[ROM][OFFICIAL] Beanstalk 4.4.200 - M7UL - [12/18/13] 4.4.2
  • 7 Antworten
O
Oberlandus
MIT ABSTAND DIE BESTE KITKAT ROM DIE MIR DURCH USB KABEL GEFLOSSEN IST. SEHR VIELE EINSTELLUNGSMÖGLICHKEITEN BIS HIN ZUM LOCKSCREEN ENTSPERRRING, DEN MAN MIT EINEM EIGENEN BILD BELEGEN KANN.
UND VORALLEM DIE GUTEN ALTEN QUICK-SETTINGS IN DER NOTIFICATIONANZEIGE.
EINFACH MAL ANSCHAUEN.MEINER ANSICHT NACH EIN MUST-HAVE
DOWNLOAD ROM
http://www.androidfilehost.com/?fid=23269279319197002
Default [ROM][OFFICIAL] Beanstalk 4.4.200 - M7UL - [12/18/13] 4.4.2
This is only my compilation; all the real work was done by scott.hart.bti :
"I am proud to present to you BeanStalk Builds put together by myself. This is a build composed off of the CM11 builds and I have added a lot of features on top of it. So you get speed, stability, and ultra customization ability. Many of the additional code additions came from slim ROM and also Derteufels build and have been modified to work with my current setup. A huge thanks to Derteufel and the Slim ROM guys for their work and dedication. Also a big thanks to everyone involved with CM as that is the building stone in this project. Thanks to skyliner33v for the bootanimation and upcoming wallpapers!
I plan on updating this and adding features on a pretty regular basis, so if you happen to like this, keep checking back."
Like what you see? Click the thanks button or Donate to scott.hart.bti by clicking HERE
The original Beanstalk thread can be found here: http://forum.xda-developers.com/show....php?t=2091900
Feature List.
CM based
Lockscreen background options (Color fill, Custom image, Transparent)
Customizable Lockscreen text color
Lockscreen rotation
Option to enable all widgets
Minimize lockscreen challange
Use widget carousel
Slider Shortcuts
Static Lockscreen shortcuts
Lockscreen button actions
LCD Density
HALO
Active Display
Non intrusive call ui
Scroll elasticity options
Default App grip option
Custom Carrier label
Dual Pane options
Customizable boot animation (off, default, set your own bootanimation)
Custom original BeanStalk Wallpapers by skyliner33v
Custom BeanStalk bootanimation by skyliner33v
Status bar color and transparency
Clock and date options which includes color, location, style
Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
Breathing SMS option
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
Quick settings color settings, tiles per row, Quick pulldown, text color
Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
Keyboard and input method options which include disable full screen keyboard and auto rotate
Kil app back button with customizable timeout values
High end graphic effects option
option to disable/enable vibrate on expand for notifications alerts
Low battery warning customizable options
Recents RAM bar fully customizable with color styles
Clock widget for LockClock including extra options to fully customize every feature of the lockclock
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
insane amount of edits/tweaks/fixes to make this build absolutely fly
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Numerous other options hiding throughout the build
This is compiled from source, and scotts git can be found here: https://github.com/scotthartbti?tab=repositories
He also maintains a support thread for development of this ROM, and it can be found here: xda-developers
Installation Instructions:
DO NOT FLASH IF INTENDED DEVICE IS NOT A INTERNATIONAL HTC ONE [M7UL]- THIS ROM IS ONLY FOR THE INTERNATIONAL HTC ONE
DO NOT DIRTY FLASH ANY OF THESE RELEASES ON TOP OF ONE ANOTHER. ALWAYS PERFORM A FULL WIPE(FACTORY RESET - NO INTERNAL DATA)
1) Download ROM
2) Save to internal memory
3) Boot to recovery
4) Perform FULL wipe - NOT INTERNAL MEMORY
5) Flash ROM
6) Flash Gapps
7) Reboot
8) Restore
9) Enjoy!
SPECIAL THANKS:
scott.hart.bti
BMP7777
CM
phoenixita
Reaktionen: Quelle10
Der Download Link geht nicht und der xda Link führt ins leere. Würde es gerne mal testen
Downloadlink kopieren und in browser einfügen.Fertig.Klappt habs selbst getestet.
Der ursprüngliche Beitrag von 21:45 Uhr wurde um 21:47 Uhr ergänzt:
hier der original thread von xda
[ROM][OFFICIAL] Beanstalk 4.4.200 - M7UL - [12/18/13] 4.4.2 - xda-developers
Reaktionen: Rallyharry
Hallo, habe das Rom geflasht und bin sehr zufrieden. Schöne Einstellungsmöglichkeiten ohne überladen zu sein. Akku scheint bis jetzt auch ok zu sein. Funktioniert alles reibungslos, bis auf die Kontakte, diese werden bei mir nicht korrekt angezeigt. Vielleicht weiss jemand Rat.
Das ist ein allgemeines Problem von cm 11 glaub ich.du darfst nicht die DARK UI in Einstellungen aktivieren.Dann wird es korrekt angezeigt.
LG
Super, vielen Dank für die prompte Antwort. Wird dann getestet und berichtet.
LG
Also nun brauch ich doch eure hilfe... ich wollte ART aktivieren und habe ihn neu starten lassen... jetzt zeigt er ständig an: google.gapps.prozesse beendet...
ART einfach nicht aktivieren.Laut tests ist es noch nicht so fortgeschritten, das es wirklich eine spürbare besserung bringt.noch dazu benötigen apps mehr speicher mit aktiviertem 'ART.
Deaktivieren sollte doch schon wieder helfen die Fehlermeldung wieder verschwinden zu lassen.
Blaze1984
Blaze1984
Blaze1984
Hopie
  • Hopie
Hopie
Hopie
kallehagen
