[ROM][4.3]Avatar ROM[19/10]
  • 58 Antworten
Reaktionen: Cpt. Future
Mein Freund und Retter:love:
Vielen Dank Fred, LMT kannte ich ich konnte mit Full Screen PIE nichts anfangen!:laugh:
Gruss
Update
03/24/2013 - AvatarROM 2.4b (CM10.1)
  • Latest CM 10.1 code merges for 2.4b release( upto Mar 22nd 2013)
  • Two new themes (MiUi v5 and Pink theme)
  • Weebo and status bar fixes.
  • Weebo adding actions in log.
  • Performance improvements in animations.
Update
03/31/2013 - AvatarROM 2.5b Release
  • Latest CM 10.1 code merges for 2.5b release(upto Mar 28th 2013)
  • Included new theme chooser based on Aptoide(Alpha release)
  • Lockscreen - Enable/Disable vibration when unlocking from settings -> Lockscreen -> Screen Security -> Vibrate
  • Launcher - Option to edit workspace in menu
  • Weebo - Bug fixes and now you can create your own rules (see - weebo-rules - Avatar)
  • OTA - Full support from client side. Next update will be via OTA.
  • General bug fixes
Update
04/06/2013 - AvatarROM 2.6b Release
  • Full support for OTA
  • Merged with latest CM 10.1 base (Upto Apr 3rd, 2013 - Includes Paranoid style pie control, new Super user app etc)
  • Changes in the framework to redirect trebuchet and android launcher resources from CM themes to Bazooka launcher
  • Fixed launcher menu settings in app space
  • New ThemeChooser - Bug fixes, Performace improvements and new features like download count, caching etc
  • Performance improvements in theming engine
  • Weebo fixes
  • Disabled driving rule in weebo as it was causing lot of confusions
Update
04/19/2013 - AvatarROM 2.7b Release
  • Merged with CM 10.1 M3 build( 14th April )
  • Changed Error Reporter to send requests to server instead of a google document
  • New Theme Chooser fixes
  • Weebo fixes
  • Support for layout theming
Update
04/27/2013 - AvatarROM 2.8b Release
  • Merged CM changes till 24th April ( includes Camera driver fixes for lot of devices )
  • Bazooka Launcher
    • Fixed some critical issues reported in previous build.
    • Added Gestures in workspace. A settings page also added to configure gesture actions. Different gestures like swipe-up, swipe-down, double-tap, home-button press are added. Different actions for each of the gesture can be set in preference.
    • Added ""edit workspace"" option in menu button.
    • Removed ""pinch to preview mode"". This option is currently disabled for some issues as we can go to preview mode through many other ways. It will be added later.
    • Many new Customization options."
  • Lockscreen
    • Fixed a bug
  • Fixed Settings crash on Input Method
  • Fixed Version Number problem in Error Reporter
  • Theme Chooser
    • Removed Old theme chooser
    • enabled Total download count of themes
    • Sorting themes based on download count
    • Sorting themes based on date
    • Settings App now launches the new Theme chooser
Reaktionen: perog
In eigener Sache
Der eine oder andere von Euch wird (vielleicht) eine PN von uns Mods bekommen oder bereits erhalten. Der Hintergrund ist, dass wir etwas "aufräumen" hier im Forum. Ist nicht böse gemeint, wenn Ihr angesprochen werden solltet. Nimmt es bitte ernst, aber nicht persönlich!
Gruss
05/11/2013 - Avatar team is proud to present the 2.10b version based on the latest CM 10.1 RC base (Stable build).
  • Merged with CM 10.1 RC1 tag (May 8th, 2013)
  • Added more space between wifi and signal icons in status bar
  • Added gapps version in Error Reporter
  • Message Bubbles - Reset the bubbles similar to stock version bubble when not themed.
  • Theme Chooser - Themes now display the size of the apk.
  • Theme Chooser - Fixed memory leaks
  • Theme Chooser - Fixed download problems with some themes - cobalt blue, cobalt inferno etc
  • Bazooka --> Fixed Widget scolling issue when Widgets are placed on Home screen.
  • Bazooka --> Fixed the dockbar pages issue. You can select number of pages in Settings screen of Bazooka launcher.
  • Bazooka --> Other minor bug fixes.
  • Weebo --> Fixing the issue where files cannot be read from /mnt/sdcard/weebo folder.
  • Weebo --> Contact picker to make it simpler to select the contacts you want to call/send message to.
  • Weebo --> New categories in "All rules" callled Enabled and Disabled. This shows currently enabled/disabled rules.
  • Weebo --> Location exit condition bug fixed. You can now trigger actions when you leave a particular location.
Reaktionen: perog
Update
05/18/2013 - With more features and fixes Avatar team releasing the latest version 2.11b
  • Added Centre Clock feature - can be enabled/disabled from Settings
  • Made Navigation bar themeable - the resource name is nav_bar_bg
  • Made Statusbar Transparent - Default Status bar is now 25% transparent. Themes which have transparent status bar can make use of this. Seasons is one such theme.
  • Weebo
    • A 4x3 weebo widget can be added in homescreen. It displays current location and recent actions taken by weebo. This list is updated whenever there is location change or any actions are performed by weebo.
