[ROM]04-11-12 Dark Passion Unofficial ParanoidAndroid 2.54 | Fully Inverted | Online
  • 4 Antworten
croatia1
croatia1
Stamm-User
170
Zdravo!
Also da ich schon sehr viel im Note 1 Lager und manchmal im S3 Lager geholfen hab werde ich es auch hier tun!
Xda Link: http://forum.xda-developers.com/showthread.php?t=1973812
Wie jedes mal gilt:
Android-hilfe.de und ich übernehmen keine Haftung auf gebrickte Notes!
Three Musketeers Proudly Present.....
Welcome to the Darkside....
Dark Passion - Unofficial Paranoid Android 2.54
This started as me compiling Paranoid for a few friends over on the Galaxy Nexus and then after a while it was getting modified everytime I compiled it, to add more and more 'Inverted Apps' and its got to the stage now where its all just about inverted.... when one of my friends suggested we should release it on there because it was 'good enough' we thought why the hell not... So now one of the team has a Galaxy Note 2 and he's pestered me till I compiled one for him (only joking man ) so here it is...
As stated this is compiled from source by me. Its just the plain compile, with no cherry picks (yet). We have added various things and taken some out to make it better for us and we will be releasing as is. Now this is made for our little circle of friends and I will not be changing it from how it is now... So please don't ask for the old apps to be added back. If you want a plain standard version of Paranoid, use the official version as that is the benchmark we all try to rise too
I will endeavor to update at least once a week, and update the inverted apps accordingly. Some of the inverted apps I use like Google+ will obviously try to update through Play Store when they are updated. If you update it will revert it to normal, so just simply turn off auto updates for them
Code:
CHANGELOG:
Dark Passion 2.54
Paranoid Android Updates
Updated Gapps
Dark Passion 2.53
Initial Release
Removed Apollo Music
Added Awesome Beats modded DSP manager
Added a few Themes
Added Inverted Keyboard
This rom isn't made to compete with any other roms out there. Its just made by us and released to be another option to whats already out there... If you don't like what we've done here, don't use it...
Check post 3 for Install descriptions
Download
Dark Passion 2.54
Dev-Host - Dark_Passion_pa_n7100-2.54-09NOV2012.zip - The Ultimate Free File Hosting / File Sharing Service
Inverted Gapps
Dev-Host - Vertigo's_Inverted_GApps-04-11-12.zip - The Ultimate Free File Hosting / File Sharing Service
Installation
This guide is based on my install procedure to ensure optimal performance. I am aware that we all have our own preferred methods but I have realised that by following OP procedure its much easier to get help and figure out flashing related issues:
This guide is based on the assumption you have a form of recovery be it CWM and TWRP installed and ready to flash..........I have CWM
- boot into recovery using extended power menu or 3rd party app or 3 button combo home, vol down and power
- in recovery do a nandroid backup from backup/restore menu
- wipe data/factory reset
- in mounts and storage format system
- install zip from sdcard and choose rom zip to install
- install inverted gapps
- wipe cache
- in advanced wipe dalvik cache and fix permissions
- reboot system
I have found that wiping cache and dalvik after installing rom and gapps ensures a clean install on reboot.
This is the exact method I used to install the rom so if u have any issues after using this method then please report it to us. If you used your own method then we may not be able to offer adequate support. thanks for reading and hope you enjoy the rom
Sorry dass es nicht besser aussieht. Ich habs per Tablet gemacht! Ich werde es im laufe des Tages noch bearbeiten
Pozdrav
Croatia1
Reaktionen: bergheil und Funky_
Hat jemand schon getestet
jo kenne die paranoid... sie funktioniert echt gut! ab und an ruckelt es noch einwenig (notification bar) aber das ist bei der originalen sammyrom noch schlimmer ;) also wer bei sammy kein ruckeln sieht.. wird es hier auch nicht...
ich finde nur der jellybean look ist nicht so schön wie der tw sammy look :S tw schaut moderner aus...
Reaktionen: croatia1
Ja Tw ist besser!
Pozdrav
Croatia1
