[Rom]Vanilla RootBox M7 *unofficial* JB 4.2.2
  • 22 Antworten
welche Einstellungen muss ich bitte vornehmen, das mein one so aussieht wie auf den bild von post 1?
danke
NEW BUILD!!!
June.28.2013
Toggle: Music Toggle
A port from Slim and CyanogenMod.
Kudos to them.
FW: Add hybrid toggle to ribbon
FW: Final recents commits
- Bring stock recents to stock: White app name
- No more white frames for RB Style: Grey and Black only
- Keep app name on top right to avoid alignment issues
Port TeamBAKED's tile color supports
- Ability to randomly pick color
- Ability to use custom colors for the tile
- Ability to change the text color of the tile
Credits: travp624
RB Settings: Update media control icon
Add 2G/3G option to profile connections
Only show option when network type is GSM not CDMA
Settings: Privacy Guard support
* Add toggle to InstalledAppDetails to enable/disable privacy guard flag on
a per-application basis.
* Add toggle to enable privacy guard by default for applications.
privacy guard: Fix crash when uninstalling an app
* Don't try to update the privacy guard flag while refreshing after an
uninstall since the PM will throw an exception at us.
framework: Privacy Guard
* Introduce a new privacy feature which allows the user to run an
application with reduced visibility into his or her personal data.
* Adds a per-application flag and simple API to determine if this flag
is enabled for the current or calling process.
* This flag can be used by content providers to decide if they should
return a limited/empty dataset
privacy guard: Use LocationBlacklist for location filtering
* Google has built a per-package blacklist into the location service.
* Let's use this to handle Privacy Guard instead of our one-off code
which has a bunch of edge cases and can leave apps in a weird state.
Toggle: Add a Pressed Background customizable at the back for the tiles with colors
FW: Update Hybrid toggle icon
HALO: Fix memory leaks
sync'd with cm's repo
enjoy!
schade das einiges auf englisch ist aber sonnst top.
  • henschw73
ThoSta
  • raoul110
Roughneck_sp
Roughneck_sp
Blaze1984
Blaze1984
Blaze1984
