[ROM][N7100][4.3] *25.10.13* Helly Bean [CM10.2][Entwicklung eingestellt]
  • 26 Antworten
DirtyKlot
DirtyKlot
Ehrenmitglied
3.907
Helly Bean 4.3 N7100
Additional changes, compared to cm10.2 (this list might not be complete):
Code:
- facebook sync integrated
 - option to enable high end gfx effects
 - possibility to activate and customize navigation bar
 - aokp clock (right/center, custom color, big/small am/pm, display weekday)
 - misc settings in settings menu
 - added possibility to change the colors of the statusbar toggles
 - added option to enable/disable coloring of toggles
 - added option to display a small bar below the toggles as indicator for toggle state
 - alternate default app picker (from aokp)
 - notification panel transparency
 - statusbar transparency
 - removed cm stats
 - removed cm updater
Many thanks to:
Code:
 - cyanogenmod team for their rom sources
 - stratosk (from who's initramfs i could start build my first jb booting kernel)
 - team nyx who always have good tips for me, if i get problems with my kernel
 - SysTem-X for hosting
 - Rootax for hosting
 - RolluS for hosting
Changelog:
Code:
Release - 25.10.13
+merged cm changes
Release - 23.10.13
+merged cm changes
+completely fixed contacts text while using TRDS/dark Hellybean
Release - 22.10.13
+merged cm changes
Release - 20.10.13
+finally finished moving the rom to hellybean github :)
+merged cm changes
+some  minor fixes and improvements by ThdDude (white contacts text by using  trds, renamed trds to dark hellybean, including new logo, hellybean  wallpapers instead of cm wallpapers, etc ...)
 Release - 11.10.13
+added more options to hardware key rebinding
+reverted active display (testing if this was causing a memory leak)
+merged cm changes
Release - 27.09.13
+Navigation bar button color mode (slim)
+active display: some more options and better handling of sensor enabeling/disabeling
+merged cm changes
Release - 25.09.13
+disable proxymity sensor, if active display is not used
+reoganized lockscreen settings
+merged cm changes
Release - 23.09.13
+navbar and statusbar color and transparency mods from slim
+fix autocollapse statusbar not working after boot
+merged cm changes
Release - 20.09.13
+lockscreen: option to disable initial widget page hints
+merged cm changes
Release - 18.09.13
+navigationbar and nav-ring fixes from slim (enabeling or disabeling does not require system_ui restart anymore)
+more halo mods
+possibility to place navbar at bottom in landscape (slim)
+possibility to open notifications from statusbar in floating window (longpress, pa)
+re-add settings for device-specific settings app (app needs to be placed at system/app by the user for now)
+merge cm changes
Release - 13.09.13
+ option to use the same lockscreen background color, as selected for optimus4 lockscreen (this avoids ugly borders)
Release - 11.09.13
+ fixed font render issue
+ fixed halo creation on boot
+ added custom lockscreen selection (eclair, gb, ics, jellybean and optimus4)
+ merged cm changes
Release - 10.09.13
+ you should consider this, beeing the first non testing 4.3 release!
+ fixed all known bugs
+ updated halo to 2.0
+ added additional completely hide feature to halo
+ added option to change number of quicksetting tiles per column
+ synced latest cm changes
+ many more ....
Screenshots:
Code:
[URL="http://www.hellybean.com/screenshots.html"]Helly Bean Screenshots[/URL]
Install instructions:
Code:
 - wipe data/factory reset
 - flash zip
 - flash gapps
Website & Downloads:
Code:
[URL="http://www.hellybean.com/download/galaxy-note/neue-download-page-10/"]Helly Bean[/URL]
[URL="http://goo.im/gapps"]Gapps[/URL]
[URL="http://forum.xda-developers.com/showthread.php?t=2134990"]XDA Thread[/URL]
Habt ihr eure EFS-Partition gesichert?
Reaktionen: skysat, redbull1, Darkman und eine weitere Person
Moin moin, herzlich willkommen und allzeit Gutes gelingen! Wenn Du Unterstützung brauchst, so sage bitte bescheid.
Gruss
Update 27.06.13
Changelog and Download:
Hellybean4.2-n7100
Release - 27.06.13
+ merged cm changes
+ added app sidebar from chameleon OS
+ halo related fix to sms app
Release - 26.06.13
+ merged cm10.1 stable changes
Release - 24.06.13
+ merged cm changes
+ added halo (from ParanoidAndroid)
Release - 10.09.13
updated halo to 2.0
many more ....
Download:
Hellybean4.2-n7100 on AndroMirror
Release - 11.09.13
merged cm changes
Download:
Reaktionen: DirtyKlot
Schade, dass diese ROM so untergeht. OP sollte mal geupdated werden...
In diesem thread ist keine bewegung. Schade da es schon immer eine recht gute alternative zu den total überladenen roms war.
Da der TE diese ROM nicht mehr pflegt, schreiben wir diese ROM soeben aus. Wie immer würden wir uns über freiwillige freuen!
@DirtyKlot
Du bist wirklich einer der Leistungsträger in unserem Note2 Forum, unser Dank für dein Einsatz.:thumbsup:
Gruss
Ich mach das gerne! Danke für das Lob. Ich hoffe, es tut sich jetzt demnächst was hier im Thread, wäre schade, wenn diese ROM untergeht :)
Reaktionen: skysat, derOyabun, Darkman und eine weitere Person
Auch von mir ein Dickes DANKE für deine Helfende Hände!
Muss jetzt auch mal außer Reihe erwähnt werden ;)
Reaktionen: DirtyKlot und Cpt. Future
Neues update.
Release - 20.09.13
merged cm changes
Release - 18.09.13
more halo mods
merge cm changes
Reaktionen: skysat und DirtyKlot
Danke, OP und Links aktuell.
ich lese hier nur von DL-Links und Updates.
Ich vermisse hier:
wie seid Ihr mit diesem ROM zufrieden ? Warum dieses ROM ?
Wer hat es installiert und am laufen ? Erfahrungswerte ?
Hellybean war und ist ne gute rom. Hatte die 18.09. Drauf und sie lief genau so gut wie die slim. Allerdings muss ich sagen, dass ich immer wieder mein goa backup einspiele, da es meiner meinung nach die beste rom ist.
20.09 werde ich evtl. Morgen mal drauf hauen.
Lg
Und ich kann eben kein Feedback posten, weil ich die momentan nicht laufen habe.
Release - 23.09.13
merged cm changes
OP up2date
Reaktionen: redbull1
Release - 27.09.13
merged cm changes
Release - 25.09.13
merged cm changes
Wird heute Abend, wenn ich da bin, gleich geupdated.
Dr.No
Taker18
Sealsman
Silverblade
Nufan
Nufan
