passed throught the sub layers such like new helper class so another
    feature can check Peek state invocking from NotificationHelper class.
    - Move phone listener to new helper class.
    - Do not show Peek on sim pin lock screen.
    - Process new incoming notifications only if screen is off, keep updating notification array separately.
    - General cleanup.
  • Long press clear all recents to flush cache
  • Quick Settings: Option to use floating window
    - Allows the option of launching preferences from the quicksettings menu in a
    floating window
  • Quick Settings: allow flip animation on clicking a tile
  • Fix crash when clicking a file from recents or downloads
  • The return of "App Sidebar"
  • Add ability to use floating windows with "App Sidebar"
  • Add "Inaccurate proximity switch" in Display Settings.
  • FIx QS Layout including Camera Tile, etc.
  • blar blar blar
  • Updated cm source
V86 is up with v3.64 kernel
servus, ich habe die rom installiert, aber leider funktioniert bei mir die Menü Taste nicht.... muss ich was aktivieren?
z.B. in der Titanium Backup App komme ich leider nicht in die Einstellungen... wenn ich auf Menü drücke tut sich gar nichts....
Wieso gibt es die Funktion nicht wie beim originalen cyanogenmod wo man unter Telefon Einstellungen einfach updaten kann?? Jedesmal laden und flashen ist echt kacke...
Gesendet von meinem SM-N9005 mit der Android-Hilfe.de App
Weil das aufwändiger ist.
Der Entwickler muss dann jedes mal die version.xml usw anpassen.
Dann braucht man einen geeigneten Server mit MySQL und PHP die man auch pflegen muss.
Jetzt ist einfach Änderungen hoch laden und das wars.
Nimm Temaseks Seite als Lesezeichen benutz einen Handy Browser lade es darüber runter und fertig.
Dann haste da deinen updater. Ich finde es nicht wirklich umständlich. Man kann es sich aber umständlich machen.
edit: weiß einer warum die Formatierung meines Beitrags nicht geht? Enter Tasten werden ja völlig ignoriert...
edit2:
Habe es nun mit dem HTML befehl .br /> gelöst. (punkt durch < ersetzten)
Hi. Hast du auch eine Antwort auf meine Frage?
planta, weiß ich leider nicht. Flash mal am besten mit Fullwipe ? Bei mir geht es.
bei mir geht die Menü-Taste auch nicht richtig. Auf dem Homescreen im Nova Launcher gehts, in Titanium Backup und einigen anderen Apps wieder nicht.
Hab mit Fullwipe geflasht und ansonsten nichts verändert.
Hi hab gerade die 86 geflasht. Bei mir funktioniert die Menutaste ohne Probleme!
v86 seit heute früh drauf, dirtyflash wie immer, keinerlei Probleme mit der Menütaste und auch sonst alles OK.
Habe das Problem mit der Menütaste auch in Titanium Backup. Habe es mit einem kleinen Trick umgangen.
In den Einstellungen einfach auf long press Action “Menü öffnen“ legen und voila.
Build v87
  • Compiled with Linaro 4.8 with JustArchi Optimization V2.
  • Comes with revised Temasek kernel v3.64 compiled with Linaro 4.8
  • Updated cm sources
Ich habs gewagt - bis jetzt keine Probleme festgestellt.
Reaktionen: xGojira und d407974
Habt ihr noch gps? Bei mir geht es nicht mehr. Hatte auch keine zeit eine andere Rom zu testen
Also ich nutze die von cyanogenmod.org und dort geht GPS.
Habs gerade mit Google Maps getestet.
Reaktionen: Sakaschi
Mit v86 keine Probleme
Gps funzt bei mir einwandfrei allerdings mit v86.
Ok flashe ich nachher die 86 ich bin noch auf 85
Also ich hab grad 10km mit sygic navigiert. GPS geht mit v87.
navi geht auch wieder bei mir (auch mit 85) keine Ahnung was es war. Jetzt bin ich auch auf 87
