[ROM][6.0.1][crDroid][UNOFFICIAL][N7100][STABLE]
  • 8 Antworten
Taker18
Taker18
Hallo liebe Note 2 User, hier stelle ich euch meine crDroid ROM für das Note 2 vor!
Ich hoffe ihr habt spaß damit, und wenns was gibt, einfach melden bitte! :)
crDroid Custom Features:
Code:
 * Your warranty is now void.
 * I am not responsible for bricked devices, dead SD cards,
 * thermonuclear war, or you getting fired because the alarm app failed. Please
 * do some research if you have any concerns about features included in this ROM
 * before flashing it! YOU are choosing to make these modifications, and if
 * you point the finger at me for messing up your device, I will laugh at you. Hard. A lot.
- Volume panel timeout
- Clear recents location
- Heads up customization
- Quick access button on expanded status bar
- Swipe behavior
- Touch outside behavior
- Time out
- Do not disturb
- Blacklist
* SlimRoms custom lockscreen shortcuts
* Navbar on/off
* Hardare keys on/off (in devices supported)
* Power menu in navring targets
* SlimPie controls with all working
* Sound panel option om power menu
* Superuser indicator (Notification, Statusbar icon or no indicator)
* Force expanded notifications on expanded statusbar
* Power menu and notifications tiles
* Four tiles per row
* Vibrate on tiles touch
* Disable quick settings on secure lockscreen
* Kill app back button configurable timeout
* Omni-Ambient Display
Installation
1. Download ROM .
2. Download GApps.
3. Wipe dalvik/cache/data/factory reset.
4. WIPE SYSTEM.
5. Flash die ROM im recovery.
6. Flash die GApps.
7. Reboot Device.
Download ROM
crDroid
Download GApps
GApps
Credits
crDroid Team
All they helped crDroid
CyanogenMod
@trafalgar Square
Source
Device Source
Kernel Source
Reaktionen: arjen robben
Servus
kannst du bitte dein download überprüfen? Kommt nur 404...
Danke
diloniga
diloniga schrieb:
Servus
Danke
diloniga
Servus, habe crDroid für Note2 leider eingestellt, BeanStalk wird nun mehr von mir unterstützt :)
Mit freundlichen Grüßen
Domi
Dann bitte ich diesen Thread zu schliessen.
Vielen Dank !
Vielen Dank !
Bleibt immer noch dem thread-innhaber über [emoji14]
Regards
Das is richtig ;p
nja dann bleibt die " hoffnung " die letzte :s
gruß
Sealsman schrieb:
Das is richtig ;p
gruß
Vl werde ich crDroid wieder aufnehmen in mein Programm, mal schauen :)
Regards
Selbst wenn hier keine Weiterentwicklung mehr stattfindet, haben immer noch genug Leute die ROM auf ihrem Phone.
Und da diese möglicherweise Hilfe benötigen, bleiben die Threads im Normalfall auch weiterhin offen ;)
na dann :)
