DirtyKlot
Ehrenmitglied
- 3.907
- Themenstarter
- #1.041
Es gab seit der Version, bei der Beta 4 angezeigt wird, noch keine neue Version. Das ist aber nur ein Schönheitsfehler, in Wirklichkeit hast du Beta 5 drauf.
Grüße
Grüße
Change logs for 4/29
* updated from latest sources.
* PA version bumped to 4.3 beta 1
* Peek is official and is included
* lots of kernel updates and optimization. New governor added.
* Google camera settings issues fixed.
* updates to the new Theme engine
* updates to stock recent and slim recent
* Enhancement to paranoid ota app
* option to pause, resume or stop a download feature added.
* Added some security enhancement to the lock screen. Check them out under settings -> security
* many more bug fixes and enhancements
Das Update könnt ihr über die offizielle PA OTA Updater App beziehen! Der OP ist aktuell.* Updated from latest sources
* Version bumped to 4.3 BETA 3
* Launch floating mode apps from notification shade (long press)
* Launch floating mode apps from recent apps
* Root access modes (disabled, apps only, adb only, apps and adb)
* Added Incoming Call in Background feature
* Allow disabling the IME selector notification
* Many more Bug fixes
* Translation updates
Change logs - 5/15
* Updated to Beta 4
* Added New CM Theme Engine
* Added New CM Lock screen Wallpaper
* Fixes for Floating mode in Recents
* Modified circle Battery UI
* Fixes for PIE
* Some translations updates
* Many more bug fixes
Note : If you have applied a theme on your phone, then set your phone back to the system team before applying installing this update. This uses a new Theme Engine UI there are chances for hitting some errors. Also would advice to take a backup if required. In my testing i have not seen any issue, but it is always better to take some precautions.
