[ROM][N9005][4.4.2][CM11][NIGHTLY] BeanStalk UNOFFICIAL Build
  • 212 Antworten
GalaxyMax90
GalaxyMax90
HINSWEIS:Flashen und Testen auf eigene Gefahr. Weder Ich noch Android-Hilfe.de übernehmen keine Haftung für Schäden und Probleme die durch das Flashen auftreten können und somit euere KONX-Counter von 0 Auf 1 getriggert!! wird somit besteht keine Garantie mehr.
Der Entwickler Hat auch vor die Rom immer auf Den neusten Stand zu Halten.
Changelog:
BeanStalk 4.4.275- 4/12/2014
Kernel updated
Set some GC parameters only for dalvik
base: Add blacklist provider permission
Frameworks: SlimRecents pass gesture detector to the cardslistview
Frameworks: add 1dp more bottom padding
Frameworks: SlimRecents: Make expanded layout pretty
Framework: Allow Power Notification Sounds For Wireless
Settings: Mock SMS
settings: Add blacklist provider permission
SoundSettings: Assigning a null to an unnecessary variable
cm: sepolicy: Allow ueventd to load WiFi and audio irmware
cm: sepolicy: Allow ueventd to properly handle cpufreq changes
Other cm stuff
BeanStalk 4.4.270- 3/18/2014
Home button to answer call ( setting ---> accessibility )
bump to beanstalk 4.4.270
Optimizing system app used ram
DeskClock: Support double-digit hours for timers
Don't fetch deleted messages from IMAP folder
audio: Added lock during closing of direct output
ifdef "stagefright: Enable GraphicBuffer usage to decoder before querying formats
Keyguard: Fix configuration change observer
Don't recreate keyguard for MCC/MNC changes.
FWB: Allow disabling of FC dialogs
Remove double tap, make long press to enable torch
Settings/Wifi: Add support for Ad-hoc (IBSS) networks
Fix resource IDs being added to the android namespace
Other cm stuff
BeanStalk Features:
CM based
Xposed framework
Gravity box
Temasek kernel as default
Custom unlock button
Halo
Lockscreen Notification
Lockscreen background options (Color fill, Custom image, Transparent)
Customizable Lockscreen text color
Lockscreen rotation
Option to enable all widgets
Minimize lockscreen challange
Use widget carousel
Slider Shortcuts
Static Lockscreen shortcuts
Lockscreen button actions
LCD Density
Scroll elasticity options
Default App grip option
Custom Carrier label
Dual Pane options
Customizable boot animation (off, default, set your own bootanimation)
BeanStalk Wallpapers
BeanStalk bootanimation
Status bar color and transparency
Clock and date options which includes color, location, style
Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
Breathing SMS option
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Pie controls (need to have lockscreen background set to something other then default to work correctly (dont ask why) )
Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
Quick settings color settings, tiles per row, Quick pulldown, text color
Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
Keyboard and input method options which include disable full screen keyboard and auto rotate
Kil app back button with customizable timeout values
High end graphic effects option
option to disable/enable vibrate on expand for notifications alerts
Low battery warning customizable options
Recents RAM bar fully customizable with color styles
Clock widget for LockClock including extra options to fully customize every feature of the lockclock
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
insane amount of edits/tweaks/fixes to make this build absolutely fly
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Numerous other options hidding throughout the build
SPEN:
Für Alle die den S Pen mit der Rom benutzten wollen hat@Sakaschi:thumbsup:
eine Anleitung geschrieben,wofür ich ihn nochmal´s Danken will
Zu Finden Auf seite 2,Beitrag #14
MOD´s VOM Entwickler:
Custom font
______________
DOWNLOAD LINKS:
Kernel-Einstellungen
Beanstalk Download Link
Vorher dran Denken ein EFS BACKUP zu machen
1)Backup
2)Wipe data,wipe cache,wipe dalvik,wipe system
3)Flash Rom
4)Reboot Phone
Auf die neuste BeanStalk Updaten:
1)Wipe cache,wipe dalvik
2)Flash Rom
3)Reboot phone
Was noch nicht Funktioniert:
scott.hart.bti for the rom
temasek for the kernel
BaNkS for gapp
C3C076
for gravity box module
XDA LINKS: [AOSP][CM11][4.4.2][ROM]BeanStalk UNOFFICIAL Build - xda-developers
Reaktionen: br34ker, Bastizpunkt, Toleranz und 3 andere
V3 ist da OP Aktualisiert
Hat die Rom schon jemand am laufen?
