defjam2oo1
Update 4.4 beta 1
Ist raus
Habe es ohne wipe einfach drüber geflasht, und läuft.
Ist raus
Updated from latest sources
Updated to RC 2.
Hover
- General improvements and bugs fixes
Peek
- Improved sensors algorithm - but this does not make a lot of sense as Peek is still not working as it has to work on samsung phones.
Quicksettings
- Fixed theme support
- Separate dimension for dual tile switch so themers can edit it separately
- Other small fixes
Pie
- General improvements and fixed systemui crash on boot
Theme Engine
- Upstream feature patches/fixes
- Fixed system and on the spot dialogs theming
- Other fixes and enhancements
Recents
- Fixed clear all glitch on quick double press while many apps are loaded
- Crash preventing patches
General
- Fixed various force closes (Chrome, Settings, DocumentsUI)
- Fix input settings empty screen when launching from keyboard
- Fixed Safe Headset Volume dialog Softboot
- Added Kitkat supported camera drivers, DRM drivers, started to use closed source sensor drivers. LPM and EGL drivers.
Note : There is one bug that is not yet fixed. when you try to open Google now via PIE, you will see systemui force close. This issue is seen only when using PIE, google now as a app works fines. This issue will be fixed in the future build.
Du hattest recht, es ist unter Akku umzustellen. Oben rechts ist ein Akku Symbol den man anwählen kann und dort kann man es umstellen.DirtyKlot schrieb:Ich habe den ROM zwar gerade nicht mehr drauf, aber schau mal in Einstellungen - > Akku und dort könnte die Einstellung sein.
