[ROM][N7100][4.4.4] *28.06.14* AOSB Project - Run over the Limit v1.3.6
  • 732 Antworten
Ich habe neben der Kamera auch das Akku Problem. Auch ohne Spiele etc.
ich hab im Durchschnitt 4,7-5,5%/h pro Ladezyklus.. knapp 6h DisplayOn-Zeit mit WLAN und 2G/3G.
Jedoch ist die Standby-Performance wirklich schwach, ich komme nicht unter 1,8%/h im WLAN-Standby (Protokolliert mit BatteryDrain)
Update 1.2.4
Reaktionen: Bastizpunkt
Change log 13 JAN
Merge Lastes CM Changes
Update to Lastes Gapps
Settings: Custom CRT Animation
Settings: enable/disable wifi name from notification drawer
Settings: Enable AppOps
Settings: add development animation transition mode 0.75 and 0.25
Settings: User-selectable camera click sound
Settings: Mobile Network Battery Saver Mode
Settings: Configurable up to user (LTE or 4G)
Settings: Don't set a null alias before unpairing
Settings: Advanced BatteryBar
Settings: New Navigation bar/ring
Settings: Add text plain battery style
Settings: fix led pulsespeedoff disable behaviour
Frameworks: Delete media tests
Frameworks: speed up statubar/notification drawer
Frameworks: squash of leak & race fixes
Frameworks: Facebook Sync Dirty Hack
Frameworks: Add CPU boosting hooks
Frameworks: Hot reboot (Quick)
Frameworks: show more info in boot dialog
AOKP: Custom Navigation Ring
AOKP: Custom Navigation Bar
HALO: make windows move able and scale able
Gallery: Storage configuration options
Remove old NavigationBar/Ring
Dialer: Fix Dialpad Text Color when PiB is enabled.
Dialer: restore full compatibility with theme chooser
Dialer: DarkUi update
Dialer: Goodbye blue dialpad ,Consistent white dialer
tile: LTE toggle support
add screen record to power menu
screenshot: quick delete action
Fix: Lockscreen Blur Rotation
multiwindow: Fix NullPointerException
Fix multi-user issues
SystemUI: Allow theming battery via theme chooser
too many translations was added
hlte: use samsung's gps libloc api.
hlte: Update adreno libraries
hlte: update adreno blobs
m7 : Update graphics libraries
Add new APN
OP wieder aktuell.
Wie sieht es mit der Akkuleistung aus? Besser? Soweit wie man das jetzt schon sagen kann...
Wir funktioniert Multiwindow jetzt eigentlich?
Multiwindow läuft über die zuletzt geöffneten Apps (Recent Apps). Dort die gewünschte App gedrückt halten und add to split view drücken. Die zweite App dann genauso. Ist allerdings ziemlich laggy, bei mir jedenfalls. Halo muss dafür deaktiviert sein.
Ich hab das irgendwie nicht
Und Halo ist deaktiviert?
Hmm...
Ging das nicht auch mit halo?
Naja die ist an.
Nein mit Halo läuft es nicht. Sollte aber auch in den Einstellungen unter Halo stehen. ;)
Moin.
Hab mir mal die aktuelle Version geflasht.
Habs erst dirty versucht aber konnte so leider keine Telefonate führen.
Mit Fullwipe geht alles.
Bekomme jetzt immer ne Anfrage "Superuser für kombinierte Standortabfrage".
Ist nicht das normale Fenster als wenn zB. Titanium usw. nach Superuser fragt. Ist einfach nur ne Meldung.
Hatte ich vorher nicht gehabt.
Jemand eine Idee ?
@Racks
Jetzt hat es klick gemacht. Installiere dir Halo))) aus dem Play Store und du hast quasi "Multiwindow" feeling.
Reaktionen: Racks
Keiner ne Idee wegen "Superuser für kombinierte Standortabfrage" ?
Also mir sagt das so gar nichts. Kannste da nen Screenshot von machen? Oder ist das nur die Notification die unten am Bildschirm erscheint? So wie "Nachricht erhalten". Hatte das auch mal irgendwann das diese Notification immer wieder erschien, aber nach nem Reboot hatte sich das erledigt.
Ist einfach nur ein kleines Fenster wo das drinnen steht.
Lustig ist das ich das nur gestern hatte.
Den ganzen Tag kam keine Meldung.
Dann hast du vielleicht irgend ein App installiert?
Kein Plan was das war aber scheint weg zu sein.
Und wie läuft bei euch so die Kamera ?
Bei mir crasht das Teil gelegentlich.
Die Rom ist super aber es nervt echt das die Kamera immer Probleme macht.
Die Kamera wird immer schlimmer. Fokussieren kannst meist sowieso vergessen. Das wird wird wohl nichts mehr werden.
Hmm...ich Fotografie nicht viel,aber wenn doch hab ich keine Probleme.
Dr.No
Taker18
Sealsman
Silverblade
Nufan
Nufan