    • Fix for change of location when network is not detected
    • Removed cell-Id display from recent events logs. Remove cell-Id entries from recent events list shown in weebo.
    • Changed location tracking time options from locations page. Put a "recommanded" text for 4 hours option and removed "5 minutes" tracking time.
    • Action notifications are getting cleared now
    • Removed Actions in the notifications s when notification is cleared. When user removes notification the actions shown in notification are cleared.
  • Launcher
    • Feature to lock/unlock homescreen. Once homescreen is locked apps or widgets cannot be moved.
    • Fix a bug related to Gesture detection
  • Theme Chooser
    • Some memory leak fixes
    • Added support to share a fav theme on facebook
    Existing AvatarROM users can update via OTA from setting-> About Phone-> Avatar Updates
Download
Reaktionen: perog
Fred danke Dir! Erste Seite ist wieder up 2 Date!
Gruss
Reaktionen: perog
Update
05/25/2013 - Avatar ROM 2.12b release.
Startseite aktuell.
Reaktionen: perog
ROM an sich mag ja okay sein...aber die Truppe macht sich selbst nen schlechten Ruf, indem heute zb bei AndroidPit bei den "News" in so ziemlich jedem Thread in den Kommentaren gespammt wurde, man solle sich doch das ROM mal anschauen...und sorry, aber sowas ist einfach nur PENETRANT und NERVT...und ist für mich zumindest ein Grund, die ROM eben deshalb gerade NICHT zu testen... ^^
Getapatalked von meinem NOTE2...you know... yiiipiiiyayeee, Schweinebacke...! ;-)
Reaktionen: Marcel2580
Ja das ist echt mal nur nervig. Und mal ehrlich wer soviel Aufmerksamkeit braucht, dass die Leute seine Rom testen, da kann die Rom gar nicht so toll sein. Wenn eine Rom sehr gut ist spricht sich das von ganz allein rum.
Moin Moin,
ich bin über Euren Beitrag mehr als irritiert. Den hier wurde bis dato kaum Kommentare zu dieser Rom von den Usern geschrieben. Schaut es euch selbst an. Updates, updates, updates. Ich habe es mal installiert und nutze aktuell die Stock. Das was in anderen Foren (AndroidPit) geschrieben werden, ganz ehrlich interessiert hier nicht. Also wenn Ihr das Penetrante und als nervig empfindet, diskutiert es bitte dort. Den hier fehlt der Bezug. Den hier wird weder aufgefordert es zu testen noch wird etwas in ähnlicher Art und Weise suggeriert.
So und nun weiterhin viel Spass mit der Avatar ROM
Update
Changelog:
06/01/2013 - AvatarROM 2.13b release
CM merges till 28-05-2013
Bazooka --Custom grid size fix. Bug fixes.
Weebo -- UX/UI changes for location screen. Improved UI for mapping location screens.
Nova Launcher fix
Lockscreen support for new MIUI tag
Theme Chooser - some bug fixes
Service unregister crash
Notification added to show theme installing and installed
Download 01/06/13
LG
Andreas
Moin moin, erste Seite wieder up 2 date!
Gruss
Moin,
irgendwie finde ich den Titel etwas irreführend...finde, da sieht es so aus, als wenn das hier ein Sammy-ROM ist...ist aber scheinbar ein CM-ROM?
Vielleicht könnte man da noch was dran ändern? :)
Da es zur Zeit kein Note2 Sammy Rom mit der Version 4.2.2 gibt finde ich, ist es eigentlich eindeutig AOSP/CM.
Und HIER wird es auch als CM geführt.
Gruss
Hi, ich hoffe ich bin hier richtig.
Ich nutze die Avatar ROM,
CyanogenMod-Version: 2.13b-967-20130531-galaxysmtd
Build-Nummer: cm_galaxysmtd-userdebug 4.2.2 JDQ39E 967 dev-keys
Kernel-Version: 3.0.80-gad5ca4c build@jasmine #1 Fri May 31
Baseband-Version: I9000XXJVT
Android-Version: 4.2.2
auf meinem Samsung Galaxy GT-I9000.
Bin an und für sich sehr zufrieden mit der ROM, allerdings ist mir seit 5 Tagen ein sehr schlechter Netzempfang aufgefallen.
Bislang hatte ich in meiner Behausung immer 3-4 Balken Empfang, jetzt nur noch 1, manchmal bricht die Verbindung zum Mobilfunknetz (Congstar, also Telekom-Netz) komplett ab.
Meine Frau nutzt dasselbe Netz und hat diese Probleme mit ihrem Samsung S5230 nicht.
Ich habe deshalb gestern abend ein Update der Rom und der gapps gemacht, eine Verbesserung wurde dabei jedoch nicht erzielt.
Alle anderen Verbindungen (Wlan und Bt) scheinen nicht betroffen zu sein.
Kennt jemand das Problem?
Im Netz habe ich gelesen, dass man das Baseband updaten könnte??
Stimmt das und brächte das eine Verbesserung?
Vielen Dank und Grüße
Dr.No
Taker18
Sealsman
Silverblade
Nufan
Nufan
