perog
Stamm-User
- 690
@Xi-bit
Ist Normal. Der Dev hat es schon in seinem Thread auf XDA mehrmals geschrieben. Alles gut.
LG
LG
Been quite busy AFK but I've been updating and testing on my own (as usual). I will not be available online from April 22 to 24 as I will be teaching in a client's location so I hope to get the update out before that time, if no major show stoppers pop up on my end.
Here's what the next version will bring: (We're going straight to Rev1.10 as 1.08 and 1.09 are older releases, even if I have it ready it wouldn't make sense releasing an old build)
Rev 1.10
Updated to RedPill Kernel 1.52
Enabled GPU OC/UV for r3p1 (Thanks to Simone R. for the gpu control patch for n7100, Gokhan Moral, AndreiLux and Michael Wodkins)
Made compatible with apps like CPU Adjuster (Thanks to matrix.ppc of RYO Software)
Some stability updates
Updated to support Ad-Hoc Wifi connections
Framework updates and bugfixes
Updated DashClock
Updated Theme Manager
Updated Settings
Added SlimRom's Custom Shortcut Quick Settings Tile (Thanks SlimRom Team)
Enable Auto-hide statusbar (Thanks SlimRom Team)
Translations from SlimRom (Thanks SlimRom Team)
Rev 1.09
Updated to RedPill Kernel 1.51
Patched up to 3.0.74
Minor Bugfixes
Updated Gapps
Updated CMFileManager
Rev 1.08
Updated to RedPill Kernel Rev1.50
Patched up to 3.0.73
GPU OC'd to 733
Updated Contacts (Blacklist function from CM)
Updated Phone (Blacklist function from CM)
Updated Settings
Xi-bit schrieb:die neue HyperDroidAOXP_Rev1.10 (Download) ist online.
