DirtyKlot
Ehrenmitglied
- 3.907
Features
Built from ReVolt Sources | Based on Android 4.2.2 JellyBean
ROM Control Features (from AOKP)
Hybrid Engine | Paranoid Preferences (Thanks to PA Team & Carbon ROM)
Per-App-DPI
Per-App-Color
Updates Center | GooManager (With Push Notifications)
CyanogenMod Profiles
Power Widget
Navigation Bar Color
Status Bar Color
Option to select Saving Location in Camera
Option to control cursor in text fields using volume keys
Multi User Option
Advanced Phone Options from CyanogenMod (Vibrate on Answer, Every 45 Sec., On Call waiting and Hangup)
Different Pattern Sizes
Apex Launcher
Nova Launcher
Trebuchet Launcher (ReVolt Version)
cLock App (Lock Clock) (CyanogenMod)
Expanded Desktop (Hide StatusBar & Navigation Bar)
Pie UI (Paranoid Android)
Font Size Controlling
DPI Changer
AOKP Ribbons
CRT On / Off Effect Controller
Lock Screen Targets (CyanogenMod)
Lock Screen Shortcuts (Paranoid Android)
Full List of Features on ReVolt Website
Per-App-DPI
Per-App-Color
Power Widget
Status Bar Color
Multi User Option
Apex Launcher
Nova Launcher
DPI Changer
AOKP Ribbons
Why ReVolt ROM ?
ReVolt ROM is based on AOKP Source with Cherrypicks from CM. ReVolt ROM offers you smoothness, Stability. I will not say for Example that It's the Best ROM(Because Every Developer can Say whatever he wants about his ROM), You try it and let me know what you think ...
Please Don't Forget to donate if you like my Work !
Donate Here
Installation Steps
If coming from a Stock ROM:
1-Root your Device
2-Wipe Data
3-Wipe Cache
4-Wipe Dalvik-Cache
5-Flash ROM
6-Wipe Cache / Dalvik-Cache
7-Enjoy ReVolt ROM !!
2-Wipe Data
3-Wipe Cache
4-Wipe Dalvik-Cache
5-Flash ROM
If Coming from another Custom ROM:
1-Wipe Data
2-Wipe Cache
3-Wipe Dalvik-Cache
4-Flash ROM
5-Wipe Cache / Dalvik-Cache
6-Enjoy ReVolt ROM !!
2-Wipe Cache
3-Wipe Dalvik-Cache
4-Flash ROM
If Upgrading from an older ReVolt Build:
1-Wipe Cache
2-Wipe Dalvik-Cache
3-Flash ROM
4-Wipe Cache / Dalvik-Cache
5-Flash GApps
2-Wipe Dalvik-Cache
3-Flash ROM
5-Flash GApps
Download Links
Version 4.3
1-Merges Latest AOKP and CM changes
2-Added AOKP Ribbons
3-Added StayAwake Toggle
4-Fix hot reboots
5-Fix Navigation Bar layout on Phablet UI
6-Fix Per-App-Color System (Thanks to Bajee11)
7-Fix SOD on lockscreen while on lockscreen (PAC Rom)
8-Add Permissions Manager
9-DARK ReVolt is extended to Calendar, Keyboard and E-Mail
10-Hidden StatusBar Pulldown Feature
11-Fix Pie Toggle (Thanks to Bajee11)
12-General fixes and memory leak fixes
13-Added feature from CM Camera
14-Add initial Support for Oppo Find5, Samsung Galaxy S4(jfltetmo and jfltecan) & HTC one
15-Fixed SystemUI crashes
16-Fixed FC on Tablet UI mode in Lockscreen (Thanks to DaxMaxx)
17-Modular BackUP tool added
18-Added build info in flashing
Big Thanks
1-XDA Developers
2-bajee11 (Aroma Installation Files)
3-AOKP Team
4-CM Team
5-Cyberboob (Logo / Wallpapers / Signatures / ReVolt ROM Thread Organization)
6-BigDenn (Bootanimation)
7-TheWierd (Download Center / Support)
8-ReVolt ROM Supporters & Loyal Users
9-Synergentick (Testing Beta Builds)
10-Carbon ROM (making the port of hybrid engine to AOKP base)
3-AOKP Team
4-CM Team
ScreenShots