Gesendet von meinem SM-N9005
Reaktionen: Tyrion
Na dann muss ich die heute mal testen
Auf meinem One hatte ich slim bean drauf. Hoffe die geht genauso
Jaa kann ich dir nur empfehlen
Die Rom heißt zwar
Beanstalk aber denke mal das wird Slim Bean sein wenn nicht auch egal ich finde sie top :thumbsup::thumbsup::thumbsup::thumbsup:
Funktioniert das mit dem Pen auch?
Habe ich selber Nicht geteste wall ich den S pen wieso ned nutzte
Wenn es auf CM basiert geht auch der Pen, dann dazu noch 2 apps aus dem playstore installieren und schon läuft alles wie unter stock.
z.b. doppeltipp = screenshot etc.
ich bin selber aber auf temasek
Reaktionen: GalaxyMax90
Sorry welche 2 App hast du genommen,würde das gerne op mit einfügen.
Von Slimroms ist die ROM nicht. Die heisst neu SlimKat und unter 'Supported Devices' ist das Note 3 nicht aufgelistet.
ja würde ich auch gerne wissen
Danke für die info,Konntes mir auch schon so denken aber war mir ned 100% sicher
Der ursprüngliche Beitrag von 10:11 Uhr wurde um 10:12 Uhr ergänzt:
hallo großer Mann
Anleitung für SPEN unter AOSP mit Funktionen:
1. Einstellungen -> Sprache und Eingabe -> ganz runter scrollen -> Stift Symbol -> harken rein (Optional nur für hover)
2. CM S Pen Add-on aus dem Playstore installieren und aktivieren
3. Note Buddy (S Pen Helper) aus dem Playstore installieren und einrichten wie man will.
4. ANote Overlay Free (root) aus dem Playstore installieren
5. Wieder nach Einstellungen gehen -> Sprache und Eingabe -> ganz runter scrollen -> Stiftgesten -> aktivieren -> die passende Geste auswählen -> ANO free auswählen.
Fertig nun habt ihr den Spen wieder mit Funktionen natürlich könnt ihr auch dazu andere apps nehmen.
Beschreibung welche app was macht:
CM S Pen Add-on:
Aktiviert Haptisches feedback wenn man den stift entnimmt oder wieder reinsteckt
Note Buddy (S Pen Helper):
Damit habe ich die Statusmeldung aktiviert (stift wurde erkannt) und noch Sound eingestellt wenn man den Stift entnimmt oder wieder reinsteckt das noch ein Sound dazu kommt.
ANote Overlay Free (root):
Ist meiner Meinung nach die beste Screenshot app die es gibt. Damit könnt ihr direkt auch im screenshot notizen machen etc.
Note Buddy und ANote Overlay Free bin ich durch Yank drauf gekommen.
An der stelle nochmal ein dickes danke schön!
Reaktionen: PowerPaule, Reddy, RoccoD und 12 andere
Hatte auch erst gedacht die wäre von Slim ROM
@Sakaschi danke für die Anleitung
Auch von mir ein dankeschön
Kein Thema, so funktioniert wenigstens bei mir der Stift super und vermisse von Touchwiz nichts mehr. Die können mich ma. Android 4.4.2 TW hat nur Fehler -.-
Lach jaa mich können die auch mal
So und jetzt wieder zum Thema Rom Danke
@Galaxy_S3_26 Wie sind die Akkulaufzeiten? Ich nehme mal an, dass auch diese ROM unter der dauerhaften erhöhten CPU Freq. leidet
